2011 458 Retrofit Ipod adapter? | Page 2 | FerrariChat
Discussion in '458 Italia/488/F8' started by css, Dec 11, 2016.
  1. daflk
    daflk Formula Junior
    Jan 27, 2013
    257
    Hong Kong
    Where exactly it’s not on the audio system as shown, is it only on the NAV units?
  2. NorCal458
    NorCal458 Rookie
    Sep 17, 2018
    4
    Northern California
    BG
    Man I wish there was an answer for this. I have a 13 and would love to have the iPod connection.
  3. daflk
    Jan 27, 2013
    257
    Hong Kong
    Same
  4. F60SA
    F60SA Karting
    Nov 15, 2014
    82
    I promise its there - remove glovebox - remove NIT unit and its right behind the dashboard on the left hand side
  5. sfcorsa1
    sfcorsa1 Rookie
    Aug 31, 2017
    22
    AVN
    My friends 2012 did not have this option and after disassembling most of the dash and the glove box there was no plug in available for the oem iPod connector (bought from Ferrari). So I don’t know why there are conflicting info out there but as far as I know it is not possible
    Sent from my iPhone using Tapatalk Pro
  6. daflk
    Jan 27, 2013
    257
    Hong Kong
    I can echo this, there’s no harness or fitting plug behind the audio amp or head unit that allows the iPod cable to plug in
    I suspect you need to get a head unit (GPS variant). Can someone confirm???
  7. daflk
    Jan 27, 2013
    257
    Hong Kong
    Can you provide more details, you mentioned it’s a harness, where exactly does the harness connect to?
    What is the “dashboard” is it the aircon controls?
    Left head drive on a LHD or RHD car? Does it differ depending on that?
  8. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    Well guys I found it, you don’t have to waste 2 hours removing the glove box, its behind the center HVAC control, there are 3-4 bolts on the bottom of the dash, remove those then the entire center pops right out. Pull the foam back its attached to a metal rail on the right side. Plugged in the IPod adapter and the Bovee and the it pops up on the menu. Pics are here..
    ecf34, 458Spider2013, Rody and 3 others like this.
  9. stretchgeneral
    stretchgeneral Formula 3
    1,436
    MA/TX
    McK
    What year 458?
  10. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    2014 without Nav
  11. PJxxx
    PJxxx Karting
    Sep 14, 2017
    129
    PJ Cusano
    Great news Kevin!
    Question: I have a 2012 with Nav.
    To get the iPod function, do I simply plug in Ferrari cable(part#257948) into this I’m good to go?
    Tomking997 and daflk like this.
  12. PJxxx
    PJxxx Karting
    Sep 14, 2017
    129
    PJ Cusano
    Kevin, another dumb question potentially... where are these screws to be removed? Under the glovebox, near the driver side footwell? Don’t see any under HVAC
  13. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    Yes plug it in and good to go, I connected the Bovee Bluetooth adapter to it, as soon as the phone connects the iPod icon comes up.
    The screws are down right above the carpet line above cup holders and then a few under steering column area.
    PJxxx likes this.
  14. daflk
    Jan 27, 2013
    257
    Hong Kong
    Anyone else been able to find it? Can we get better pics?
  15. PJxxx
    PJxxx Karting
    Sep 14, 2017
    129
    PJ Cusano
    Thank you Kevin.
    There’s a lot of foam in there and I’m trying to figure out what side the iPod connector is on. Is it on the right side of the HVAC when looking from the back of the unit?
  16. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    If you pull the foam out and you're looking its in the back right side.. I made this video...
  17. PJxxx
    PJxxx Karting
    Sep 14, 2017
    129
    PJ Cusano
    Thanks for the video. I’m thinking I need to create a little more room.
    Thanks for your help
  18. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    You’re welcome let us know the outcome!
  19. Gstefanick
    Gstefanick Rookie
    Jan 17, 2019
    12
    George Stefanick
    The problem ive had with the Bovee is you need to replug it back into the adapter after the car is shut off and restarted.
    Anyone else ?
  20. Atreides
    Atreides Rookie
    Apr 9, 2018
    19
    Dunedin, FL
    Paul M
    ecf34 and 458SG like this.
  21. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    No mine
  22. Kevin M.
    Kevin M. Rookie
    Jun 18, 2006
    35
    Nice, glad you found it!
  23. Atreides
    Atreides Rookie
    Apr 9, 2018
    19
    Dunedin, FL
    Paul M
  24. Suborbital
    Suborbital Karting
    Apr 25, 2018
    61
    Fallbrook, Ca
    This is normal, sometimes it works and I get surprised, but most of the time you are going to have to settle for iPod track 1475 or something like that
  25. Atreides
    Atreides Rookie
    Apr 9, 2018
    19
    Dunedin, FL
    Paul M
    What are you using to connect to the Bovee? I'm using spotify on a pixel phone and can't get the song/artist display or car controls.
