News
255/35/19 too wide for front ?
Discussion in '360/430' started by Manda racing, Jan 28, 2021.
  1. Manda racing
    Manda racing Formula 3
    1,141
    Bakersfield, Ca
    Mark
    Anybody run this size on a Scuderia rim?
    thanks.
    stock ride height
  3. BlacktopRacing
    BlacktopRacing Formula Junior
    Sep 18, 2016
    755
    Dale
    It won't fit. While you're only talking just over 3/4" wider, the overall tire diameter would be about an inch larger.
    Manda racing and Monteman like this.
  4. Manda racing
    1,141
    Bakersfield, Ca
    Mark
    Thanks-/I was just tempted by some good deals. I’ll pass.
  5. Manda racing
    1,141
    Bakersfield, Ca
    Mark
    What about
    235/40/19. Aspect ratio 40 instead of 35?
    goodyear F1’s.
  6. BlacktopRacing
    Sep 18, 2016
    755
    Dale
    It would still be taller and may not look right. The 40 is the size of the sidewall. It's called an aspect ratio, and means the sidewall is 40% of the width. Check out tirerack.com. They have information on how to properly upsize wheels and tires. Even though the tire you spec'd may fit the wheel, it may not fit the car.
    Manda racing likes this.
  8. KC360 FL
    KC360 FL Formula 3
    1,269
    Melbourne Florida
    KGC
    I've been running 235 - 35- 19" on the front of my car (2003 360). They are after market wheels but the offset is very little to the outside. The car is lowered, the fenders rolled and I do have some rub issues. Almost never an issue while driving only when turning into a upgraded entry like a steep drive or a large bump at speed. However it is only on the driver side and I can easily correct that with a coil spring adjustment. FWIW just wanted to pass the info along. I agree that the 255s would not work.
    sparetireless likes this.
  9. Manda racing
    1,141
    Bakersfield, Ca
    Mark
    It’s a set of take offs for $450 so that’s why I’m tempted especially since I run Nittos comp tire and had to drive over the grapevine last month in the snow.
  10. Mel Spillman
    Mel Spillman Formula Junior
    413
    Sugar Land, Tx
    I have 245/35/19 fronts using Novitec wheels and Novitec coil overs on my 360. I'm sure that without the Novitec shocks there would be rubbing.
  11. honda corse
    honda corse Karting
    Jul 20, 2011
    54
    Vancouver BC
    Mark
    I tried to run 255/35/19's Cup 2's but they could barely turn without rubbing the fender liner. My friend has a 430 Scud and runs 255's no problem, not sure if they have a fender liner in those cars. I ended up going 235/35/19 and it works great, no rubbing.
