2023 Australian GP: Post Race Analysis | Page 2 | FerrariChat
Discussion in 'F1' started by SS454, Apr 2, 2023.
  1. SS454
    SS454 Formula 3
    Oct 28, 2021
    2,272
    Chris S
    There is no question the Red Bull is the fastest car. I suspect Verstappen saved up a lot of battery while he waited for DRS to be enabled so he could attack right away. Alonso was doing his thing in 3rd running 1:24.644 on Lap 11, then 1:23.321 on Lap 12 in clean air, too far to use DRS. Gasly in the much slower Alpine did a 1:23.647 on Lap 12 with no DRS, and George Russell ran a 1:23.169 trying to pass Gasly but failed. So the 1.1 seconds faster was circumstantial to that lap, but is relative to the RBR/Max being a significantly faster car. There is no logical reason for LH to slow to a 1:24.616 while letting off the throttle extremely early on both straights. He lost 1 full second in just the lift early and brake early stages going into Turn 9, and Turn 11. The very next lap he was running normal pace.
    Verstappen on Lap 12 hit 303 kph with a slight tow behind LH, no DRS. Lap 12 he hit 325 kph with the aid of a tow up to around 320 kph. That gives a DRS of about 22 kph, give or take. We don't know how much battery was used between those laps. Safe to say Max did not use overtake modes on lap 11 when he was specifically waiting for lap 12, where he likely did use overtake.
    Max never hit 341 kph in the race. That was Perez. As I showed above, Max hit a Vmax of 325 kph while Hamilton did 298 before lifting early. A significant difference, but Lewis typically was hitting a bit over 300 kph. Alonso was mostly in clean air, but maybe a very slight tow behind LH, was hitting roughly the same speeds. Max in clean air with zero tow was doing maybe 1-2 kph faster, but we can assume engine was turned down.
    The Red Bull is quite a lot faster than everyone, and they have a significant top speed advantage. No denying it. It's not much different than a lot of 2022, just perhaps more this year. It's not all DRS though, they aren't 2 seconds a lap faster than everyone, and they don't have a 30+ kph advantage over everyone either. The media is not correct with their halfassed reporting. Isn't it weird everyone is focused on Max's pass on Lewis on Lap 12, talking about the insane speed difference, but nobody is looking at the fact LH slowed down and made the speed difference far more exaggerated?
    Bas and werewolf like this.
  2. ago car nut
    ago car nut F1 Veteran
    5,535
    Madison Ohio
    David A.
    When Ham and Mercedes was unbeatable, there was less concern from the media. The media sucks in every thing!!
  3. DF1
    DF1 Three Time F1 World Champ
    Good luck watching a race without --'the media'
  4. ago car nut
    5,535
    Madison Ohio
    David A.
    Media without bias is what is needed.
    Bas likes this.
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,928
    Richmond
    Pete
    Ferrari are, so far, unequivocally worse now than they were under Binotto. This season is looking awful, drivers trying to wring things out of the car that aren't there, mediocre to poor strategy, and still suspect reliability. 3 races in and a disaster so far.
    werewolf likes this.
  6. DF1
    Bias is inherent in most life items. If SKY is annoying I turn it down. Easy.
  7. trumpet77
    trumpet77 Formula 3
    Jun 13, 2011
    2,181
    Great Neck, NY
    Robert Nixon
    If everyone can work on their car to the same degree (tires, etc) under a red flag, why so much complaining? Either way, it's the luck of the draw with safety cars, VSC, and red flags. Sometimes it's to your benefit, and sometimes not.
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    And Binotto got a golden handshake for delivering garbage
