2014 pre-launch thread | Page 5 | FerrariChat
Discussion in 'F1' started by Ferraripilot, Dec 15, 2013.
  1. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    I dunno know man..... Playing devils advocate for a moment, they've chopped what, 6 inches off the width, that's quite a bit. More importantly, they can no longer 'steer' the air around the outside of the front tires like they were doing without that width.
    OK, the (supposedly) all important blowing has gone, but dear old Williams said their cars driveability improved once they got rid of it. May not be generating Newey levels of D/F, but driver confidence counts for a hell of a lot.
    It should be interesting that's for sure!
    Cheers,
    Ian
  2. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    You think they care two hoots about 'visual compromises'?
    Here I have to disagree!..... If it works, they'd build the ugliest looking thing we've ever seen! 'Beauty' is not even on their priority list! ;)
    Now, as has been said many times, there's often a good correlation between what 'looks right' and what 'goes right', but with aero at this level, they'll do whatever they think will work best and beauty be damned!
    Cheers,
    Ian
  3. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    Ettore Bugatti showed that pretty design isn't always good design.
    Fast is beautiful but beautiful isn't always fast.
  4. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Well said. I just wish the rules were geared towards better looking cars. Things only really took a turn for the worst in 2009.
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,981
    Atlanta
    John!
    It's 6 inches of front wing width vs. completely doing away with the blow diffuser (worth upwards of 20 points) and beam wings (also another 20 points or so). So, 6 inches compared to what was lost off the back isn't squat.
    Williams could never get their EBD working right anyway so I don't judge their pace whilst not using it as a team worth providing significant data.
    Red Bull based their entire car paradigm on the EBD, and the Renault engine was simply best for it as it yielded just plain superior blowing properties.
  6. Ferraripilot
    May 10, 2006
    17,981
    Atlanta
    John!
    Mclaren not building a hump nose a couple years ago was a great example of a car that went like heck but looked good.
  7. Ferraripilot
    May 10, 2006
    17,981
    Atlanta
    John!
    #107 Ferraripilot, Jan 9, 2014
    The Ferrari may have a brilliant engine and exhaust system with them exiting from the center ie. no exhaust pipes going into the sidepods taking up space.
    BTW, this IS within the rules
    IF Ferrari have done this, it's a masterstroke of cleverness. It's been done before in other engines, but not here. Love it.
    From Scarbs:
  8. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Hmmmm.... 2014 tech regs;
    Guess I'll go read what Scarbs has to say......
    Cheers,
    Ian
  9. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    At the start, but they eventually had to redesign it to keep pace in development.
  10. Ferraripilot
    May 10, 2006
    17,981
    Atlanta
    John!
    per Scarbs:
    "I drew the ferrari engine with exhausts exiting upwards through the heads, not through the outer face of the head. This would keep exhausts short and keep the total engine installation much narrower.
    The rules only demand the exhausts exit outboard of the cylinder bores centre line, the top exit exhausts meet this rule. Similar exhaust ports have been used on the lancia delta group B car and some BMW racing engines."
  11. Igor Ound
    Igor Ound F1 Veteran
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    Finally some engine cleverness
  12. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,902
    @ the wheel
    Andreas
    Yeeha!
    And if my prediction of the Renault engines going Kablamo comes through, then the eternal runner up from the past few years could finally be the one getting crowned.
    Forza Fernando! Forza Ferrari!
  13. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,292
    Worcester, England
    Phill J
    Considering how much heat these engines are liable to produce, especially through the exhaust system, I would have thought it could be counter-productive to have the inlet manifolds and the exhaust manifolds too close together due to heating up the air entering the engine?
  14. piolaxo
    piolaxo Formula Junior
    Feb 24, 2012
    652
    Bay Area
    Salvador
    ...And Renault may be reading these lines and start changing their setup. :)
  15. crinoid
    crinoid F1 World Champ
    10,084
    LaCrinoid
    I can't find the article on the blog?
  16. Ferraripilot
    May 10, 2006
    17,981
    Atlanta
    John!
    Scarbs posted this on the F1technical forum where he actively posts. Scarbs also tweeted the idea.
  17. crinoid
    10,084
    LaCrinoid
    Ok thanks
  18. Ferraripilot
    May 10, 2006
    17,981
    Atlanta
    John!
    This is all conjecture at the moment, but it was prompted by something or other, no idea what yet.
    Heat would be an issue with that much 'stuff' in a small area with various functions, but the spacial savings would be worth it if they can get their hands around the heat. Everyone has been banking on cars needing larger sidepods due to the new cooling requirements so it would really be something to see Ferrari show up with this. It would take better part of a year for any other team to implement such a design with an entirely new cylinder head and everything else that goes along with it to reap the benefits.
  19. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    OK, thanks. That's what I wasn't seeing in his drawing.
    Awesome stuff if true! (Not that they meet the rule, but that they're trying it!)
    Can't help thinking exhaust valve control is gonna be 'interesting' in that configuration...... Even pneumatics need some space.
    But hey, who said innovation is dead in F1? ;)
    Cheers,
    Ian
  20. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Maybe..... 'This is why we watch' ;)
    Ouch!
    Certainly, they never got it going like the Cans, but then neither did anyone else.
    Williams were using the same lump of course.......
    Cheers,
    Ian
  21. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    Spain practice on Jan. 29-30 only 10-12 allowed 00 euros per day. team trailer is the venue. I am not going. this is through Ferrari F 1 Club. should b interesting
  22. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    I'm liking the sound of this more & more......
    Big torque, no TC, no EBD & (supposedly anyway), way less D/F.
    Maybe the jockeys will become 'important' again. ;)
    Cheers,
    Ian
    F1 drivers will need all-new race approach for 2014 - F1 news - AUTOSPORT.com
  23. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
  24. Igor Ound
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
  25. DF1
    DF1 Three Time F1 World Champ
    Exactly. Allison comments allude to going slow to save fuel. Not good.
