2009 D/FW Toy Run | Page 4 | FerrariChat
2009 D/FW Toy Run
Discussion in 'Texas' started by WDR328, Oct 19, 2009.
  1. 4M son
    4M son Karting
    May 12, 2009
    51
    corinth, texas
    Matthew
    #76 4M son, Nov 24, 2009
    I'm Coming i am Raffi's son. Raffi might not be coming because he has to be at the shop. But i am surely coming.
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,544
    E ' ' '/ F
    Enzo Gorlomi
    Looks like I might be available after all, but the car is in pieces :(
    Big Yeller checking 6 I suppose.
  3. f_399
    f_399 Karting
    Oct 11, 2009
    91
    AJ Pena - 07 VW GTI
  4. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    As we drove by the parking lot where we will all collect pryor to leaving for the base I think I heard the first musical lines of the Hallelujah Chorus. Yes indeed we actually ran the run in it's entirety for the first time. It is 74.5 miles long and it took us 1 hour and 38 minutes to do it. The time length is due specifically to the Ft. Worth urrrrrban spraaaawl. You must also remember we did it at the speed limit to which you all also should adhere.
    So we will rerun it on Thanksgiving just to tweak it and then on Saturday to Ferrarize it. Everything else seems to be falling in place so now we pray for good weather and a huge turn out.
  5. 348 spy
    348 spy Formula Junior
    Nov 17, 2002
    672
    LEWISVILLE
    JANO
    how many pieces tillman.
  6. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    #81 WDR328, Nov 27, 2009
    Well we went out Thursday AM and Ferrarized the part of the route I was a bit concerned about and it is fine! The route seems to flow pretty well once you get out of the spraaal.
    We will run the entire route at the correct time this Saturday just to see what the traffic is like. Still hoping for one more piece to fall into place
  7. Indypits
    Indypits Karting
    Jun 1, 2005
    111
    TX
    Carolyn
    #82 Indypits, Nov 27, 2009
  8. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    Ok the report on the at time run for next Saturday. Additional problems cropped up with apparently intelligent street lights. There is no way to get to the main part of the run unless you make a left turn (1 of 4). The problem we encountered is that when we were doing planning we knew where we wanted to go so we did not do the left turn-just the road and how to get there. On Saturday we got into he left turn lane and bumped smack dab into a 7 second left turn light and you can only make a left on the arrow. In addition we noticed a police presence that we had not seen before.
    Therefore, I have come up with a little different twist on the start-which will be explained on Saturday
    The roads are good, there are a few bumps, but they will be noted on the maps
    I still have a couple of items to work out this week but everything should go well.
    If you want to make a cash donation I will have an envelope at the run otherwise 1 or more toys.
  9. TRScotty
    TRScotty F1 Rookie
    Oct 12, 2006
    2,505
    Tyler, Texas
    Scotty
    Don,
    Thanks again for putting this together. I had an amazing time last year. For those writing a check, to whom do we make it out? I will bring toys, too, more if I can find a trailer to haul the car in with.
    If anyone on this thread will let me borrow their trailer, I (and my lovely 355) would greatly appreciate it!!
  10. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,515
    Southlake, TX
    Rob Lay
    you can borrow the flat bed trailer, never put a Ferrari on it before though. might be loading and unloading issues even with the dovetail.
  11. TRScotty
    TRScotty F1 Rookie
    Oct 12, 2006
    2,505
    Tyler, Texas
    Scotty
    Thanks, Rob.
    Did you use it with your RX-8 race car? Do you think it's too tall or are the ramps too short?
    I have used a break-trailer before, and we had to load it in a ditch (literally) and unload it by undoing the hitch and holding it as we backed the car off.
    If you used it for your track car, it should be ok, right?
  12. rob lay
    Dec 1, 2000
    64,515
    Southlake, TX
    Rob Lay
    #87 rob lay, Nov 29, 2009
    Just used for RX-7 and RX-8's. Both sit higher than a 355. I think the dovetail actually works against you a little as it creates a little bump. Even with the Mazdas I would try to back up towards a hill, put extra boards under the ramp, and jack up the front a little. I'm sure you could get it to work, would just have to be careful.
    Also, when I tie-down the 355 in the enclosed it attaches to D-rings in the floor. Attachment points on flat trailer are usually higher and can rub underneath.
    Here are some pics...
  13. TRScotty
    TRScotty F1 Rookie
    Oct 12, 2006
    2,505
    Tyler, Texas
    Scotty
    Thanks Rob,
    That gives me a little more perspective. I have been networking here locally for an enclosed, as I would really like to secure the car without any issues. If I can't get his trailer, I may just have to drive. Thanks alot for the offer, I'll let you know if I can use it.
  14. WJHMH
    WJHMH Two Time F1 World Champ
    26,602
    Panther City, Texas
    WJHMH
  15. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    Scotty, remember that if you lift the tongue of the trailer that decreases the angle of approach for the car. This makes it easier for you to load a low clearance vehicle. Then when the car is on the trailer you let the tongue down on the hitch. I had to move an 8,000 lb. fork lift one time (very low clearance vehicle) and it had a bad transmission so it did not move. We put a 3 ton Hein Werner floor jack under the front of the trailer, lifted the frond, hand winched the fork lift onto the trailer and let the front of the trailer down onto the hitch. It was really quite simple.
  16. jeffb99tx
    jeffb99tx Formula Junior
    Sep 15, 2004
    292
    Dallas, Texas
    Jeff
    Hi Don, I have a quick question and I probably missed the answer back a few pages, but here it is anyway. Do the presents need to be wrapped? Should we donate wrapping also?
    Thanks,
    Jeff
    Alfa 164
  17. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    #92 WDR328, Nov 30, 2009
    I am going to start a list of people that have said that they will be attending;
    Here is the official list!
    Don & Carolyn
    Frank Sprow
    TR Scotty
    'the other William H'
    Jake Miller
    Rob Lay
    Stew F.
    Steve F.
    Mike Khun
    Brian Ratcliff
    Raffi
    Jano
    Dan Gardinger
    Mike Hersey
    Joe & Becky
    Bob lewis
    Chet parsons
    Safe For Now-RS6
    Jim-S6
    Ratfink RS6-RS6
    S8Tuner-S8
    Eric The Red S4-S4
    PZ-TBD
    Mr_CT9A-TBD
    Johntesi-F430 or Alpina B7
    Texas RS6-RS6
    cc08GT2-GT2
    Mrs. cc08GT2-Panamerica Turbo
    bbs993TT-CGF
    Silentrun-997TT
    RaceMX-M3-M3
    Fubar-Ford GT
    Jetmech-M3
    TEJS-Lotus
    Westrock-Lotus
    5Qf3764b-Lotus
    TR4-Lotus
    MikeMC1-Lotus
    Sweet and Low-Lotus
    Nerces M-M3
    TonyP-'63 Lincoln
    Scott72 Olds
    GregTR
    Mike B.
    Frances
    Robert Parlato
    Brant Worrell
    Tom Minella
    Marci
    Sam Emerick
    John & Carol Knight?
    Brannon & Christy
    Plane Guy
    DB (Challengehauler)
    512 Dreamer?
    David Seizer
    CR Fitch
    Don & Pam Payne
    Damiel & AAron
    Greg & Jamie Thompson
    David Knapp
    Shaun & Lucinda Howard
    Larry Freeman
    Kenneth Struck
    Kimson
    Jeffb99tx
    Nicola-Apparently flying in for this one A BIG THANKS
    Kenneth
    AJ Pena
    The turbo Saab clb-7 cars
    Italian Car Club of the Southwest-6 cars
    Scsuperman105
    Kevin Foster
    Shayne77
    Jared-Camero
    Curz
    Monarch air-2 cars
    It looks like 89 cars at this point. I would like to see thirty five more sign up!!! Remember last year we had over a hundred.
  18. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    I will have an envelope at the run for cash/check donations. If you would like to write a check and it is in excess of $10,000. just make it out to me:)---JUST KIDDING. Make your checks out to Collin County Children's Advocate and I will deliver that envelope on Monday to those folks.
    Thanks again for all you help and generosity. It looks like the weather will be good for Saturday perhaps a little windy!
  19. s_chev
    s_chev Rookie
    Nov 30, 2009
    1
    Keller, TX
    Steve Chevier
    I'm not sure if anyone else from the Maverick Porsche club has chimed in, but I'll spread the news on that site also. This should be a blast.
    Count me in.
    Steve and Jackie C.
    86 911 Targa
  20. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,889
    Dallas Texas
    If you know you know
    #95 SAFE4NOW, Nov 30, 2009
  21. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    Jeff-the toys should be unwrapped and don't worry about the wrapping paper. Thanks for joining in and it should be fun.
  22. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    FOR ALL PEOPLE COMING FROM DALLAS AND THE NORTH--ATTENTION PLEASE!
    When you are proceeding south on east loop 820 you will come upon the 820/287 junction. Just before that intersection there is a sign that says Sun Valley Exit 3/4 of a mile. The problem is that when you go under 287 you will see that there are 2 lanes of merging traffic from east bound 287 onto 820 and that makes getting to the Sun Valley exit a little difficult.
    In the event you cannot safely get to the SV exit get over to the right lane and proceed south on 820 and exit on business 287 this is the next exit. Turn right and go to Parker-Henderson Road (approx. 5 blocks). Turn right(N) and go to David Strickland (approx.5 blocks) turn right there and go 3 blocks to Durothy. Turn right there and go 1 block to Vesta Farley.
  23. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    STEVE THAT IS ABSOLUTELY AWESOME!!!!! YOU WILL HAVE TO DRIVE THAT CAR BY REMOTE CONTROL:)
  24. LEXUSF
    LEXUSF Rookie
    Nov 30, 2009
    1
    i would like to go! one of the guys posted this in our forum and i would love to join u guys!
  25. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    25,049
    Dallas, TX
    Jim E
    Scotty, I used Robs trailer to pull my 328, and it took some planning. I got 2 10' 2x12's, had them cut into 5', 3' and 2' sections, and still had some approach problems. (I put the 5' on the ground, then the 3', then the 2', then the ramps). I'd assume the 355 will present similar problems. I used a sloped driveway, curbs, whatever I could find to reduce the angle to load/unload. No problems, but it did require some thought.
    Don, add David J, in a 911 turbo cab. Coworker of mine that attended last year. He has details and told me today he'll make it.
