206 SP
Discussion in '206/246' started by omgjon, Jan 13, 2016.
  1. Check out the video promo for our FerrariChat Miami event coming up end of October! https://www.ferrarichat.com/forum/threads/new-ferrarichat-miami-video.580070/
  1. omgjon
    omgjon F1 Rookie
    Rossa Subscribed Owner
    Feb 13, 2005
    3,074
    Rancho Santa Fe, CA
    It's at the paint shop in primer with paint probably 2 weeks out. Anxious to get it back.
  2. omgjon
    omgjon F1 Rookie
    Feb 13, 2005
    3,074
    Rancho Santa Fe, CA
    Michael Call, mcimino and dflett like this.
  3. omgjon
    omgjon F1 Rookie
    Feb 13, 2005
    3,074
    Rancho Santa Fe, CA
  4. Ferraripilot
    Ferraripilot F1 World Champ
    Project Master Owner
    May 10, 2006
    15,977
    Atlanta
    It's man
    Very nice there Jon. Love the gearshifts, superb
  5. tx246
    tx246 F1 Veteran
    Nov 4, 2003
    5,476
    Texas
    Shawn
    Jon,
    This project is going to be awesome to watch it come together. Your attention to detail is amazing as always. The gear shifts look superb. Since you used a real one as a pattern, is the shifter in the car you started with using the same pattern and connectors?
    Shawn
  6. omgjon
    omgjon F1 Rookie
    Feb 13, 2005
    3,074
    Rancho Santa Fe, CA
    Same shift pattern but I'm going to have to figure out the connections.
  7. Tired of seeing this ad? Upgrade now
  8. mikemal7
    mikemal7 Rookie
    Nov 4, 2009
    43
    I have two original wheels for the car
  9. jjeffries
    jjeffries Karting
    Sep 4, 2012
    132
    Connecticut
    John Jeffries
    This one looks not to have been painted at SpeedZone; as a race car, were you looking for less perfection than a street 246 repaint? Best regards, John in CT
  10. cnpapa24
    cnpapa24 F1 Rookie
    2,720
    NOLA
    Chris
    Lemacc likes this.
  11. Tired of seeing this ad? Upgrade now
  12. 4CamGT
    4CamGT Formula 3
    1,913
    Southern California
    Freeman Thomas
  13. Ferraripilot
    May 10, 2006
    15,977
    Atlanta
    It's man
    You find your right side upright Jon? You may end up having to have a run of them made if your set on 206 components. I found lots of 246 uprights.....
  14. omgjon
    omgjon F1 Rookie
    Feb 13, 2005
    3,074
    Rancho Santa Fe, CA
    My machinist is making one, so all is good.
  15. jerion
    jerion Rookie
    Jan 26, 2007
    49
    Plymouth, MI
    Jeff Erion
    Jon, This is also one of my favorite Ferrari designs. You are doing a magnificent job. Keep it up.
  16. BigTex
    BigTex Six Time F1 World Champ
    Dec 6, 2002
    69,056
    Houston, Texas
    Bubba
    Beautiful....
  17. Jon Hansen
    Jon Hansen Formula Junior
    470
    Grand Rapids, MI
    Jon Hansen
    Beautiful!
    What will you be doing to stop/minimize the inevitable up-dents in the aluminum body that are caused by stones coming off the tires at high speed?
    Applying several strategically placed coats of Wurth undercoating, or something else?
    I made some thin nylon liners for a Ruf 930 TT with aluminum fenders that were having that issue, and it worked really great. They were very lightweight, removable, and good up to at least 235mph...
  18. omgjon
    omgjon F1 Rookie
    Feb 13, 2005
    3,074
    Rancho Santa Fe, CA
    I will for sure have to address the issue, possibly rubber glued to inside?
  19. mcimino
    mcimino Formula 3
    1,613
    Long Island, NY
    omg wow!!!
  20. Jon Hansen
    470
    Grand Rapids, MI
    Jon Hansen
    Anything you do is going to add a little weight and involve some labor.
    Rubber sheeting sounds like it could work. Those panels are pretty curvy, so that approach would involve patterns, pieces, joints, and gluing upside down, etc... If you can still flip the car on a rotisserie, it would help make that job easier as you could roll out the glue and bubbles under the rubber, and maybe place some weight on it here and there as the glue dried, etc..
    Spraying several thick coats of the same aqueous Wurth undercoating you are using on the aluminum Dino gas tanks would also work well and be easier. (Mask and spray on the lift, or invert on a rotisserie). I think it is available in Black, Beige (gas tanks) and Grey. I don’t think you have to worry about adhesion based on how hard it came off your RSR donor cars. :)
    Either way, I’m certain you will do a great job.
  21. camchain
    camchain Formula Junior
    542
    Denver
    Ron Hetherington
    Do you have more photos of the Speedster? ;) Just kidding of course. Thanks for directing me to this thread omgjon. Fantastic project. Cheers.
  22. Ney
    Ney F1 Rookie
    4,147
    neoprene fabric can be rubber cemented in. It works well in different thickness and is reasonably easy to remove.....
  23. terry61
    terry61 Rookie
    May 17, 2011
    28
    Just saw this thread. Spectacular project!!
    I have a 2.0 Dino motor and would like to dry sump. What dry sump pump did you use? It's not evident in the photos.
  24. swift53
    swift53 F1 Rookie
    4,088
    E.S.
    Alberto
    I would 'choppergun' a bit of fibreglass, light and strong. Easy to apply.
    Regards, Alberto
