28 years, not a problem. | FerrariChat
Discussion in '308/328' started by johnk..., Apr 7, 2013.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,203
    CT
    John Kreskovsky
    #1 johnk..., Apr 7, 2013
    It's pretty nice out today in CT so I decided to go through the spring ritual of getting the 308 up and running. For 28 years, in the fall I have pulled it into the garage, disconnected the battery, threw the cove over it and forgot it. In the spring I take the cover off, reconnect the battery and give it a whirl. No different this year, 1, 2, 3, rummmmm! No trickle charger, no gas stabilizers, no nothing. Park it, forget it,....6 months later, get in it, start it.
  2. mwr4440
    57,879
    Bavaria, The 'Other' Germany
    Mark W.R.
    Good for Ya.
    I have not met a battery yet that will survive a German winter w/o a trickle charger hooked-up at least intermittently.
  3. Lektronimo
    Lektronimo Karting
    Dec 31, 2012
    143
    Franklin Square NY
    Stefano
    Way to go John
    Enjoy!
  4. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    How many miles on her?
    R
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,469
    San Carlos, CA
    Mitchell Le
    I see what you mean. You forget her for 6 months only to return to find a battery staying charged and the car ready to rock and roll. If you had meant that you had never had a single thing wrong with the car, then I would not believe it. No plug extenders, no relay, no fuse boards, no ignition wires, no rotors, no dizzy caps, no bearings, no oil leak problems? Well, that would be a first.
  6. johnk...
    Jun 11, 2004
    11,203
    CT
    John Kreskovsky
    30524 miles and counting.
    By the way, for our German friend, my battery is 12 years old! I'm convinced that trickle chargers are battery killers.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,799
    Cerritos, CA.
    Let's see some pics,:)
  8. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,208
    Austin, TX USA
    Greg
    Hope not, i have them on my 2 bikes and the 328....
    Sent from my SGH-T989 using Tapatalk 2
  9. johnk...
    Jun 11, 2004
    11,203
    CT
    John Kreskovsky
    #9 johnk..., Apr 7, 2013
  10. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,160
    SB,CA & Park City UT
    Jeff
    Not so sure myself. 10 year old battery still going strong with intermittent driving all year. I doubt that would be the case without my battery tender. You unplug the battery I assume?
  11. johnk...
    Jun 11, 2004
    11,203
    CT
    John Kreskovsky
    I unplug the battery when ever the car is in the garage, even during driving season. It's so easy to pop the hood and disconnect the ground.
  12. Piloto
    Piloto Karting
    Sep 13, 2009
    58
    #12 Piloto, Apr 8, 2013
    Pretty much the same story here, although there have been some minor mechanical issues. 1983 one-owner 308 GTSi. I do the majority of work, and we have spent many enjoyable moments, both on the road, and in the shop.
    A mistress that has not grown fat, lazy, and has not given me grief in our long-term relationship.
    TN
  13. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    That's what I do...same battery...long time...always a good start.
  14. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    I agree, I also just unplug - every time after a drive. nothing else needed.
  15. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    Gezzz, I better tell my motorcycle batt, Ferrari batt, John Deere batt, etc that there double life expectancy thus far is not from a Batt tender but luck...
    just saying...
  16. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Congratulations, John :) I'm glad that your driving weather has arrived. Enjoying it here as well.
  17. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    One of the benefits of having older cars with ECUs that don't re-set & erase all the learned data tables --- on the newer cars, constantly disconnecting the battery has its downsides, too ---- ahhhh, the simpler days ;).
  18. 308 GTB
    308 GTB F1 World Champ
    11,699
    New Jersey
    Barry Wolinsky
    #18 308 GTB, Apr 8, 2013
    It's even easier for me. In 1977, the original owner had Algar install this battery disconnect switch in the spare wheel well of my 1976 GTB...
  19. johnk...
    Jun 11, 2004
    11,203
    CT
    John Kreskovsky
    Yep, I use a trickle charger on my 07 Boxster during the winter just for that reason. While I don't like to, it's better than having to go through the ECU reset procedure. Still, I don't leave it connected all the time.
  20. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    I dont see why a German winter should be considered so severe- European winters (excluding Russia, which many geographers dont consider as "Europe")are not even close as being cold as northern states in N America. European winters are downright mild. Now N. Norway, thats different.
    Batteries in northern states last for years. You could have other problems with your elecs if batt lasts only one season.
