Exhaust Clearance on 328 | FerrariChat
Discussion in '308/328' started by roalda, Mar 8, 2010.
  1. roalda
    roalda Formula Junior
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    #1 roalda, Mar 8, 2010
  2. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Any ideas guys
  3. BigTex
    79,368
    Houston, Texas
    Bubba
    I'm not sure how to adjust that spring hanger, but there has to be some way.....maybe others will chime in..
  4. Denman_Honda
    Denman_Honda Karting
    Sep 3, 2009
    123
    DFW, TX
    Chris Denman
    Looking at the picture, you can try to support the exhaust, remove the cotter key and pin on the collet. Then attempt to loosen the jamb nut at the bottom of the spring washer and above the collet to possibly adjust height. You will have to counter hold the collet. I have not had to make this adjustment, so do not know if it is possible. On the 328 I have here, it looks like the collet is a seperate piece from the rod running through the spring assembly. Hope this helps and good luck!!!
  5. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    #5 roalda, Mar 9, 2010
    Do you think by holding the bolt at the top with a spanner and turning the nut at the bottom clockwise will compress the spring thus lifting the exhaust???
  6. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Any ideas guys
  7. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    #7 308 GTB, Mar 10, 2010
    Roy,
    Yes, do what you described to compress the spring in order to lift your exhaust. The hangers on my 308 are the same and I had to do just that to adust the height of the Mille Miglia exhaust I installed a couple of years ago.
    Barry
  8. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Thanks Barry
    I think when i fitted new o,ring gaskits to the exhaust this has altered the height of the box.
  9. 308 GTB
    11,717
    New Jersey
    Barry Wolinsky
    Roy,
    I can't see it in the picture you posted, but there's probably another nut at the top of the bolt. Place your spanner on that and turn the bottom nut to compress the spring.
    Barry
  10. Steve Magnusson
    26,781
    #10 Steve Magnusson, Mar 10, 2010
    You need to loosen all of the exhaust "donut" gasket connections (and the nuts item 3). Each "donut" gasket connection acts like a ball-and-socket joint, and this gives you the freedom to "rotate" the entire muffler assembly about a lateral axis -- i.e. the inlet pipes go down and the tailpipes go up. Headers and mufflers aren't made to tight enough dimensional tolerances to (always) allow individual replacement and have everything come out right -- the whole thing is meant to be adjusted together as a "system" -- i.e., you need to loosen the connections at each end of both pipes running from the headers to the muffler inlets so those pipes can act like moveable links and "absorb" all of the tolerances:
  11. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Thanks Steve
    Should i not bother with the hanger adjuster? my first thought was to loosen the pipes you have pointed out then compress the hangers to raise the box height.
    Regards Roy
  12. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    #12 roalda, Mar 11, 2010
    Shows up better on this pic Left hand side.
    Regards Roy
  13. Steve Magnusson
    26,781
    #13 Steve Magnusson, Mar 11, 2010
    I can't recall how much of the hanger bolt is threaded, but I don't think that it is that much, so IME you can't make large adjustments there (and the weird part is that if you turn the nut to compress the springs and expose more threads, this lowers the bolt). IMO, you don't need to raise the box height -- you only need to raise the tailpipes (by rotating the box -- its general height doesn't need to change).
  14. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Thanks Steve
    Have done what you showed on your diagram and it worked, now no annoying rattles.
    Thanks again guys.
    Regards Roy
  15. BigTex
    79,368
    Houston, Texas
    Bubba
    #15 BigTex, Mar 12, 2010
  16. roalda
    Oct 2, 2007
    593
    Wiltshire England
    Roy
    Nice earmuffs.
  17. Mfoncerrada
    Mfoncerrada Formula Junior
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Nice muffs
  18. Steve Magnusson
    26,781
    #18 Steve Magnusson, Mar 12, 2010
    Glad to hear that you got it sorted out. It is a little unobvious at first, but since the ends of the headers are in a fixed location, and since you want the tailpipes in a fixed location (relative to the coachwork), you really need to loosen all of the joints between the two in order to achieve a new "solution" -- not just the joints associated with the new component (unless the old and new components are an exact match -- which they rarely are for exhaust pieces).
