GTB QV 49461 refurb | FerrariChat
GTB QV 49461 refurb
Discussion in '308/328' started by viper_driver, Oct 26, 2009.
  1. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    #1 viper_driver, Oct 26, 2009
    Bought the car a few months ago from F-Chat, it's in storage until I move in November. Finally got a weekend to fly out, see it, and start working on some minor stuff.
    Fix rust on doors
    Refurb rear bumper
    Refurb front bumper
    Radio delete plate
    Steering wheel
    Shift knob
    Ash tray refurb
    Make license plate frame
    Fix/ charge AC
    Then, took it to a local car show the second night. Good fun.
  2. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #2 viper_driver, Oct 26, 2009
    Door rust. First job was to fix the rust at the bottom of the doors.
    Removed the bad metal with a grinder, put encapsulator on, filled with combination of West Systems stuff and Rage, sand, more Rage, more sanding.
    Then, on to paint. First with high fill primer, sand w/ 600 grit. then sealer primer and finally red. I used single stage to match the rest of the original paint. The PO had some paint that was a late 90s Jag color, Phenix red I think. It's a perfect match to the 25 year old Rossa Corsa.
    It came out great, by far the best paint on the whole car. All that's left is some 2000 grit and polishing the next time I'm out there.
  3. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #3 viper_driver, Oct 26, 2009
  4. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #4 viper_driver, Oct 26, 2009
    Same as the rear, it looked bad. same sanding and paint. Then, I drilled the shocks and pushed it in till the mounting bolts hit the frame.
    If anyone wants the procedure, PM me. I'll leave it out of here since it seems pretty unpopular. I definitely learned some things to make it easier and faster next time.
    The turn signals are still out as both needed major surgery to be saved.
  5. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #5 viper_driver, Oct 26, 2009
  6. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #6 viper_driver, Oct 26, 2009
    the original wheel didn't look too good. I wanted to keep it, but even at $500, the refurb wasn't going to look original. So, I opted for a new Momo Monte Carlo.
    It's very similar. The size is exactly the same. the black center is identical in shape, but the Momo logo is very slightly different. The leather seems the same, but the stitching is black instead of white. The rim shape is different: no finger bumps all the way around like original and the Monte Carlo also has thumb bumps at 10 and 2.
    overall I like it. and can't beat the price.
    Yes, I need some new bolts I know. The old ones look even worse with the fresh wheel.
  7. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #7 viper_driver, Oct 26, 2009
    The stock shift knob looked 25 years old. I love my DD's Voodoo so I bought one for the 308 as well. It's great.
    The ash tray was the only part on the console that looked bad. There was some rust under the emblem. Removed it, took it all apart, polished and painted everything. I used SEM trim black to paint it. The amount of gloss seems just like it was before, I think it's right.
    I was thinking about getting a new emblem, but maybe that's as good as they ever are, even when new??
    The window switches don't look too good in the picture, I just got a new set from T Rutlands that are waiting for install.
  8. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #8 viper_driver, Oct 26, 2009
    Not really worthy of a post, but it was on my list.
    Every plate frame I could find was chome. I wanted black so I made my own design: anodized frame + white vinyl sticker.
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,806
    Cerritos, CA.
  10. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,326
    Montana
    Kim
    Looks Great Jason! Enjoyed your "play by play" and Pics.
  11. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
  12. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    Thanks, I sent an update to the QV register with my info right after I bought it. I guess they're just a little behind.
  13. GTVeloce
    GTVeloce Karting
    Jul 19, 2009
    207
    Kauai Hawaii
    Dennis
    Really nice! Like the new steering wheel!
  14. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #15 viper_driver, Oct 27, 2009
    Thanks to F-chat, I repainted my old emblems rather than buying new ones. they came out great.
    Removed them with fishing line, soaked in lacquer thinner, light sanding with a scotch brite pad, repainted with gloss black spray, then white paint pen from Joann's craft store, then a few coats of clear.
  15. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    Your car looks great. Almost a twin sister to mine except for the tan inside. Mines black inside. I did alot of the same things you did. Enjoy the car. Looks fantastic.
  16. chris_columbia
    chris_columbia Formula Junior
    858
    Columbia MD
    Chris
    How did you access the nuts that attach the 308 emblem. The last time I looked, mine had a fiberglass panel on the inside of the rear cargo area that covered the nuts. I understand the fishing line removal for the quattrovalvole emblem.
  17. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    The 308 nuts are behind that fiberglass panel. At least on my car, there's really nothing holding that panel in place except the carpet. it's easy to remove.
  18. chris_columbia
    858
    Columbia MD
    Chris
    thanks viper. I see that the fiberglass panel is very loose.
  19. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
  20. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #21 viper_driver, Dec 29, 2009
    When I was pushing the rear bumper in, I noticed the trunk floor was loose underneath and hanging down. Ouch, once I got in there, it looked like a shark had taken a bite out of the thin tin covering the frame rail on the left side rear.
    So, cut back to good metal, put encapsulator and rust stuff on everything, made a new piece to replace it from al and riveted it in. Filled in all the cracks with goo and reattached the trunk floor. painted the other side and sealed it as well.
    nothing else is rusty, the trunk floor must have leaked at some point.
  21. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #22 viper_driver, Dec 29, 2009
  22. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #23 viper_driver, Dec 29, 2009
  23. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #24 viper_driver, Dec 29, 2009
  24. viper_driver
    Jan 1, 2009
    978
    Vegas
    Jason
    #25 viper_driver, Dec 29, 2009
    my center/ windshield rear view mirror was bad. The glare switch was broken and made it basically unusable. Seemed like replacement 25 year old versions were about $150 or more and not all that nice. I got a universal model at AutoZone for $15. The 8" size is just right so the visors still work.
    I don't have much of a picture so here's just a random pic of the car.
