Refurbishment of Wheel Wells | FerrariChat
Discussion in '308/328' started by Easyrider7467, Sep 7, 2009.
  1. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    #1 Easyrider7467, Sep 7, 2009
    Hello,
    I'm in the process of refinishing my wheel wells and although I've only completed the drivers side, I'm psyched to get some pics up to share the results thus far. The only thing I have yet to complete is the touch up of rock chips behind the rear tire on the body (see pic).
    Here is what I did....
    1. Removed wells.
    2. Remove rubber moulding, clean and hydrate with Wurths rubber care.
    3. Remove all the Dinol with mineral spirits, heavy duty scotch brite, rinse clean.
    4. On aluminum lower well; Feather-out the edges with sand paper caused by rock chips
    5. Scrub the outer shell of the wheel well and then wet sand the outer portion of the well leaving it smooth and clean. That which is visible from inside engine bay.
    6. clean screws, washers and bolts, spray with a textured black.
    7. Use Wurths Stone Guard, 2 light coats on inner wells.
    8. touch up lower rocker panel in front and behind tire.
    9. Install wheel wells and tire
    10. Rechromed lug bolts
    While the Wheel well was out I cleaned up the shock and others various parts.
    Thanks..
  2. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    Looks pretty nice! And it's much better than the orignial Dinol stuffs.
    I bought the Wurth Stone Guard too but have no gut to trip the Dinol and decided to leave everything alone for now.
  3. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,270
    Seattle Area
    Dave
    Beautiful work - labor of love!
  4. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
    Where did you get the stone guard? it looks great
  5. kafugelum308
    kafugelum308 Formula Junior
    Jun 6, 2003
    610
    Northwest
    M Bradley
    You can get it on Amazon - $15.99
  6. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    Scruffy wheel wells really show the age of a car. It's amazing how good the Wurth product makes them look. Awesome job!
  7. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    This is something I have not even considered doing? But based on this thread, its now on my "winter do list". Easy job to do and will be an immediate, noticable improvement. Great post! Joe
  8. MBFerrari
    MBFerrari F1 Veteran
    Jul 2, 2008
    6,057
    NoVA
    Matt B
    Looks great man! I will take a look at doing that this winter as well. Hey Pitts Pilot, do you guys even have Winter down there? LMAO!! :p
    MB
  9. PittsS2APilot
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    Man, a few years ago it was awful...it got all the way down in the 40's a couple of times. Would you believe I actually had to wear a long sleeve shirt one day driving the 308 so I could keep the windowns down? Geeesh...Talk about bad winter weather! :)
  10. MBFerrari
    Jul 2, 2008
    6,057
    NoVA
    Matt B
    Ha Ha. Reeeeal Funny. Although I will say our driving season in Northern VA is much better than Green Bay LOL!!!
  11. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Man, my car needs this sooo bad. I tried just scrubbing them down with Simple Green and a mild pressure wash. Looks absolutely no better than when I started.
    Looks like this will be my procedure.
  12. Easyrider7467
    Nov 3, 2005
    980
    Northen N.J.
    Thanks very much.
    Advice: Let the mineral spirits sit on the Dinol for several minutes. I used a M.S. that was organic, a milky white from Lowes.
    Buy several scotch brites and a soft bristle brush. I scrubbed small sections at a time, rinsing inbetween to see my progess.
    The Dinol makes a MESS. Do it where you will not mind getting it on anything.
    I was able to get the inside wells exceptionally clean, not a sign of Dinol anywhere on the fiberglass wells.
    Brake Cleaner also works well, but you'll go through alot. I used it for hard to reach and small touch-up areas.
    Aus_yz likes this.
  13. DenisB
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
    what did you use and how did you do the shocks?? that's just the finishing touch, Looks fantastic
  14. Easyrider7467
    Nov 3, 2005
    980
    Northen N.J.
    I used a citrus cleaner called Goo Gone. Picked it up at Lowes, comes in a spray bottle. I dampened a rag and ran it through the spring. I also used a small toothbrush with it on it.
    Then a clean rag to wipe it off....
    Thanks..
  15. SoCal308GTSiQV
    SoCal308GTSiQV Formula Junior
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    Nice work, I'm going to save this thread and do the same! Thank you
