2011 599 HGTE Low Oil Pressure Light | FerrariChat
Discussion in '612/599' started by Ducati348, May 26, 2024.
  1. Ducati348
    Ducati348 Karting
    May 15, 2009
    80
    Dallas, Texas
    Alex Scroppo
    I just had a low oil pressure warning light show up several times on my dashboard as I was driving. Obviously, very disconcerting when that happens. I pulled over when I could and checked the oil level, and it was exactly where it was supposed to be, halfway between the dipstick marks. Once I shut of the car and restarted it, I have not seen the light come back. I am hoping it's just a faulty senor. Does anyone know where the oil pressure sensor is located and perhaps a part number for it? If anyone has experienced this problem before I would appreciate hearing from them. Any and all advice is welcomed.
    Thanks!
  2. Skidkid
    Skidkid F1 Veteran
    9,689
    Campbell, CA
    John Zornes
    The sensors have had some issues so probably a sensor. BUT, checking the oil is a bit fiddly; did you check it correctly?
    The process:
    Engine at temp
    Run 4500 RPM for 1 min
    Idle for 2 min (at 3 min you must start over)
    Check oil without turning off the engine
  3. Ducati348
    Ducati348 Karting
    May 15, 2009
    80
    Dallas, Texas
    Alex Scroppo
    Thanks for the quick response Skidkid. Yes, I followed the procedure and checked the oil level correctly. I ordered the superseded oil sensor part, PN 304074. Hopefully, the sensor is accessible without having to take off too many parts.
    Skidkid likes this.
  4. HK Mondial
    HK Mondial Karting
    Mar 12, 2007
    89
    Mark M.
    Unfortunately not ! Requires removing inlet manifold on that side if I remember correctly. I had the same problem, (low pressure warning light) and wanted to put an oil pressure gauge on, to test pressure to see if the sensor was the problem, but couldn't. So changed sensor -problem fixed
    brogenville, Ducati348 and Skidkid like this.
  5. MarksCollection1055
    May 28, 2014
    3
    Hey can you tell me where this sensor is? I’m having same issue and going to change it out and have the passenger side manifold off but don’t see anything
