250 California Spyders | Page 10 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by Robertb, Sep 15, 2004.
  1. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    First six owners of 1497 GT were in Italy between 14 November 1959 and 17 June 1967.
    Marcel Massini
  2. AUSWOODS
    AUSWOODS Rookie
    May 2, 2019
    21
    Richard Woods
    Hi,
    I am having a very esoteric debate. What is the factory correct thickness of the body on the Competitzione 2.2mm or 1.6mm - or are we completely wrong ??
  3. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,674
    Pittsburgh, PA
    Matt F
    I think you’re looking for precision where it doesn’t exist.
    Even if Pininfarina started with nominal 2.0mm sheet metal, they wouldn’t have been exactly that.
    And after those panels had been beaten into shape, they would be somewhat thinner.
    So a finished car isn’t going to have a uniform body thickness.
    Matt
    AUSWOODS likes this.
  4. AUSWOODS
    AUSWOODS Rookie
    May 2, 2019
    21
    Richard Woods
    Think your right and good advice. Did find this post after some nifty searching
    Wow. A technical question on a topic I actually know something about.
    The alloys of aluminum have varied, and it's almost impossible to say exactly what sort of sheet was originally used.
    Having said that, it's pretty clear that the thickness of aluminum sheet used on most racing models was around 1mm or 0.040". When repair panels are made, they are generally made with 3003 sheet and 1100 welding rod.
    The H numbers quoted above indicate the heat treat, and are pretty irrelevent for this use, as the metal will almost always be annealed to dead soft (often many times over) in order to be shaped. The "flexibility" and maleability" you refer to, Horsefly, is this softness achieved by annealing. 3003 can be annealed over and over again, and work hardens as it is shaped.
    Smiles likes this.
  5. Ed Niles
    Ed Niles Formula 3
    Honorary
    Sep 7, 2004
    2,493
    West Hills, CA
    Edwin K. Niles
    Is that with or without the bondo?
    djaffrey, pilotoCS and AUSWOODS like this.
  6. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    Have a look from second 5 on.
  7. RichieR1111
    RichieR1111 Rookie
    Jun 26, 2018
    8
    Richie Rich
    colombo2cam likes this.
  8. NunoRosso
    NunoRosso Formula Junior
    Dec 10, 2007
    254
    Portugal
    Nuno
    2015GT. In my opinion, this is the best California.
  9. TTR
    TTR F1 Veteran
    5,898
    Riverside, CA
    Timo
    mechaniker likes this.
  10. kare
    kare F1 Rookie
    Nov 11, 2003
    3,847
    1615GT...?
  11. TTR
    TTR F1 Veteran
    5,898
    Riverside, CA
    Timo
    Call me old school, but I was taught that gentlemen do not (publicly) reveal identities of their private affairs/encounters.
  12. kare
    kare F1 Rookie
    Nov 11, 2003
    3,847
    Hrmph, I've already used to be the "you" when they say "Ladies and gentlemen and you!".
    TTR likes this.
  13. TTR
    TTR F1 Veteran
    5,898
    Riverside, CA
    Timo
    :eek::)
  14. TTR
    TTR F1 Veteran
    5,898
    Riverside, CA
    Timo
  15. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,326
    Austin, Texas
    David Castelhano
    franmort, ivo73, Edward 96GTS and 3 others like this.
  16. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  17. GHG
    GHG Formula 3
    Jan 29, 2008
    2,134
  18. Edward 96GTS
    Edward 96GTS F1 World Champ
    BANNED Silver Subscribed
    Nov 1, 2003
    11,097
    it wears white well.
    Bertocchi and readplays like this.
  19. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    franmort, FF4X4, ivo73 and 2 others like this.
