the lvferraripilot engine rebuild thread | FerrariChat
Discussion in '308/328' started by Ferraripilot, Mar 29, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,988
    Atlanta
    John!
    #1 Ferraripilot, Mar 29, 2010
    Hey all. I picked up an engine crane and engine stand over the weekend, assembled them, and started pulling the difficult stuff off the engine first.
    So far, I have the header towards the rear of the car unbolted, but not out. The e-brake cables have been moved out of the way as have all the air-pumps, but the header will still not slide down. I suspect the right rear engine mount has to come off to slide the header out??
    Also, I have remover the hex bolts holding the half-shafts to the differential, but some of the hex bolts to the other side of the half-shaft are held on by some sort of interplanetary force not known to Earthly societies yet (they are stuck really well). I have the bolts/nuts soaking in nutbuster. Any tips anyone can share on removing these things?
    As you can see by the second pic, this header became *really* hot at some point due to a misfire. When I first purchased the car, I noticed this header immediately as I could see the pipes glowing red-hot. I immediately performed a major and the car has been fine since. Just a drag because I have an ugly header now.....
  2. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    You know there is an extra set of hands to help you with this stuff thats not too terribly far away from you.... I look forward to following this, both here and hopefully in person!!!
    How long do you think your car will be off the road??
    PDG
  3. Brian Elliston
    Brian Elliston F1 Rookie
    Oct 9, 2009
    2,778
    Clermont, FL
    Brian Elliston
    Right on! I love these threads. Popcorn is popping.
  4. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I am hoping to have it done by July. We shall see.....
  5. JV's89
    JV's89 F1 Veteran
    7,435
    Pittsburgh, PA
    I can't remember for sure, but I thought the rear header came out pretty easily. The front came out after removing the passenger side fuel tank.
    There are some in-depth threads with step-by-step descriptions that I relied on when I did mine.
  6. JV's89
    JV's89 F1 Veteran
    7,435
    Pittsburgh, PA
    Have you given any thought to removing the heat shields from the headers? I don't know if it is advised, or not, but I left mine on and I suspect they are part of a rattling noise coming fom back there. It would have been a much easier task while the engine was out.
  7. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    #7 furnacerepair, Mar 29, 2010
    If you remove the heat shields you should have the headers coated. A good ceramic coating runs about $500. The idea behind the heat shields is to keep the heat in. Coat both the inside and outside. Pic is of one header with the shield removed and before coating. Looks nasty.
  8. furnacerepair
    Feb 9, 2009
    744
    Wisconsin
    Martini
    #8 furnacerepair, Mar 29, 2010
    I ended up replacing the headers with new just so there were no test ports or welded up holes. Went with silver to kind of match the rest of the SS pipes and muffler.
  9. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    moderator. just noticed my grammatical error. can you change the title to 'rebuild' thread plz?
  10. JV's89
    JV's89 F1 Veteran
    7,435
    Pittsburgh, PA
    That's beautiful!
    Wish I had done that when I had it all out.
  11. furnacerepair
    Feb 9, 2009
    744
    Wisconsin
    Martini
    #11 furnacerepair, Mar 29, 2010
    Thanks. It was just one of those things. As long as we are in there...... Started out as a normal major service. It had not been done for a long time. Ended up rebuilding everything. LOL ,,,, I should be good to go for quite a while now. Got a friends QV in the shop for the same. Wonder how far he will go with his. First pic is mine. Second pic is QV just getting started on the work.
  12. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Some might like to document this little tidbit. I am filling a box and calling it 'the emission crap box'. So far, I have both air pumps in there, one valve and a couple hoses. The box is already a shade over 20lbs. I just have a valve, couple hoses, and the injectors themselves to go. Might make the 25lb mark.
  13. JV's89
    JV's89 F1 Veteran
    7,435
    Pittsburgh, PA
    Free horsepower!
    Gotta love it.
  14. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    John non of us here noticed you had already rebuilt your motor , to interested in the juicy bits .
  15. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    lol. yeah my grammatical error is being corrected
  16. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    July of 2011 right?? ;)
  17. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I should have known the peanut gallery was going to pipe in lol. Machine shop says they are 3 weeks out. Hoping that is the only delay.
  18. duck.co.za
    Jan 9, 2007
    1,007
    Dave
    So you are not going to try your hand at porting once Mark has shown us how !!!!
  19. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    No, I'm not quite that brave nor do I see the gain being entirely worth the expense for my purposes.
  20. furnacerepair
    Feb 9, 2009
    744
    Wisconsin
    Martini
    #20 furnacerepair, Mar 29, 2010
    I had a whole trunk full of this stuff when I did mine. Your engine will thank you.
  21. stev4266
    stev4266 Karting
    Mar 24, 2010
    186
    R.I.
    steven gregson
    If you pull all that stuff off the engine will it still pass inspection. Or is that not a problem in your state.
  22. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Not an issue in Oklahoma. I recently moved from Las Vegas where unfortunately it was a huge issue, otherwise I would have pulled this engine and upgraded it years ago. It was very frustrating having to tune the car specially to pass emissions and inspection. The car runs like a dog, hot, and it ruins a weekend.
  23. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    #23 Ferraripilot, Mar 29, 2010
    Made some progress tonight. Managed to get the header at the 1-4 bank out. Thanks to Paul and Larry, the header comes out the top. Remove air injection tubes, cam cover (header gets stuck on the air pump mounting portion of cover), and out the manifold comes. Also, I removed the half shafts. For really stuck hex bolts, give them a couple good whack with a brass hammer and they come right out.
    I placed the cam cover back to keep the cams from getting dirty.
  24. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    I believe this engine ranks right up there with Paul's engine in the dirty department. Really disgusting. Nothing a power washer can't fix
  25. Ferraripilot
    May 10, 2006
    17,988
    Atlanta
    John!
    Ok, I know I don't have pics. I promise more are coming.
    Had about an hour or so to tinker last night. The other half shaft came out without much drama. I found the most difficult part of removing them was finding position in which I could apply sufficient torque to the bolts. I was in the trunk lifting on the wrench for the inner bolts, and on my back nearly under the brakes for the others.
    Remaining:
    disconnect starter
    disconnect alternater
    remove/get out of the way a/c compressor
    remove bell housing/drop gears
    disconnect shift linkage
    disconnect ground strap
    disconnect motor mounts
    The hard stuff is out of the way.
    I will be lifting the engine a la factory spec with the 1-4 bank being lifted first with the 5-8 header still attached. Searching the forums shows a couple have done this before, and in speaking with a couple old Ferrari mechanics it seems to be a good way to go.
