2022 CanadianGP("Salut Gilles") Pre-Race Thread | Page 2 | FerrariChat
Discussion in 'F1' started by jgonzalesm6, Jun 4, 2022.
  1. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    24,660
    Corpus Christi, Tx.
    Joe R Gonzales
    @ingegnere
    Any idea where Ocon is at???
    mcimino and jpalmito like this.
  2. ingegnere
    ingegnere F1 Veteran
    5,567
    Montreal
    #27 ingegnere, Jun 13, 2022
    Looks like would be here, Hotel Place D’Armes. Just like home for him ;)
    Looking the other way down Rue St-Jacques…
    BTW, all that orange in Ocon’s picture is not a mob of Verstappen fans, those are just some of the millions of construction site cones lining the streets of Montréal as our mayor tries to destroy every possibility to drive a car around town, either through construction and road closures or restricting roads to pedestrians and bike traffic only.
    stavura, 20000rpm, kes7u and 4 others like this.
  3. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,999
    ESP
    Bas
  4. Bas
    Mar 24, 2008
    42,999
    ESP
    Bas
    Can't quite work it out from the FIA documents as it seems they're incomplete, but if I'm right Leclerc's 1st turbo (That they could use) has bahrain, jeddah, australia, Imola, (all practices, qualies and races) and miami FP1/2/3 on it.
    That's quite a lot. But the only way to avoid penalties.
  5. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,281
    Le caylar (France)
    mathieu Jeantet
    Penalties are unavoidable in the end so better change the whole power unit.
  6. Bas
    Mar 24, 2008
    42,999
    ESP
    Bas
    I would think that overtaking at Silverstone is easier (higher downforce), but the risk of yet another turbo failure using such an old unit are quite high. I think changing all elements would result in a pitlane start even?!
  7. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,281
    Le caylar (France)
    mathieu Jeantet
    We are in for 6 or 7 PU for Ferrari this year so frankly it doesn’t matter where anymore.
    If you asked I’m pretty sure Binotto already told the team they won’t be able to fight for both titles this year..
    20000rpm, 375+, Bas and 2 others like this.
  8. william
    william Two Time F1 World Champ
    Jun 3, 2006
    27,870
    Binotto declared that early in the season, I believe.
    That was commented on this forum as demotivating for the team.
    What happened at Baku unfortunately may confirm that.
    jcurry and jgonzalesm6 like this.
  9. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,281
    Le caylar (France)
    mathieu Jeantet
    He just say the truth.
    We have to listen him more carefully now and no more extrapolate..
    ingegnere likes this.
  10. Bas
    Mar 24, 2008
    42,999
    ESP
    Bas
    That's true.
    An entire new unit in canada should allow them to at least fight for victory in Silverstone. Taking a penalty at silverstone rules that out and using the old turbo will limit power and risk another failure as well...sigh.
    375+ likes this.
  11. william
    Jun 3, 2006
    27,870
    I think Binotto tried to dampen the tifosi's expectations after the early success.
  12. trumpet77
    trumpet77 Formula 3
    Jun 13, 2011
    2,181
    Great Neck, NY
    Robert Nixon
    Didn't LEC coast into the pits in Baku and stop in front of the weigh bridge? That means dead engine in my book.
  13. jgonzalesm6
    24,660
    Corpus Christi, Tx.
    Joe R Gonzales
  14. jgonzalesm6
    24,660
    Corpus Christi, Tx.
    Joe R Gonzales
    E60 M5, Finlander and Bas like this.
  15. ingegnere
    5,567
    Montreal
    They’ll do this for sure after a bad quali at some point or at a Sprint race.
    Here they have a chance to win so if they have confidence in the life of the turbo they’ll try to keep turbo #1.
    The big question mark is the part that failed—a part that seemingly has not had issues for years. Was this a one-off quality problem or a bad batch? If so, they need to track down the whole batch. Would be interesting to know what happened to MAG and if it’s related.
  16. Bas
    Mar 24, 2008
    42,999
    ESP
    Bas
    Both tthe engine and turbo are unrecoverable. Did the turbo let go and parts got inside the ICE that destroyed it or did the ICE fail...
    trumpet77 likes this.
  17. ingegnere
    5,567
    Montreal
    Could be both, yes? If compressor end of turbo fails pieces will be ingested by the ICE and damage it. If the engine fails and liberates bits, this will damage the turbine end.
    From the article, if the failure initiated at the ICE cylinder head then likely the turbo also damaged as a result. Really unlucky if that’s the case.
    Bas likes this.
  18. Bas
    Mar 24, 2008
    42,999
    ESP
    Bas
    Quite worrying...if it kept being a turbo failure it would seem like a lot simpler fix, like Red bull and their fuel issues. It's constantly different things for Ferrari engines, ICE, Turbo, MGU failures, hydraulic issues...
  19. ingegnere
    5,567
    Montreal
    BTW, less than 20 minutes from the circuit. One of the reasons the teams like it here. 24 minutes by bike, according to Google.
    Red arrow on map is where I was refused access to the sight last week—so close, LOL. Ocon will probs have no issues ;)
    Javierix likes this.
  20. ingegnere
    5,567
    Montreal
    The randomness of the engine bit that failed and the hydraulic pump are the concern, really.
    Apparently the turbo that failed at Barcelona was probably installed or operated incorrectly and its failure caused the MGU-H failure. Same thing here with the collateral damage of the turbo.
    Bas likes this.
  21. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,281
    Le caylar (France)
    mathieu Jeantet
    Absolutely inadmissible if true :mad:
  22. Bas
    Mar 24, 2008
    42,999
    ESP
    Bas
    jgonzalesm6 and 375+ like this.
  23. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    8,281
    Le caylar (France)
    mathieu Jeantet
    Bas likes this.
  24. jgonzalesm6
    24,660
    Corpus Christi, Tx.
    Joe R Gonzales
    Another Ferrari Strategist foul up???
    Finlander, absostone and Bas like this.
  25. Formula 1
    Formula 1 Formula 3
    Feb 20, 2005
    1,525
    I'm just trying to figure out on what laps will the Ferrari engines give up on ?
    I'm gonna guess before lap 15 or is that wishful thinking?
