246GT Cooling Fan Removal | FerrariChat
Discussion in '206/246' started by Fezzaphil, Aug 14, 2006.
  1. Fezzaphil
    Fezzaphil Formula Junior
    Sep 14, 2004
    370
    Philip
    Hi,
    I want to remove and replace one of the cooling fans and motors on the Dino. Access is proving a little tricky and I really don't want to have remove the radiator. Is there a way or a knack of getting it out without pulling the car to bits?
    All help appreciated!
    thanks,
    Philip
  2. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Fezzaphil, I wish we could but I don't believe its possible. You will have to remove both air conditioning condensor and radiator. I thought I could remove the grill to access but just ran into bodywork, you will have to do it the hard way unless someone has a magical fix.
  3. Fezzaphil
    Sep 14, 2004
    370
    Philip
    thanks Gary, i too have tried to remove the grill - heres hoping someone knows a magic fix!
  4. 246gts
    246gts Karting
    Jan 10, 2005
    134
    cheshire, uk
    On my car it is possible to take out the grille by undoing the two side screws and the top screw in middle, gently pull forwards and out one side of the grille and then once one end is free you can pull the grille slightly sideways so that the rest of the grille comes out through the wider centre section of the grille aperture. I have done this many times and despite the shaking hands as I am afraid of scratching the paintwork on the grille surround it seems to work.
    Once the grille is out the fans are easy to get to, there is an allen key headed grub screw which holds the fan onto the flat of the spindle, take care when pushing the fan off the spindle that you dont bang it into the radiator.
    Good luck
    Dave
  5. celestialcoop
    celestialcoop Formula Junior
    715
    Coop
    Try these 3 threads that prompted some great clues & cues on cooling system issues from folks who've been there...done that! (I'm new to this posting process & haven't figured out how to properly refer to a thread, so I'll give you this much; you'll have to get there however you can!)
    racerboy9, 02-22-2006 07:33 PM, "Dino Fan Motors"
    dm_n_stuff, 08-14-2005 07:56 AM, "Dino Cooling Fans - repair/replace"
    premieram, 06-15-2005 06:13 PM, "Dino Cooling Issues"
    This info is priceless.
    I plan to put it to good use very soon. 'hope it helps you, too.
    Cheers...
  6. celestialcoop
    715
    Coop
  7. Fezzaphil
    Sep 14, 2004
    370
    Philip
    GUYS,
    thanks will explore these options tomorrow, really appreciate!
    Phil
  8. dm_n_stuff
    Dec 10, 2003
    43,746
    26.806311,-81.755805
    Dave M.
    Not easy, but do-able.
    I'd like to add, a lot easier to do in a non-a/c car.
    DM
  9. Fezzaphil
    Sep 14, 2004
    370
    Philip
    I'll keep trying, thanks again.
    BTW it's a Euro car with no aircon
