250 GTO wheels | Page 3 | FerrariChat
250 GTO wheels
Discussion in 'Vintage (thru 365 GTC4)' started by ag512bbi, Dec 19, 2019.
  1. Marcel Massini
    Honorary
    Mar 2, 2005
    22,929
    Borrani catalog from a few years ago.
    Marcel Massini
    of2worlds and miurasv like this.
  2. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Does anyone know the differences between the 15 x 6.0 RW 3690 and the RW 3711, and also the 15 x 6.50 RW 3801 and the RW 3715?
  3. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,553
    So. Cal
    Armen
    The accuracy is very inaccurate. Maybe that'll fix it.
  4. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,300
    my preference would be
    7.5 x 15 front with 215/70x15 michelin xwx tires
    8 x 15 rear with 225/70x15
    for a muscular look and use 3 eared knockoffs.
    pm sent
  5. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,441
    Will Tomkins
    If you haven't done so already, please check that your spinners have enough thread engagement, ideally 4 turns before tightening.
    The Daytona hubs were designed to be used with the Cromodora wheels which have a different length centre to those used on all the Borranis. The spinners supplied with the Cromodoras only go on a turn or two before tightening, which isn't safe. Special spinners were produced with an extended thread to be used for the conversion.
    If you have the wrong ones you can probably get the correct ones from the US Borrani agents, but if not we can supply them.
    email [email protected] website www.turrinowheels.com
    of2worlds, miurasv and turbo-joe like this.
  6. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    Here's an example of what Mr. Tomkins ("246tasman") is referring to, the one on left with shallower tread depth is (U.S.-delivery, octagon) nut for center mount Cromodoras on 365 GTB/4s, the one on right with deeper thread depth is for Borranis on same application.
    Photo copyright of TTR (me)
    To fix “very inaccurate"(?) may require more than just change in tire diameter/size.
    turbo-joe, 375+ and miurasv like this.
  7. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,553
    So. Cal
    Armen
    Let me Clarify what I said/meant: My Speedo is very inaccurate. AT LEAST 10mph slower than it shows. I do feel that's a Speedo problem though (and not a bad thing to have compared to the other way of: Faster than it shows)
  8. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    Do I understand your clarification correctly, the cars actual speed is “AT LEAST 10mph slower” than speedometer indicates ?
    If yes and tires are close to OEM diameter/size, your speedometer and/or its drive pinion may require calibration/service.
  9. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    IIRC from the Autocar magazine road test of the Daytona, the speedo read about 33mph at a true 30mph and 160mph at a true 150mph.
  10. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    "IIRC from the Autocar magazine road test of the Daytona, the speedo read about 33mph at a true 30mph and 160mph at a true 150mph."
    Most cars manufactured in past 50 or years tend to have a built-/designed-in +/-2 MPH "over-read" (i.e. indicating more than actual speed), but anything over or under 5 MPH is usually an tell-tale of inaccurate calibration.
    OTOH, given Ferraris traditional tendencies to over-state performance stats, +/- 10 MPH "over-read" shouldn't surprise anyone. :rolleyes:
  11. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Does the Daytona speedo run off the transmission or one of the wheels?
  12. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    Transaxle, driven off the gear*-nut in front of the upper, i.e. output/pinion (to final drive) shaft.
    *Dependent on final drive ratio (?).
    375+ likes this.
  13. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Thank you.
  14. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,553
    So. Cal
    Armen
    Yes, I think your correct. It probably needs calibration. Just dont feel like having it out of service for a bit.
    I really enjoy driving the car in this "cooler" weather
  15. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Are there 2 types of wide 15 x 7.5 inch RW 3808 rims?
    I ask because 250 GTO 3869 has RW 3808 rims that do NOT have the raised circular rim inserts that the spokes insert into, whereas 250 GTO 4153 HAS the raised circular inserts that the spokes are inserted into.
  16. JP365
    JP365 Formula 3
    Mar 8, 2007
    1,346
    Chicago
    John F
    I have a 365 GT 2+2 and was wondering if the deeper knock off be used on both mags and wires safely?
  17. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    I've never tried deeper reach center mount nuts ("knock-offs") on Cromodora hubs, so can't say for sure whether they would work or perhaps bottom out before tightening.
  18. JP365
    JP365 Formula 3
    Mar 8, 2007
    1,346
    Chicago
    John F
    Thanks for the response. I’m in the process of getting a set of cromodoras to put on my car when I have the wires rebuilt and was hoping to use the same knock-offs for both sets of wheels.
  19. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    It might be worth to have proper depth set of "knock off" for each hub design or at least measure/test deep reach nuts carefully to make make sure they don't bottom out too early.
  20. JP365
    JP365 Formula 3
    Mar 8, 2007
    1,346
    Chicago
    John F
    Thanks for the info. Trying to figure out what I need to do to have both types of wheels.
  21. Philip Parnagian
    Dec 3, 2019
    6
    Philip Parnagian
    How would a 225/70x15 look on a rear 7.5x15 rim?
  22. Terra
    Terra F1 Rookie
    3,689
    The sidewalls of a 225/70/VR15 won't look stretched out nearly enough on a 7.5 x 15 wheel for the rear. A 9 x 15 Cromodora from a carbureted BB 512 is the perfect wheel to combine with a 225/70/VR15. Or a 9 x 15 Borrani with the proper offset.
    miurasv likes this.
  23. Philip Parnagian
    Dec 3, 2019
    6
    Philip Parnagian
    Ok , so I have (4) 7.5 X15 RW 4326 Borrani’s. When I get on the Borrani’s website they say stock rim is a 7.5 x 15 RW 4075.
    I’m confused if they are both 7.5 x15 why are they different numbers?
    Second if I have (4) 7.5 x 15 for my Daytona Conversion What tire size should I use front and back?
    I understand probably the best would be 7.5 front and 8 on back?
  24. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    What kind of Daytona Conversion do you have? Coupe to Spyder or 400i to Daytona body? See here and scroll down.
  25. Marcel Massini
    Honorary
    Mar 2, 2005
    22,929
    See list in post #51.
    RW 4326 are for a 400 Automatic.
    RW 4075 is for a 365 GT 2+2, 365 GTC4 and 365 GT4 2+2.
    A Daytona would have RW 4300/RW 4301.
    Marcel Massini
