250 HP Mondial, Cheap Ferrari,, etc. | Page 17 | FerrariChat
Discussion in 'Mondial' started by 350HPMondial, May 30, 2014.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Hey Steve,
    Welcome to my garage
    Glad your reading my project. (smile)
    the Tool your referring to, was/is recommended for 308QV heads. My heads do not require that tool.
    and, bravo, you are correct , you have to add a torque amount to the torque wrench dial display, or subtract the additional length from the Automatic Torque Wrench Detent. ;-)
    ronfrohock likes this.
  2. 350HPMondial
    5,325
    Edwardo
    hi all Ferrari friends,,
    my lucky day.
    I found a NOS, front windshield bottom trim.
    Thank you Redbay.
    yes,, it’s now on order.
    This,, I went to work in the garage.
    see,, sanding and primer, of lower windshield edge.
    Ready for trim.
    paulchua likes this.
  3. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,465
    Menlo Park, CA
    Paul Chua
    Keep up the great work!!!
    350HPMondial likes this.
  4. 350HPMondial
    5,325
    Edwardo
    ( whew)
    2 years of prep, 4 hours of masking,, followed by 3 hours of paint work.
    All painted now, window jambs, C pillars and roof.
    Roof to get “color sanded,” followed by a 2nd coat of PPG 95083 Ferrari Nero Image Unavailable, Please Login
  5. 350HPMondial
    5,325
    Edwardo
    And,,,, you know,,
    ,, while you are in there,,, ( extra work done…)
    Clean and lubricate both “ trunk - hatch opening solenoids.”
    spray interior of left rear panel in PPG Nero.,. ☺️
  6. 350HPMondial
    5,325
    Edwardo
    In an attempt to prevent any future, galvanic corrosion,, in the rear of the car, a 100% Zinc panel has been installed and grounded,, in the well for the tool roll.
  7. 350HPMondial
    5,325
    Edwardo
    Last fiberglass heat- shield & fiberglass trunk floor installed.
    why do the “boring” jobs seem to take the most time. (Done finally, ,, yes,,! )
    Ferrari friends,,
    thanks for following.
    rob likes this.
  8. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,668
    Argent/Brasil
    Guido
    Edwardo, great job until now. Just a question,..why not spray the car in one time instead of panels separatly ? Time you loose putting paper and plastic to protect the other panels.
  9. 350HPMondial
    5,325
    Edwardo
    #410 350HPMondial, Jan 13, 2023
    Great question,, Guido,
    First, I painted the front wings ( fenders) seperatly, in isolation, so I could paint their inside and their outside and the front frame rails with PPG products.
    Second reason,
    The volume of paint that I would need to spray and finish, before the first application is semi dry hindering a glassy finish, would overwhelm my little Craftsman Air Compressor and my little Summit 1.5 mm finish gun. I am also painting in my garage , it is not exactly surgically clean.
    Luckily, the new masking plastic film is so easy to work with,, thus, I can effectively isolate a single panel for a finish coat.
    As everyone in our Ferrari club knows, these cars are made of very low quality steel. Ferrari didn’t use any zinc protection until 1983 ish.
    Thus the paint job is for surface corrosion control.. also, it is a 10’ job,, lol,, ( aka, , looks good from 10’ away.) lol
    Last, for a high quality finish,, a complete, clear coat needs to be applied in a spray booth, prior to buffing.
    ( whew)
    thanks for following Ferrari friend.
    Edwardo
    theunissenguido likes this.
  10. 350HPMondial
    5,325
    Edwardo
    Hi Ferrari friends,
    please ,
    See Paint Products, in use for this project.
    Hope your Winter Projects are also progressing.
    Edwardo
  11. 350HPMondial
    5,325
    Edwardo
    85QVEuro likes this.
  12. 350HPMondial
    5,325
    Edwardo
  13. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    545
    NYC
    Joe
    Looking good - On the windshield install, did you use spacers at the bottom of the windshield to keep it up away from the body? If so, what size, how many and where did you place them?
    What adhesive did you use for the glass to the body? What other products did you use to hold the trim on and what product do you plan to use between the trim and the body? Thanks - this is a project that I will be getting to soon
  14. 350HPMondial
    5,325
    Edwardo
    #415 350HPMondial, Feb 16, 2023
    Hey Joe,
    My glass is a special piece from Mondial Z.
    Place your windshield in the car dry. This will tell you the thickness of the bottom spacer you need.
    I cut some heavy black polyurethane foam to the right size, then glued that in a few days before I Glued in the glass. Mine was close to 8 mm thick.
    Trim the spacer and the glue that squished out with a new razor blade. ( clue,, check on-line for some videos.). If you scratch or chip your paint,,? Touch up with SEM self etching primer. Use a mini paint brush to save masking and cleanup time. Use Acetone to clean up excess 3M Window Weld. Careful, you can wipe off your paint or bodywork.
    You will need;
    Dow Automotive 5504G glass primer.
    3M Window Weld 08609.
    3M “Red Devil” Extreme Duty Calking Gun.
    good luck Ferrari friend.
    p.s. Love the color of your car.
  15. 85QVEuro
    Jan 15, 2021
    545
    NYC
    Joe
    TY Ferrari friend - a few follow up questions on this:
    1. how many spacers? and were yours 8mm thick or 8mm tall?
    2. what bonding agent are you using to hold on the trim (or does it snap in place? - can't remember)
    3. Are you using any other sealer where the trim meets the body or where the trim meets the windshield (mine had something when I removed the windshield)
  16. 350HPMondial
    5,325
    Edwardo
    Hey Joe,
    1- I used one long spacer, as shown in the parts manual. I estimate mine was 10 mm tall by 8 mm thick. Trim and fill as needed so it is flat with the glass.
    2- sorry, I don’t know about the clips, as used on the 308.. for, my trim is an aftermarket Ford product. ( I couldn’t locate a factory trim, back in 2009, when I set the glass.) But, my bottom trim is factory and is glued on flat.
    3- for glass and trim, I have used only the 3M Window Weld product.
    ( smile)
    Hey now,
    I spent a lot of my career up in NYC,, lil cool up there,, ( today,, it is a balmy 62 *F ,,here in California) hope your winter project is going good Ferrari friend.
    Edwardo
  17. 85QVEuro
    Jan 15, 2021
    545
    NYC
    Joe
    Thank you for the additional details - BTW, it was 60* in NYC yesterday!
  18. 350HPMondial
    5,325
    Edwardo
    aaaaa ha ha (smile) finally kicked out the $600.00 to get my Fuel Distributor rebuilt. ( mine was only ,, 42 years old. .. ) More tuning to follow. ✨✨✨ Image Unavailable, Please Login
  19. 350HPMondial
    5,325
    Edwardo
  20. 350HPMondial
    5,325
    Edwardo
    rob, 85QVEuro and djs308 like this.
  21. jgoodman
    jgoodman F1 Rookie
    3,267
    Central PA
    Jay Goodman
  22. 350HPMondial
    5,325
    Edwardo
    Jay,,
    9 years,,??? Where has the time gone.
    ( ha ha, love the Gene Wilder clip. )
    Note; I’m also surprised, I have the patience.
  23. 350HPMondial
    5,325
    Edwardo
    see “Refinished,” front Mondial Grill.
    The paint is curing in my backyard.
    ( smile)
    Hey all you Ferrari fans.
    Thanks for following this Mondial 8 rebuild.
  24. 350HPMondial
    5,325
    Edwardo
    See refinished Grill Screws, Ferrari Part 14779612. (six are required, yes, I have spares.)
    These are “Chirao,” or light in color for light colored cars.
    Note; Image Unavailable, Please Login While shopping for parts, a few years back, these were as rare as hens teeth.
