296 Spacer Talk | Page 2 | FerrariChat
296 Spacer Talk
Discussion in '296' started by soulsea, Mar 20, 2024.
  1. soulsea
    soulsea Formula 3
    1,402
    29464
    Yes … I bought extended bolts with the spacers.
  2. nlpamg
    nlpamg Karting
    Oct 18, 2014
    101
    I assume the car has height adjustments collars (similar to coilovers) that allows you to lower it on the stock suspension?
  3. soulsea
    soulsea Formula 3
    1,402
    29464
    It do.
    nlpamg likes this.
  4. jimmyb
    jimmyb Formula 3
    Dec 26, 2005
    2,220
    Charlotte, N.C.
    James Bookout
    The spacers are not bolted to the hub?
    On my C8, I put Paragon 20mm spacers and they bolt to the hub using the original wheel studs and the spacer itself has wheel studs (the wheel bolts to the spacer)
  5. soulsea
    soulsea Formula 3
    1,402
    29464
    That’s not how wheels work on a Ferrari and other European cars. There are no bolts attached to the hubs that you guide the wheels over and then use lugs to secure. Wheels are attached with five long bolts that go through the wheel and screw into the hub. So if you put spacers you just need longer bolts.
    nlpamg, Thecadster and RoadRonin like this.
  6. jimmyb
    jimmyb Formula 3
    Dec 26, 2005
    2,220
    Charlotte, N.C.
    James Bookout
    Got it. Thanks. Different ways to skin the cat
  7. E63 BiTurbo
    E63 BiTurbo Rookie
    Dec 3, 2016
    19
    Does your car have the front lifter? I'm told that cars with the front lifter cannot be lowered more than 2mm but I'm having a hard time believing that.
  8. soulsea
    soulsea Formula 3
    1,402
    29464
    Yes I have the lifter.
    I’m happy to connect my dealer’s service dept with yours if that helps.
  9. JesseRohr
    JesseRohr Formula Junior
    267
    Austin Texas
    Jesse Rohr
    Melons, jm2 and soulsea like this.
  10. E63 BiTurbo
    E63 BiTurbo Rookie
    Dec 3, 2016
    19
    Thank you! That may be necessary. Which dealer do you go to?
  11. soulsea
    soulsea Formula 3
    1,402
    29464
    https://naples.ferraridealers.com/en-US
    You can reach out to Brian at service and he’ll get the info from the tech for you. I’m pretty sure mine is the only Grigio Alloy GTS they have done it to.
  12. E63 BiTurbo
    E63 BiTurbo Rookie
    Dec 3, 2016
    19
    Car looks really good with those wheels! what finish are they and do you know how much it was lowered?
  13. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,334
    michigan
    john
    Looks great!
  14. JesseRohr
    267
    Austin Texas
    Jesse Rohr
    The finish on the wheels is called Miami White. It's one of the solid powder coat colors available from Vossen. That is who manufacturers the wheels for Novitec.
    Lowered 13mm rear and only 5mm up front (level to my eye). The car could physically be lowered more but my driveway and much of the city don't allow for it.
