275GTB vs Daytona | Page 3 | FerrariChat
275GTB vs Daytona
Discussion in 'Vintage (thru 365 GTC4)' started by J.P.Sarti, Nov 19, 2005.
  1. malcolmb
    malcolmb Formula 3
    1,163
    San diego
    Malcolm Barksdale
    wow, an old thread back to life. I LOVE driving my Daytona.
    Malcolm
  2. jgcferrari
    jgcferrari Formula Junior
    925
    Jose
    To me nothing feels more Ferrari than a properly sorted Daytona, its just magcial, probably my favorite driving Ferrari of all time
    swift53 and daytonaman like this.
  3. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,505
    Tuscaloosa, AL
    Drew Altemara
    The Daytona was built on the 275 classy I believe.
    The engine is 4.4L vs. 3.3L for the 275GTB and I imagine the running gear is a little beefed up in the Daytona.
    The Daytona is much heavier to drive. By a large margin.
    Is this all due to the weight of the engine or are there other differences.
  4. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,836
    Drew: Don't forget, Daytona's have air conditioning, this adds quite a bit of weight. All the suspension is designed for the heavier, more powerful car. A-Arms on a 275 are welded up sheet metal, while a Daytona uses heavy forgings. Daytona's are nicer finished in the interior and all this adds weight. Obviously the larger engine and dry sump system is quite a bit heavier. Daytona bumper systems (even on European Daytona's) are considerably heavier. 275 GTB with steel body-2,757 lbs. Daytona- 3,487 lbs. Both cars with spare tire and toolkits, but no fuel. Weighed on the same set of race scales.
  5. Ak Jim
    Ak Jim F1 Veteran
    8,493
    North Pole AK
    Texas Forever likes this.
  6. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
  7. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,300
    checkout the speedo/tach. :eek:
  8. Nembo1777
    Nembo1777 F1 World Champ
    10,210
    opposite lock
    Marc Sonnery
    He was on the Autobahn;) and that's what these cars are made for, not concours lawns:).
    turbo-joe likes this.
  9. Ak Jim
    Ak Jim F1 Veteran
    8,493
    North Pole AK
    I did! :)
  10. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    832
    Ted
  11. malcolmb
    malcolmb Formula 3
    1,163
    San diego
    Malcolm Barksdale
    jim, check the road ahead, 13 mile straightaway.malcolm
  12. bertdeboer340
    bertdeboer340 Formula 3
    Sep 16, 2003
    2,374
    Netherlands
    Bert de Boer
  13. Marcel Massini
    Honorary
    Mar 2, 2005
    22,929
  14. Edward 96GTS
    9,300
    that is no beauty, ultimately they got it right.
    NYC Fred likes this.
  15. Marcel Massini
    Honorary
    Mar 2, 2005
    22,929
    10287 is the very first Daytona prototype.
    Marcel Massini
    FrankBarnard likes this.
  16. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    … and for some fairly obvious (styling) reasons, didn’t (thankfully) get chosen for production. ;)
  17. Marcel Massini
    Honorary
    Mar 2, 2005
    22,929
    That was never planned nor the idea.
    Prototypes often use bodywork from earlier cars (288 GTO = 308 GTB, or F50 = Mondial 8, etc.) or even different makes (FUV Purosangue = Maserati, etc.).
    Marcel Massini
    readplays likes this.
  18. swift53
    swift53 F1 Veteran
    6,733
    E.S.
    Alberto
    California Autobahn ;)
    Regards, Alberto
    Nembo1777 likes this.
  19. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    Yes, I’m fairly familiar with the concept of design prototypes, hence my earlier comment.
    Many designers often use new and unconventional styling features for their prototypes, while some try to retain existing or older ones, perhaps using such feature in attempt to “bridge” the lineage.
    I’ve even had a pleasure to work on few (non-Ferrari) vintage prototypes (& one-offs) of various makes.
    swift53 likes this.
  20. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner
    Dec 1, 2000
    59,653
    Southlake, TX
    Rob Lay
    awesome, you still have them 15 years later? did you ever attend Crescent Classic in Arkansas?
  21. -K1-
    -K1- Formula Junior
    Jul 10, 2008
    698
    Northern Italy
    Ken
    Do you think there are any ‘easy wins’ to reduce weight? Tubi, modern aircon replacement etc? Unlikely to be able to drop that much I would expect.
  22. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,836
    Ken: Only major ways to reduce weight would be totally remove the A/C system, remove the bumper units, and gut the interior.
    -K1- and TTR like this.
  23. malcolmb
    malcolmb Formula 3
    1,163
    San diego
    Malcolm Barksdale
  24. TTR
    TTR F1 Veteran
    5,196
    Riverside, CA
    Timo
    Dyke, while I dislike to disagree with your experience, I don't think Daytona bumpers or their support structures are heavy contributors to overall "weight problem" on them.
    Looks like 275 GTB bumpers might weight more than those on Daytona.
    OTOH, Daytona (road car) exhaust system, especially the US one, is quite heavy, over 200 lbs, IIRC. And let's not forget all the smog equipment related items.
    The "visible" interior components aren't really that heavy, but all the OEM heat/sound insulation (under the carpets) and the firewall + underfloor heat shielding (latter I believe is found only on US cars) easily adds 200+ lbs.
    Also IIRC, the complete A/C system is only about 100 lbs, but as you said removing it all would help reduce the weight.
    The dual-zone heat/fresh-air system is fairly heavy too, maybe another +/-100 lbs all in.
    Daytona doors (especially steel ones) with power window systems, OEM speakers, etc are also surprisingly heavy.
