News
246 carb microswitch
Discussion in '206/246' started by Paul Root, Mar 4, 2019.
  1. Paul Root
    Paul Root Rookie
    Nov 18, 2018
    13
    Paul Root
  2. racerboy9
    racerboy9 Formula 3
    1,822
    Do you need just the switch or the bracket too?
  3. tx246
    tx246 F1 Veteran
    Rossa Subscribed Owner
    Nov 4, 2003
    5,534
    Texas
    Shawn
    Wow....
    Someone want this?
    The magical item I have always looked for on a US car, especially when claimed it was original.
    These are not common, but awesome to have!!!!
    Shawn
  4. absostone
    absostone F1 Rookie
    4,255
    Fchat
    pretty sure I saw one of those in a box of stuff for my GT4
  5. Paul Root
    Paul Root Rookie
    Nov 18, 2018
    13
    Paul Root
    Switch and Bracket
  6. Paul Root
    Paul Root Rookie
    Nov 18, 2018
    13
    Paul Root
    Im interested if you do
  7. absostone
    absostone F1 Rookie
    4,255
    Fchat
    is the switch for high idle at warm up? then why the thermos spring at the cross over?
  8. racerboy9
    racerboy9 Formula 3
    1,822
  9. DinoLasse
    DinoLasse Formula Junior
    525
    Sweden
    Lars
    No, the disc with the thermal spring mounted on the valve cover takes care of increasing the idle speed.
    The microswitch is activating an electronic module called the Anti-hop device, which in turn retards the ignition timing at idle. For emission control reasons.
  10. absostone
    absostone F1 Rookie
    4,255
    Fchat
    What I thought about emissions. The Gt4 has the spring on the crossover pipe if the intake manifold controlled by coolant temp
  11. Paul Root
    Paul Root Rookie
    Nov 18, 2018
    13
    Paul Root
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    8,922
    CHNDLR
    Scott
    What price do these sell at?
    Thank you
