296 GTB. died | Page 6 | FerrariChat
296 GTB. died
Discussion in '296' started by dan7777, Aug 29, 2023.
  1. BG259
    BG259 Karting
    Aug 20, 2009
    152
    My understanding is the car has a hot V. Ie the turbos are inside the V of the engine. The engine as far as I understand, does away with a normal intake manifold (which are mostly plastic these days).
    Hot V engines are not new. F1 has been using them since 2014. Major manufacturers bmw, audi and Mercedes use them.
    Increasing the water jacket size is normal to dissipate thermal load caused by 830hp.
    The 296 creates a huge amount of heat with its hybrid pack, but if you carefully watch the engine thermometer you will see that the temperature is controlled very very well even in 30deg+ temperatures.
    I have had a 296 GTB and GTS and have not suffered any issues to do with the car dying out (yet!).
    I did get an issue on my GTB when I started it after 3 hours of use (and 2 hours sitting) where a plethora of lights came on( but I was seriously low on fuel). I had the engine light come on, a misfire and lots of warnings (no hybrid or battery warning’s). I put it down to being very low on fuel. It was fine after refuelling.
    I personally think Ferrari has done an epic job and has really pushed the envelope. They have done an excellent job on the engineering side.
    You will always have issues with electric systems for hybrid cars in their nascent form.
    You must remember, Ferraris are made in very low numbers and as such any issues will show up more readily.
    I have owned Ferraris for 18 years and I think they have done an incredible job with the 296. I just think the styling is a bit soft !!!
  2. To be fair, and I am by no way a Ferrari apologist, but all cars put out "Cheronble heat" -- hybrid, ICE, and basically anywhere in between.
    Clyde Romero likes this.
  3. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    the temp reading on the gauge is the water temp not the under hood temp where the plastic is which if you took an IR gun reading you would be amazed on the difference in temperature. Plastics don’t take well to constant heat and cooling, they tend to warp and crack.
    Your ownership of Ferrari’s is noble. I have owned them and worked on them since 1986, you can do the math!
    Bottom line as far as I am concerned a vehicle with a sticker price well north of $400K shouldn’t have plastics anywhere near the power-plant, but that’s just me. If I were an owner of this vehicle I would buy those pieces as spare parts now, while they are available. I firmly believe that there will be an aftermarket fix for this substandard design issue on a high performance vehicle. With regards to the engine hydraulic engine dampers, all you need is one to fail and it will be catastrophic considering the rpm’s this engine turns. I realize and so does Ferrari that most owners drive less that 1k a year on their vehicles, so they are betting on the safe side. Good luck with both of your 296 vehicles, I will be watching this car very closely.
  4. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    Yes I agree but most US vehicles have ample room around the engine bay, don’t have sealed bottoms, and have ample radiators to dissipate the heat better than any of the 8 cylinder Ferraris lately. You can take an IR gun to the engine bay of any of the US high powered iron and you will see what I mean. Heat kills engines pure and simple. If you have ever looked at a modern day Ferrari radiator you will see how small it is, vs how much heat it has to get rid of.
    Just think of it this way, if you have an OAT ( outside air temperature) of 90 degrees the Highway surface is at least 100 plus. You are now pushing 100 degree air thru a radiator that has a thermostat set at 190 with your thermal limit on that vehicle at 220. And that’s with a perfectly operational system and fans. A dirty Raditor or an inoperable fan and your toast!
  5. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,600
    Austin TX
    https://www.caranddriver.com/features/a39187844/ferrari-mclaren-120-degree-v-6/
    Il Tifoso and of2worlds like this.
  6. Hocakes
    Hocakes Formula Junior
    Apr 24, 2010
    492
    FL
    Going to assume this is a typo or translation error & is supposed to say intake pOrts.
  7. Scott simpson
    Scott simpson Karting
    Jan 1, 2021
    62
    Hold Your Horses
  8. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    956
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    I like the fact that Ferrari used the short stroke and wider cylinder spacing for cooling. This engine is running in the 499 P and won LeMans and in the GT3 class and won the 24hr. of Nurburgring. I am not as concerned as Clyde about the plastic intake runner as Ferrari has significant experience with such composites. If it fails, there will be a replacement in some exotic metal-- at Ferrari's expense.
  9. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,600
    Austin TX
    Reminder: race car engines do not require durability as part of the design, even for a 24hr race, after such a race, the entire engine is rebuilt or retired, street cars require much more thoughtful design regarding maximizing engine life.
  10. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    JTSE30 likes this.
  11. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    You nailed it
    They were racing
    The regular owner isn’t
    Rifledriver, bamaman and JTSE30 like this.
  12. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    BJ remember the 348 issues of past, FNA could revisit this once again.
    Rifledriver and bamaman like this.
  13. BG259
    BG259 Karting
    Aug 20, 2009
    152
    Every single manufacturer uses plastic everywhere on their engines now. It is not only weight saving but cost saving. I agree manifolds should be made out of metal, but you cannot build such finely balanced intake manifolds out of metal for modern era hybrid cars. The car would weigh over 2 tons if every plastic engine part was produced in metal.
    By using composite materials for intake manifolds, which car manufacturers have been doing for at least 20 years, they can keep overall weight down.
    Don’t get me wrong, I do not disagree that a plastic part will eventually faiil, but I do not think it will be due to temperature. It will be due to poor manufacturing and design.
    And 1986. Wow that’s some ownership of Ferraris right there. Congratulations on a long stint! Let’s all just remember how blessed we are to own and drive these amazing machines courtesy of one Enzo Ferrari.
  14. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
  15. Alex HH
    Alex HH Karting
    Dec 11, 2021
    87
    Zhuhai (China)
    Alexis H
    When this happens to me, I just smile and pose for the picture. The best luxury is driving a Ferrari and not worrying about it :cool:
    willcrook likes this.
  16. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    Yes there is a lot of plastic in modern day cars, but paying over $400k for a vehicle and having an engine that has thermal issues from the start and locating such a crucial part made out of plastics should not happen.
    it’s a like the space shuttle challenger accident, they knew better !
    And we all know what happened there!
    Rifledriver and alex like this.
  17. Eilig
    Eilig F1 Rookie
    4,266
    Tänzelndes Pferd
    I can think of quite a few adjectives that more accurately replace that word "brave"
    TheMayor and Rifledriver like this.
  18. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,600
    Austin TX
    On the 'face' of it, yes, but, as for literary reference, @TheMayor is rather spot on..at least in the idea of total control of the population
    Huxley's dystopian novel describes a future society in which technological and medical innovations are used by the state to exercise control over its citizens.
    https://www.bl.uk/collection-items/brave-new-world-by-aldous-huxley#:~:text=Aldous Huxley's novel Brave New,exercise control over its citizens.
    bamaman, Rifledriver and Eilig like this.
  19. Eilig
    Eilig F1 Rookie
    4,266
    Tänzelndes Pferd
    Hadn't even considered that! In that regard, spot on indeed!
    JTSE30 likes this.
  20. omercan
    omercan Formula Junior
    446
    omer can
  21. Rifledriver
    37,299
    Much of what you say is true but there are other considerations. Those plastic parts are being routinely replace in dealers and repair shops all over the country. For a BMW or a Ford it is at a reasonable price. We all know a major component like that will be a considerable expense from Ferrari. Additionally the Fords and BMWs a small percentage will still be on the road in 20+ years and both companies have a very good reputation for for parts supply for older cars. Ferrari on theother hand has a very large percentage of old cars still on the road and their reputation for supplying parts for older cars is dismal in comparison. Making parts with planned obsolescence has a very different impact on these cars. It would be different if Ferrari cared. They do not and everyone in the Ferrari service industry knows that very well.
    willrace, willcrook and JTSE30 like this.
  22. Rifledriver
    37,299
    I also found it interesting after a brief search I found no online source for Ricambi Originali parts for 296 just to see what some of those prices are now.
  23. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,350
    Iain
    LVP488 likes this.
  24. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    I have worked on a lot of powerplants in my day this one while installed in a vehicle would be a major challenge.
    The engine bay is extremely tight and doesn't allow for much room.
    of2worlds likes this.
  25. Clyde Romero
    Sep 6, 2019
    765
    Atlanta Georgia
    Clarence Romero
    Truer words were never spoken, my guess is that the long-time owners of these vehicles will find out the hard way on parts availability.
    Or buy parts from wrecked cars.
    But once again the average Ferrari owner rarely drives the car more than 3K a year!
    Rifledriver likes this.
