2022 F1 Launch dates and car reveals | Page 6 | FerrariChat
Discussion in 'F1' started by jgonzalesm6, Jan 14, 2022.
  1. trumpet77
    trumpet77 Formula 3
    Jun 13, 2011
    2,181
    Great Neck, NY
    Robert Nixon
    I can't tell if those are gills on top of the side pods or just some stripes
    ingegnere likes this.
  2. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,123
    ESP
    Bas
    I think they're stripes...
    trumpet77 and ingegnere like this.
  3. ingegnere
    ingegnere F1 Veteran
    5,567
    Montreal
    I thought the same also because the area allowed by the rules for such openings I believe is much more limited.
    In any car, hasn’t been mentioned by the Twitter experts:
    trumpet77, Bas and crinoid like this.
  4. ingegnere
    5,567
    Montreal
  5. Bas
    Mar 24, 2008
    43,123
    ESP
    Bas
    If the gills are real, isn't it a pretty bad way to get rid of heat (aerodynamically speaking).
  6. jgonzalesm6
    jgonzalesm6 Two Time F1 World Champ
    24,850
    Corpus Christi, Tx.
    Joe R Gonzales
    Cooling louvers were used in LMP1(Audi) back in the day.......then they did away with them. I'm assuming the reason why they did away with them was for aerodynamics......for better airflow over the surface as opposed to a "choppy" airflow over the surface.
  7. jgonzalesm6
    24,850
    Corpus Christi, Tx.
    Joe R Gonzales
    yep
    ingegnere and Bas like this.
  8. ingegnere
    5,567
    Montreal
    I can only guess they wanted to avoid exiting the cooling air at the back and so maintain flow energy around the trailing edge of the floor and the beam wing. If they got their design right, the “choppy” air will be funnelled between the beam wing and the main plane of the rear wing.
    This doesn’t change the fact that turning the cooling air through and out the rads through two basically 90 degree bends is not good for drag and neither is the flow out of the louvers.
    Maybe that’s just their hot-day or low-speed circuit configuration. Or they expect to make up the losses using their drivers’ talents. ;)
    Bas likes this.
  9. absostone
    absostone F1 World Champ
    10,239
    The front wings look like a snow plow.
    ingegnere and ricksb like this.
  10. jgonzalesm6
    24,850
    Corpus Christi, Tx.
    Joe R Gonzales
    I saw a top view comparison of the VF-22 vs the AMR22.
    The VF-22 follows the coke bottle body style.
    The AMR22 does not....it has a very wide body before the rear axles.
    Bas likes this.
  11. slm
    slm F1 Rookie
    4,126
    Near Lambeau field
    Steve M
    Ultimate combover
    Ferrari 308 GTB likes this.
  12. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,883
    Cooling louvers look like a messy solution, but they weren´t using them until now just because they were banned, so I guess they work. The good thing is that they can close them when not needed.
  13. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,379
    Cheshire
    I don’t buy the cooling idea. Surely they should be looking to maximise airflow to the rear end via the slimmest possible bodywork? I expect all these cars to look very different when they appear on track…
    Bas likes this.
  14. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Good call! That's gonna stick lol
  15. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    That interpretation of the rear wing suggests the design of the mule is not as cookie-cutter as we've been led to believe.
    Bas likes this.
  16. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Nailed it! (as have so many others lol)
    Bas likes this.
  17. ingegnere
    5,567
    Montreal
    They were used in the past but not like this, at least not since the Toleman of 1985:
    Also, if they do close the louvres off and force the air to the back, with the rads pretty much laid horizontal as expected, that’s quite the tortuous path for the air flow. Not sure they’ll close out the louvres.
    This solution in fact has almost no opening at the back—so very tight—but the air reaching the rear of the car may be quite disturbed from the air exiting the gills. The other advantage this solution has is that of a relatively flat topped sidepod. So, unlike with a downward tapered sidepod, the air is not accelerated over the top and so reduces lift.
    This may be an early development to get through the first week’s testing but redoing a sidepod design with associated cooling system mods sounds like a major undertaking.
    jpalmito, DF1 and subirg like this.
  18. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,883
    They used them in the 2000s until banned in 2009 IIRC.
  19. ingegnere
    5,567
    Montreal
    Didn’t remember them on the tops of the sidepods like that but still not to the extent of what AM showed yesterday. Great pic, BTW! Also seeing the S-duct.
    There’s also this example. Comes pretty close:
  20. jgonzalesm6
    24,850
    Corpus Christi, Tx.
    Joe R Gonzales
    2022 McLaren Racing Team Launch
    ktu and Bas like this.
  21. 20000rpm
    20000rpm Karting
    Jan 3, 2022
    226
    Any specific reason why were they banned? IIRC, it's primary function was to cool the engine and other internal components. Or am I missing something.
  22. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,883
    Meh, things that FIA does. The idea was having simpler aero because things were going out of control (take a look at the 2008 BMW Sauber), so basically they mandated minimal radius of curvature in the bodywork, exclusion boxes and so on. The result was the ugliest cars in decades.
    20000rpm likes this.
  23. jgonzalesm6
    24,850
    Corpus Christi, Tx.
    Joe R Gonzales
  24. itschris
    itschris Formula 3
    Sep 15, 2011
    1,551
    Florida
    Chris
    Okay... these cars look great. I can't wait to see final versions of the packages and the new liveries.
    Bas likes this.
  25. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    8,095
    Tropical
    Ex Mercedes Aero Guy...
