Torque wrench recommendation please | FerrariChat
Discussion in '308/328' started by stevel48, May 28, 2010.
  1. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    What is the most useful size for working on a 308?
    1/4 in 1/2in in or 3/8 drive?
    Digital?
    Good brand/accurate brand?
    Thanks,
    Steve
  2. f355spider
    f355spider F1 World Champ
    18,044
    What are you using it for? You will probably need two.
    For lug bolts, 1/2". I have had excellent performance out of my Utica Tools/Cooper Tools torque wrench. Over 20 years of use, and always tested within spec (until I stupidly broke it recently and had it repaired). It is the "clicker" type, simple and effective.
    If you are using it for low torque stuff, you want a 3/8" rated in inch/lbs. Don't try and use the 1/2" for that, they are not as accurate at the extremes of their range, and usually won't fit anyway, since they are so long.
    I've used the fancy digital ones from SnapOn, they are nice too.
    Regardless of what you use, make sure to have it checked every couple years to ensure it's accuracy. Always dial it down and never drop it.
    After I got mine back from repair, it came with a testing analysis, certifiying the accuracy in each direction and all the specific numbers.
    I have had a friend buy two brand new Sears Craftsman wrenchs (one in 1/2" and one in 3/8") and both failed an accuracy test and needed to be calibrated.
  3. Denman_Honda
    Denman_Honda Karting
    Sep 3, 2009
    123
    DFW, TX
    Chris Denman
    If only picking one.....a 3/8 digital. As long as the range permitted (and should with a good one), it can torque most things on the car that you want to torque on a semi-regular basis, like wheels, steering/suspension, and brakes parts. However, if on a budget and not planning on rebuilding any engines, I would get an inexpensive "click type" 1/2 for wheels, and a decent digital 3/8 and 1/4 for doing more precision work like intake/exhaust manifolds, vc gaskets, etc. This is of course assuming this is for recreational use at home. HTH
  4. f355spider
    18,044
    #4 f355spider, May 28, 2010
    Understand that simply having a digital display does not denote the inherent accuracy of the tool. Quality construction and calibration are the key to accuracy. Utica "clicker" type torque sensing wrenches are not inexpensive, running $300 to $400 each. I know when I got mine repaired it came back with a certificate of accuracy of +-4% from stated setting, and included a data sheet for my specific wrench identified by serial number.
    http://www.cooperpowertools.com/brands/torque/index.cfm
    You can download their catalog and read more about how torque wrenches are used, how theirs are constructed, they even make and sell the calibration devices.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    I'd recommend a 3/8 drive Snap On click type like this: http://buy1.snapon.com/catalog/item.asp?P65=&tool=hand&item_ID=55257&group_ID=954&store=snapon-store&dir=catalog
    The most accurate and reliable torque wrench is the beam type but they are difficult to use compared to the clickers. A good clicker, like a Snap On, is an excellent tool and, as has been mentioned, it needs to stay in its box and not be abused. It is certainly not to be used for any other purpose. OLD craftsman wrenches from 30+ years ago were quite good but that was then and this is now... ;)
    As noted, you should have a 1/2 drive torque wrench for the 70Lb and up type stuff - the same type of Snap On would serve you well. Note that were talking about 500+ bucks worth of torque wrenches. Buy the 3/8 first if you don't want to buy both at the same time.
    BUt note that there is a lot more to torquing fittings than setting the wrench and hauling 'till it clicks. Are the threads clean? Are they supposed to be torqued dry or lubed? If lubed, with what? You need to know that before you tighten a bolt. If you lube a bolt that was supposed to be torqued dry, there is a fair chance you could strip the threads, especially in Aluminum.
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #6 eulk328, May 28, 2010
  7. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    I would be using it for belt/bearing changes, water pump rebuild, cam bearing caps and valve covers.
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #8 eulk328, May 28, 2010
    Under these circumstances I think 3/8" would definitely be the best compromise but it really is a question of the wrench in question having the high and low range you need for the different applications. Also, accuracy typically drops as you get near the low or high end of a torque wrench.
  9. f355spider
    18,044
    +1. I use a Utical Tools wrench. http://www.cooperpowertools.com/brands/torque/index.cfm
    You can download their catalog which has a lot of good information. Their wrenches come with a testing certificate. They are accurate to +-4% but only on the upper 80% of the given range. The lower 20% is where all wrenches become less accurate....usually applying too much force.
  10. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    thanks guys! Gonna look at the utica site.
  11. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Although 3/8" likely would be the "most used" torque wrench, the cam bearing caps and valve cover torque values are in the 6.5 lb-ft. range. For these critical fasteners, a 1/4" torque wrench is a necessity, as accuracy will be the highest. Your typical 3/8" torque wrench cannot accurately secure a fasteners at less than 16-18 lb-ft.
  12. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,961
    Wellington, FL
    Duane
    We used to use Seekonk torque wrenches on our precision machinery.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    If you are serious with torque, you need 3 wrenches:
    5-25 ftlbs
    15-75 ftlbs
    25-150 or 250 ftlbs
    You likely will find them in 3/8 and 1/2 inch size. An accurate 1/4 size tw is hard to find.
    Some people don't like Sears but i found the 3/8 inch sears ones to be very accurate and quite adequate for home use. I do have the older ones. The inch-lb one is at least 15 years old and still calibrates to 3-4%. I don't like the newer 5-25lbs sears version today because of the handle-adjuster design.
    As far as torquing values, +/- 5% is all you can expect to get. If you set a torque wrench to 40 lbs and torque away until it clicks, and you actually get to within 38-42 lbs, then you are a very good mechanic.
  14. shmark
    shmark F1 Rookie
    Oct 31, 2003
    2,968
    Atlanta
    Mark
    The most versatile is a 3/8 100lb-ft wrench. That will cover most of the things you need to do. If you're filling out a torque wrench toolkit you'll need three more - a 3/8 25lb-ft and a 1/2 250lb-ft, as well as a good beam-type so you can check the condition of the clickers.
  15. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    got a nice 3/8 CDI(snap-on) 5-75 ft lbs w/NM scale as well. Certified- $119
