246 Valve Cover Finish | FerrariChat
Discussion in '206/246' started by Ducati348, Mar 16, 2022.
Tags:
  1. Ducati348
    Ducati348 Karting
    May 15, 2009
    76
    Dallas, Texas
    Alex Scroppo
    I glass bead blasted my aluminum valve covers on my E series Dino and was wondering what others used to protect the beautiful finish? I read that some people used matte rattle can clear paint. In the attached photograph, I used some clear matte paint that was not high temperature rated. Do you think this be a problem?
  3. V12addict
    V12addict Formula Junior
    Jan 2, 2004
    293
    I would definitly strip and re coat with clear high temp clear. Both Dupli-color and VHT hace excellent high temp clear coats you can use.
  4. daviekj
    daviekj Formula Junior
    451
    First photo below is from 2008, a few months after I blasted the cam covers gently with used glass beads. The only protection was a squirt of WD40.
    Second photo below is from last year 2021. Pretty much same clean appearance. There has been no further blasting/conditioning between, other than a wipe over with break cleaner and re application of WD40 after valve shim servicing, when inevitably oil finger prints get on them.
    My suggestion is either leave as is, or follow the above.
  5. racerboy9
    racerboy9 Formula 3
    2,371
    I used mag wheel cleaner on mine and rubbed with a very used scotchbrite pad. Looked just like the NOS cover I have.
  6. vrooom
    vrooom Formula Junior
    442
    your engine compartment looks great !
  8. Ducati348
    Ducati348 Karting
    May 15, 2009
    76
    Dallas, Texas
    Alex Scroppo
    Thanks for the quick and detailed responses.
    Alex
