250 Gte distributor question | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by christc, Apr 13, 2020.
  1. christc
    christc Formula Junior
    Mar 3, 2013
    444
    Germany
    Hi all,
    happy easter to you.
    I dismounted one 250 Gte distributor today to check for wear and found two different length of springs in the weights. See picture. Is this normal?
    Christopher
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,929
    romano schwabel
    that is normal
  3. christc
    Mar 3, 2013
    444
    Germany
    Thanks! As always competent and fast answer!
  4. christc
    Mar 3, 2013
    444
    Germany
  5. christc
    Mar 3, 2013
    444
    Germany
    Just to add to my post above: This diagram comes from the Service and Maintenance handbook but it irritates us as it does not corresbond with the manual data (see below)?
  6. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    this diagram is rpm distributor on a bench or crankshaft?
    where do you have this diagram from?
  7. christc
    Mar 3, 2013
    444
    Germany
    It says Motor rpm, nothing more. It comes from a manual for the 250 Gte called Uso e Manutenzione. It is in the chapter Distributor.
    What I am looking for is the right data for advance curve for the S85A of the Gte for setting/ checking advance on a distributor tester. Thanks a lot.
  8. christc
    Mar 3, 2013
    444
    Germany
    Thanks, have needed info thanks to GTO. They informed me that the curve is identical to the 330Gt and provided attached table.
    Christopher
    turbo-joe likes this.
  9. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    great service from GTO :)
    but I wonder a little: the centrifugal advance normaly start at about 1200 - 1400 rpm, and here it says from 600 rpm?
    also this is only the advance, not the static timing
  10. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,838
    The chart from GTO is for DISTRIBUTOR rpm.
    christc likes this.
  11. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    a ok
    have read : on the bench
    sorry, not reading before
  12. christc
    Mar 3, 2013
    444
    Germany
    Yes. Distributor timing as I needed it. And as always very good service from GTO’s. Friendly, helpful and competent.
