275GTB/6C carb issues | FerrariChat
Discussion in 'Technical Q&A' started by 410SA, Feb 9, 2009.
  1. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    My 275 has been sitting for several weeks and when I went to start it, it pumped fuel to the carbs and then proceeded to leak fuel from each of the carbs on the opposite side to the fuel rail. There was no apparent leak on the fuel rail side.
    The leak appears to coming from the spring loaded plate of the side of the carbs, The gaskets are reasonably fresh and I'm wondering if this is a function of modern fuels being incompatible with the gasket material on the carbs.
    Any thoughts.
    BTW I have never needed to use the choke to start the car. I'm not even sure which way is "open" or "closed" on the horizontal choke lever.
  2. Napolis
    Napolis Three Time F1 World Champ Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Yes. This is a serious problem. Modern fuels left in Vintage Carbs will cause this type of problem. There are two things that will help.
    Replace the gaskets with ethanol resistant gaskets and put an in line fuel shut off valve or electric fuel pump cut off and after driving shut off fuel supply and idle/run until the car just begins to stall.
    Some have also had luck with fuel additives that claim to help with this problem.
    Best
  3. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    954
    Arizona
    Jim
    I believe the spring loaded plate is your accelerator pump diaphram. These are made out of a rubber impregnated cloth material. Modern fuels often cause the rubber to swell when exposed to fuel. When they sit dry for a period time they tend to shrink and loose their seal (take a compression set). Before you replace them I would check to see if the screws are torqued correctly. Often they will be loose and will seal up when snugged down. I have also found that they will typically seal again, once they have been exposed to fuel for 24 hours. Twenty four hours seems to be the time required to make them swell back up. Rubber based gaskets in the fuel system often to need retorquing once or twice before they are reliable. Of course none of the above will help is the diaphram is ruptured. In my experience I would estimate that you have a 70% chance retorquing the screws will correct the issue.
    Cheers Jim
  4. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    One separate thing. Take off the air cleaner and make sure the mechanical choke is working properly. Choked cuts off air supply and you don't want to run car too long like that. It's probably open but check.
    Best
  5. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,404
    Houston, Texas
    Bubba
    Dave Helms and I have had many discussions...As Napolis states the modern fuels (will have ethanol and LOTS more) are blended by region and season, and lots of the additives are indeed very harmful to outdated products.
    The problem is known but not the answer.
    Mercury Racing was onto it several years ago with recalls...It least in our cars, we can walk home, swimming is a lot more challenging!
  6. Rifledriver
    37,288
    The accelerator pump diaphrams have always had that problem since long before the fuel changed. The Webbers with the exterior accelerator pump design which that, 4 cam and later cars had, shrinks when dried out after use. It is not unlike the hull of a wood hulled boat, the difference being it will not swell and reseal after getting immeresed. It has been pretty standard to need to replace them in such an instance since before they were considered old cars. It has been a pretty common spring service on many cars for as long as I have been doing this. The idea that allowing a carb to "Dry Out" has been considered something to be avoided since my father learned to drive in the thirties even on Model A's.
    Sometimes just gently tightening the 4 screws at the corners of the pump diaphram cover is enough to control the situation.
  7. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I've used fuel cut off valves for years and it seems to have stopped this. Maybe it's keeping fuel from draining out of the carbs, back into the lines and tank and keeping the gasket soaked. I think it's also a factor in systems where a fuel source/line is higher than the carbs as on bikes. In the winter have shut them on my boat motors and never had a carb leak in the spring when opened and restarted.
    Wasn't this an issue on some Lambo's with side draft carbs?
  8. Rifledriver
    37,288
    DCOE series has a fuel well cover plate on the bottom with a gasket made of the same material as the pump diaphrams but it is a single layer so the shrinkage is less of an issue.
  9. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Thanks.
  10. 410SA
    410SA F1 Veteran
    Nov 2, 2003
    8,511
    West Coast
    A
    Thanks for all of the good info guys.
    I found the screws on the plates to be a tad loose, so I tightened them. The gaskets have had fuel in them for 24 hours now, so the shrinkage and re-swelling issue, if it works, should have made them fit better by now. If not, I'll pull them all off and rebuild them with ethanol resistant material.
    BTW does anyone here know in what position the horizontal choke lever (between the speedo and rev counter) is "Off". I assume all the way to left is no choke engaged and all the way over to the right is maximum choke. There are no markings on the switch and I've never used it before. I may have slid it over to the right when I was last wiping the dust of the dashboard.
  11. 512bbnevada
    512bbnevada Formula Junior BANNED
    Aug 22, 2007
    422
    las vegas
    Biff
    Carb fuel leaks have caused many Ferraris demise from fires. Don't know if you have an elec fuel pump but with key on motor off its a good idea to run your fingers around the lines and carbs for leaks befire a run if its been awhile sitting. If you suspect the accel pumps are deteriorated you can look down the carbs with aircleaner off for the volume of fuel squirting down the barrels. You can check the amt with a vial if you want to get exact that should tell if they are healthy
  12. Rifledriver
    37,288
    The accelerator pumps hold far more fuel than they squirt and are constantly refed by the fuel bowls in any event. You could have a very large fuel leak with no change in the way the accelerator pumps work or the volume they discharge.
    Same goes for your BB.
    Your BB has adjustable pump discharge so there is a spec for that quantity. Not so DCN or DCNF.
    Not all Webbers work the same.
  13. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Actually on the carb and fuel pump diaphrams the answer has been around for a good many years now. The problem is there are still a good many of the old parts floating around in the parts system and to this day I still get some of the old and some of the new when working on the Vintage cars. Used to be one could visually identify the good from the bad by color of the rubber material covering the canvas...not the case anymore. There is both good and bad black and red material.
    Many only focus on the carb leaks as they are easy to see. Dont forget about the diaphrams in the fuel pumps, they suffer the same fate as the accel pump diaphrams. Years back the liner of the Yellow hose was changed to a working material but if those lines look old....keep a close watch on them!
    With the way I have seen the fuel compounds separate in my tests, consider it essential to drive the car a few miles once a month just to stir things up and keep all of the fuel components suspended. This I now consider an absolute must with the current fuels out of the pump.
    Dave
