246GT Dino Clutch / Flywheel questions | FerrariChat
Discussion in '206/246' started by Toy Ferrari, Aug 25, 2016.
  1. Toy Ferrari
    Toy Ferrari Rookie
    Jun 30, 2016
    7
    Appleton WI
    Craig Nelson
    #1 Toy Ferrari, Aug 25, 2016
    Our shop is building a 1973 246GT Dino and and chassis number is beyond 2131. We have a clutch / flywheel question. I have attached pics of what we currently have.
    The flywheel is said to be original to the car. We resurfaced the flywheel and balanced it to the engine. We then ordered a new clutch disc and clutch cover from the major parts sources. Unfortunately, we don't have the original clutch cover for reference.
    The replacement disc is just fine. However, the replacement clutch cover will not work with the flywheel and apparently is the only option for this engine.
    Is it possible that are two radically different versions of the clutch cover/flywheel combo?
  2. dm_n_stuff
    #2 dm_n_stuff, Aug 25, 2016
    Parts books have two different numbers for this part.
    after 2131 500828A
    up to 2131 500643
    HOWEVER, Tom Vail's site shows these as interchangeable.
    Is this what you're looking for? I'm just working from the image in the parts book, which does not look like your part.
    D
  3. TTR
    TTR F1 Veteran
    5,795
    Riverside, CA
    Timo
    #3 TTR, Aug 25, 2016
    I've dealt with similar issue on more than one 365GTB/4s and just looking at your photo, I'd say your problem could be a result of multiple contributors. I don't have access to my files for couple of days, but is your clutch pressure plate (=cover?) "standard" 9"-9 1/2" Borg & Beck item (currently manufactured by AP) ?
    And your problem is not getting enough pressure plate diaphragm movement/travel to release the friction plate ?
    If answers to all above are affirmative, your first step should be to replace the flywheel, which appears to have been, one time or another, subjected to what could be considered as backyard or roadside mechanics attempt to get "extended" life out of it and/or the pressure plate.
  4. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    #4 cls, Jul 4, 2017
    I am having the same problem. Every site I have seen lists the clutch pressure plate as 246 all, but my '72 takes a pressure plate like shown in the first photo - there are three bolt holes in the pressure plate. The kit I got from Superformance has the same pressure plate as in photo 2 of the OP. Anyone know where to get the correct pressure plate?
    Here's what I have / need:
  5. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    #5 cls, Jul 4, 2017
  6. dm_n_stuff
  7. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Is that where you bought the pressure plate in your previous photo? That looks like the correct part.
  8. dm_n_stuff
    Chris.
    Honestly, I don't recall. I have all the records somewhere, and I could dig them out, but I think a quick call there would get you the answer you need.
    D
  9. pshoejberg
    pshoejberg Formula 3
    1,796
    Denmark
    Peter H
    What seems to be the problem with that pressure plate from SF?
  10. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    #10 cls, Jul 5, 2017
    3 studs in the flywheel go through the original pressure plate. You can see them in the 1st pic of the flywheel by the OP and in the pressure plate pic by dm_n_stuff.
    I'm thinking the flywheel studs have to be removed or the flywheel needs to be updated to use the Superformance pressure plate. Here's a flywheel and stud set (this will not work with any of the available pressure plates that I have been able to find:
  11. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    The 3 studs should be removed by pressing from the back of the flywheel, these are not used with the new sf pressure plate.
    I went back and forth with sf on this before they realized I had these locating studs on my early car.
    Note that the smaller locating dowels should be kept to locate the cover on the flywheel.
  12. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Thanks,
    That's what I was suspecting.
  13. pshoejberg
    1,796
    Denmark
    Peter H
    #13 pshoejberg, Jul 5, 2017
    Thanks Andrew for the heads up. I fitted the SF pressure plate to my early L series with no issues. But that might then be due to the dowels being removed already or slight differences betweens models? See attached pictures of old versus new P-plate.
    Best Peter
  14. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Your flywheel is different: it doesn't have the 3 long studs. I have no idea which cars have the studs and which do not. Mine is 04860 and has the flywheel studs. I had original flywheel, clutch and pressure plate. The simple solution seems to be to remove the studs and then use the "246 All" pressure plate.
  15. pshoejberg
    1,796
    Denmark
    Peter H
    I too would go for that solution. Your flywheel will be lighter as well ...-:)
  16. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Peter, I think yours was already replaced and the studs already removed. Saved some effort :)
  17. pshoejberg
    1,796
    Denmark
    Peter H
    You are most likely right. I observed no significant wear on the old disk, but decided to go all new when I noticed the coloration of the flywheel.
  18. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Took the 3 long studs out when resurfacing, and the new pressure plate bolted right up.
  19. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    great news!
  20. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Chris
    Thanks for the help.
    As an aside (if anyone is doing the clutch in the car) there's one nut on the bottom of the bell housing that requires slightly lifting the engine to access. I already had my muffler removed so it was pretty easy to get the 1" lift that I needed.
