250GT Compression | FerrariChat
250GT Compression
Discussion in 'Vintage (thru 365 GTC4)' started by Glassman, Jun 5, 2004.
  1. Glassman
    Glassman F1 World Champ
    What would fair-good-perfect Compression be on a 128D Engine?
    I'm going to check the compression tomorrow and was wondering what these numbers should be.
  2. Bryan
    Bryan Formula 3
    What's just as / more important in most people's minds is the deviation between cylinders. Should be no more than 15-20% between min and max.
    Typical numbers that you might get are 110-140 psi. Higher is OK, lower than 110-120 would be a concern, even the deviation was close.
