2022 Barcelona - Catalunya Testing | Page 5 | FerrariChat
Discussion in 'F1' started by jgonzalesm6, Feb 9, 2022.
  1. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    After seeing the RB and knowing Newey’s genius this may be a long season for Ferrari and F1 in general.
    Picchu88, subirg, 20000rpm and 4 others like this.
  2. Phil~
    Phil~ F1 Rookie
    3,937
    Potomac, Maryland
    Charles fastest so far
    Dino2010 likes this.
  3. Dino2010
    Dino2010 F1 Rookie
    4,852
    Belgium
    jgonzalesm6 likes this.
  4. Dino2010
    Dino2010 F1 Rookie
    4,852
    Belgium
    Guys, did you notice the silver arrows are back to silver... ? :D
  5. furoni
    furoni F1 World Champ
    Jun 6, 2011
    14,026
    Vila Verde
    Pedro Braga Soares
    "Our" car is a beauty!
    jcurry, 1HSV1 and pilotoCS like this.
  6. DF1
    DF1 Three Time F1 World Champ
    The secrets revealed in Red Bull's belated RB18 unveiling
    By: Jake Boxall-Legge
    Feb 23, 2022, 5:46 AM
    https://www.autosport.com/f1/news/the-secrets-revealed-in-red-bulls-belated-rb18-unveiling/8425707/
    Late is the hour at which Red Bull chooses to appear. Having escorted Max Verstappen to his first Formula 1 world title, the team's new RB18 had yet to break cover as the team elected to “launch” its new model with...a completely different car.
    But perhaps Red Bull is never late, or early, and has unveiled its car precisely when it means to. Aiming to keep some of its details under wraps to ensure they couldn’t be assimilated into the other cars, Barcelona’s “shakedown event” proved to be the first proper look at its new championship challenger.
    And, as expected, it’s taken a very bold approach to the new F1 regulations, even if the front wing looks relatively conventional by the current standards compared to those we’ve already seen. The wing features a centrally loaded layout which sweeps downwards towards the tips, with part of the flap adjuster mechanism placed either side of the nose in a bid to build a small vortex and send it around the front wheels.
    The endplates are squared off in a manner similar to its ‘sister’ AlphaTauri team and, like many of the recent Red Bull F1 cars, the nose features a small snorkel at the tip, built into the wing element behind the front plane.
    But the front suspension is altogether more interesting. Like McLaren, Red Bull has switched to a pullrod layout while the upper wishbone is also arranged curiously, with the rear leg mounted much further down on the chassis bulkhead in an apparent bid to control the oncoming airflow and turn it downwards. There’s been a lot of focus in this area amid the new rules, especially with the reduced aero componentry, and directing airflow to the front of the sidepods with the suspension components appears to be in vogue.
    Speaking of those sidepods, Red Bull has really rolled up its sleeves in this area. They feature a very heavy undercut, helped by extending the bottom leading edge of the inlet forward. In this area, the opening of the floor’s Venturi tunnels features a bargeboard-like extension over the top. Sharp, exposed corners produce and energise vortices to help shunt airflow outwards, guiding any tyre wake away from the floor area.
    Dramatic undercut on the sidepods is designed to channel air more effectively
    Photo by: Mark Sutton / Motorsport Images
    Airflow will pass around that undercut and around the flat-sided sidepods to be drawn into the rear 'Coke bottle' region, while the air passing over the top follows a downwards ramp to also feed towards the back of the car. This has been done by positioning many of the cooling components closer to the centre of the car, necessitating a larger inlet above the driver's head. There’s also a few tidbits around the halo area, with the mounting points either side of the driver’s head rather extended in size to help provide the airflow with greater direction over the engine cover area.
    The floor too features a range of interesting little details, with a small cut in its edge and a squared-off ‘Z-floor’ - similar to those seen in F1 last year – towards the rear. The exposed corners will also help produce airflow patterns to help seal the floor, protecting the underbody flow within the Venturi tunnels to ensure they retain their efficiency.
    PLUS: How F1 teams tackled 2021's unique development war
    At the rear, Red Bull has switched to a pushrod rear suspension format, opening up the floor space more for the Venturi tunnels to deliver the right amount of airflow expansion – creating the suction that can result in a high downforce yield. As such, the pushrod rockers are mounted on top of the gearbox/tailpipe area to accommodate the reworked suspension. Given that Red Bull popularised the shift to pullrod suspension at the rear, this is an interesting volte face from the team, and suggests that the team has been able to find plenty of gains in the pushrod switch.
    As expected, it’s taken a very bold approach to the new F1 regulations, even if the front wing looks relatively conventional by the current standards compared to those we’ve already seen
    The bodywork in this area bulges out to allow hot air to escape, as Red Bull has not opted to pepper its engine cover with any gill-like slots at this stage in time. This necessitates a larger exit, which has been positioned a little higher up in a bid to keep the beam wing open.
    For the most part, the overall rear wing shape doesn’t show anything out of the ordinary at this stage, featuring a relatively flat mainplane. The central part of the upper flap features the V-shaped cutout to bleed off any wake from the DRS housing – which appears to conform to current style and sits within a singular wing mounting.
    But although the sidepods are visually different to the other concepts seen in F1’s 2022 prologue, the rest of the car seems relatively conventional compared to the others. But it’s simply impossible to say if the car’s good simply from looking at it; especially as the most important part of the new regulations (the underbody) is naturally obscured from view. And if we do get a glimpse of a 2022 floor, something’s most likely gone very wrong.
    Underbody will be the most important element of new car design
    Photo by: Red Bull Content Pool
    As of the morning session in Barcelona’s shakedown it appears that the RB18 has good reliability out of the box, Verstappen logging 35 laps within the first hour and 30 minutes around the Circuit de Barcelona-Catalunya. That will be encouraging for Red Bull as it looks to build on its first title since 2013, especially as it also hopes to make another push for the constructors’ title after just missing out to Mercedes in 2021.
    Like last year, the two teams couldn’t be any more different in philosophy; Mercedes opting for a tight rear-end package while Red Bull has sculpted its sidepods in a completely different fashion – just as the two were on the opposite sides of the rake spectrum across the past few seasons. And yet, there was nothing between the two teams last season.
    As I write this, Mercedes and Red Bull sit separated by a tenth as George Russell and Verstappen have logged a similar number of laps around the Barcelona venue. Is that a harbinger of things to come once again in 2022 – or is Red Bull’s decision to keep its RB18 secrets until the very last minute a precursor to more secrets becoming apparent later on? At this stage, it’s impossible to say.
    Red Bull was reliable out of the box on Wednesday morning
    NürScud likes this.
  7. classic308
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    being fast would make it more beautiful……let’s cross our fingers. It’s about mileage and data gathering today.
    375+, jgonzalesm6 and DF1 like this.
  8. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    24,703
    Corpus Christi, Tx.
    Joe R Gonzales
  9. jgonzalesm6
    24,703
    Corpus Christi, Tx.
    Joe R Gonzales
  10. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,029
    ESP
    Bas
    DF1 likes this.
  11. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    46,182
    Toe Knee
  12. furoni
    Jun 6, 2011
    14,026
    Vila Verde
    Pedro Braga Soares
    fastest and with so many laps, we can only see it as a positive!
    ingegnere likes this.
  13. Bas
    Mar 24, 2008
    43,029
    ESP
    Bas
    NürScud and chinaleeexports like this.
  14. pilotoCS
    pilotoCS F1 World Champ
    May 19, 2019
    13,483
    The Capital of The United States of America
    Willis
  15. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,858
    NürScud likes this.
  16. pilotoCS
    May 19, 2019
    13,483
    Willis
    NürScud, SS454 and DF1 like this.
  17. trumpet77
    trumpet77 Formula 3
    Jun 13, 2011
    2,181
    Great Neck, NY
    Robert Nixon
    Haas is in F1 so Gene can sell more CNC machines. I just bought a dozen. :D
    ingegnere, Jeronimo GTO and jcurry like this.
  18. Kimi2007
    Kimi2007 Formula 3
    Jan 16, 2022
    1,371
    Patrick James
    Interestingly, the sector times suggest we gained the most time in sectors 2 and 3 today.
    Lec =Sector 1 = 22.632 Sector 2 = 30.092 Sector 3 = 27.386
    Nor = Sector 1= 22.564 Sector 2 = 30.212 Sector 3 =27.698
    Rus = Sector 1 = 22.600 -Sector 2 = 30.269 Sector 3 = 27.704
    Leclerc and Russell are the only ones taking turn 9 flat out right now. Leclerc is being very aggressive with the car, which together with the pace of the car in Sectors 2 and 3 strongly suggest the cars very good downforce, and Leclerc has total confidence in the car. And it doesn't even look like Ferrari were going for any headline grabbing fast times or running flat out, either.
    Do we have the best car? Still don't know, but the car is solid. Most solid we've seen in some time.
    Picchu88, 635CSI, crinoid and 3 others like this.
  19. jgonzalesm6
    24,703
    Corpus Christi, Tx.
    Joe R Gonzales
    I wouldn't put too much emphasis on sector times or lap times.
    It's all about laps(how many) and reliability.
    Bas, crinoid and classic308 like this.
  20. Top speed
    Top speed Formula Junior
    Jul 4, 2020
    880
    Joonas
    I got similar thoughts after the morning run; and yes Ferrari isn't going for fast times, Binotto said so in the car reveal. The engine seems as good as Binotto promised.
    crinoid likes this.
  21. Kimi2007
    Kimi2007 Formula 3
    Jan 16, 2022
    1,371
    Patrick James
    Of course, I just thought it was interesting that we're getting good times in the higher downforce areas of the track, and Leclerc is showing high confidence in the car.
    First time in a long time I've seen a Ferrari driver really enjoying themselves with a new car, and eager to push it further.
    crinoid and ingegnere like this.
  22. jgonzalesm6
    24,703
    Corpus Christi, Tx.
    Joe R Gonzales
    Mercedes has vented cooling louvers they can just pop onto the side of the bodywork...interesting.
  23. Bas
    Mar 24, 2008
    43,029
    ESP
    Bas
    This used to be in the past as well. Efficient way to optimize aero/cooling.
