The 110,000 mile service, part 2 | FerrariChat
Discussion in '308/328' started by GrigioGuy, Nov 12, 2009.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    #1 GrigioGuy, Nov 12, 2009
    Well, this was unintended and for the most part unwelcome, but hopefully soon I'll be sitting in a nice new interior.
    I have samples coming for the carpet and leather, and a big fight coming with the insurance company. Life is fun.
    Oh -- and I have a new-in-the-box front 328 targa seal to go with the rest of the set. Y'all don't want to know what -that- cost me :)
    More pics later.
  2. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    #2 GrigioGuy, Nov 12, 2009
  3. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,905
    Dallas, TX
    Jim E
    I've always thought an F40 was above a 328. :)
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    The glass "carrier" in the LHS door is looking a bit of a mess. Replaced both of mine earlier this year & they don't have many left in stock at Maranello parts. In fact ISTR they only had one side (the two sides are a mirror image of each other). So I had to buy two of whatever they had & then get the mounting bracket moved & rewelded on one of them.
    Then painted them & used frame/windscreen sealer to seal the glass into the things (one of the problems with them is water sits down in the carrier).
    Wouldn't be a terribly difficult thing to get made if you had to.
  5. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    The passenger one was replaced a couple of years back when the original coil drive failed, and at the time was the last one available.
    I wanted to replace the driver one, but the bolts are completely rusted. Drilling them out really isn't an option given where they sit in relation to the glass. Got to figure a plan -- which might just include buttoning it back up.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    If you took the glass+ carrier out you'd be able to grind the heads off the bolts on one site &then cut the captive nut away on the other & get the glass out the carrier . Wouldn't be too hard.
    Or are you saying you can't disconnect the carrier from the lifter mechanism? (in which case something like a dremel & grind the heads off the bolts in situ I would have thought.)
    When I bought the two I have in my car now they had 3 or 4 left. As I said, I had to buy two LHS carriers & get one converted to RHS (just a matter of moving the bracket).
  7. mwr4440
    57,969
    Bavaria, The 'Other' Germany
    Mark W.R.
    Tillman,
    A bit of advice if I may from the "Been there and done that," perspective.
    I could not get Connley Leather (Mad Cow & closed doors) so I went with leather from MB when I redid my interior a year or so back. MB leather is far above OEM in my book, much thicker and still as soft. It is GREAT for high-ware areas like the seats. But ..... its greatest assest turned out to also be its greatest liability.
    THICKER turned out be very problematic. It was TOO THICK for everything else. All the gauges and switches etc fit tight to begin with and the leather wapping behind the part made it TOO TIGHT.
    So, I had to go and cut/trim massive amounts of leather off to ensure all the re-rapped parts fit together with themselves and everything else. What ALLOT of work. :(
    Just a friendly "Head's-Up" on what could go wrong :mad: with a good intention. :)
    You might seriously look at getting different thicknesses for each application. But then, color and skin matching could become a PITA.
  8. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    #8 GrigioGuy, Nov 16, 2009
  9. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    That's precisely it, and one of the bolt heads is missing -- but the threaded area is dang near welded itself in. Nasty situation, and I think I'm going to end up having to replace the glass before this is resolved.
  10. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    Or treat the metal as best you can in situ - its only a window carrier & if you really can't get it out then maybe just treat it for rust & just paint it in situ as best you can.
    The big trick with these is a smear of frame sealant/silicon between the glass & the carrier to stop the water getting down inside & sitting in the carrier - thats what rots them. I have two new ones in my car, both painted & then the glass is sealed into them with frame sealant. Messy job but they should never rust again.....
  11. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Tillman...I've got to ask how much?
  12. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    Soliciting opinions here:
    The rear package deck is going to be replaced on the car. I'm thinking black vinyl to give more durability -- the cloth was pretty worn on the stock piece by the targa latches. I know a few have done the conversion. How's it holding up? Opinions from the peanut gallery?
  13. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    Had leather on mine for 10 years. Much better than the fabric - Its all around the rear window area and the inside of the targa (basically anywhere that was fabric as stock)
  14. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Melbourne, Australia
    Brett
    #14 b27, Nov 18, 2009
    We can get Connoly here Mark. I have had one panel replaced on my drivers seat. I am in the process of restoring my seats to keep originality. Will be posting some photos in my thread when it's done but here a couple of before and now. Not finished yet so this is just work in progress. Definitly worth considering restoring over replacing, about half the cost as well.
  15. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    No problems with the leather shrinking etc.? I'm worried about that given how hot it gets here.
  16. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    Ok, I got the sample carpet and leather in from GAHH. Nice folks, but I really didn't like the textures of either piece.
    The shop is recommending the carpet set from Italian Car Parts. Anyone used those folks recently? They're quoting 4-5 weeks lead time on the carpet :(
    I'm stil debating color choice. Black-black-black in the interior gets a bit dark. Maybe a navy or deep red in the carpet? Thoughts?
  17. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I think get a carpet that kind of matches the body colour and then do what you like with the leather that doesn't clash. Too many different colours (especially strong colours) never works IMO.
  18. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    If it were me I'd do all black, given the darker silver color of your car. Mine's Argento Nurb. and all black to me seems like the best option. I do, however, like a beige/tan with silvers, especially darker gray metallics but I dislike the two-tone interiors. Do black with all IMHO. Engine still running strong at 110K, that's very impressive, certainly a testiment to the benefits of using these cars. Wish I had even slightly reasonable parking options, I'd drive mine to work most of the time. Good luck in your endeavours.
    Jeff
  19. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    #19 GrigioGuy, Dec 1, 2009
    Well, I spent about an hour today looking at leather samples and carpet samples.
    After all that, I ended up choosing factory equivalents in black after all.
    A couple of weeks to redo it, I understand. Local guy is doing everything.
  20. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,576
    Avvocato
    FWIW...you cant go worng with blk, and the tan looks good on that color....but if you wanted to go UNIQUE on the 328....the smoking color interior would be that boedeaux (ox blood) color all round...seats, and rugs and dash....that color combo is by far the best on the exterior color you have....it would look great.
    I saw one exterior white/blood red (beredeaux) interior 328 at a car show many , many yrs ago...and everyone (especially the chicks) loved that car...was a definite crowd pleaser....the talk was all about the interior color combo ...the women called it lipstick color.
    PS..in the texas heat, i would figure it might be a tad better, plus not fade as easily.
  21. chris_columbia
    chris_columbia Formula Junior
    865
    Columbia MD
    Chris
    If you don't mind the stigma of using vinyl for the parsal shelf, I would recommend it over leather. You're not sitting on it, so you don't care about the "real" leather feel. If you're the typical owner and don't park it outside much, either will hold up. BUT, it just doesn't make sense to me to spend 10X the price for leather material vs vinyl, when vinyl is the superior product for sun/heat exposure. I used a mat black vinyl on my shelf, and I think it looks better than many of the textured leathers I've seen people add there. Plus, the price was so cheap, it was on the verge of free since I did my own labor. I just wish I could upgrade the shinny dash vinyl without taking the windshield out :(
  22. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Tillman,
    What's your source for fabrics for the rear shelf and other bits connected with that? I'm considering what to use for mine as well.
    Jeff
  23. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    Using black vinyl for the lower parts. The upper part above the shelf are fine, and so I'm leaving the striped fabric there to blend with the material under the targa roof. I did not want to replace that with black too, way too much of a coal mine effect.
  24. redline76
    redline76 Formula Junior
    Feb 26, 2008
    355
    Venice, CA
    Warren V
    Tillman,
    To break up the monotony of black, consider doing a contrast stitch using either silver or red thread. Subtle effect, but brings out the detail on the door panels, console and seats :)
  25. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    #25 GrigioGuy, Jan 13, 2010
