296 THREAD for mods (aftermarket wheels - springs - exhaust - stripes - body kit) | FerrariChat
Discussion in '296' started by RobertM, Jul 10, 2023.
  1. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,442
    Weston, Florida
    Robert M
    thoughts on having one thread to discuss aftermarket modifications to the 296 for aftermarket wheels - springs - exhaust - stripes - body kit, etc.
    Scheki, ryalex and jm2 like this.
  2. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,908
    michigan
    john
    Great idea. Always interested in wheel choices.
    of2worlds likes this.
  3. Scheki
    Scheki Formula Junior
    Jun 10, 2020
    342
    Scheki
    And in aftermarket exterior CF !! (no wings, just the regular stuff that is 20.000€ when bought from Modena)
  4. soulsea
    soulsea Formula 3
    1,355
    29464
    I plan to just lower it on stock springs (assuming that's still possible with this model) and make it flush with spacers.
    Does anyone know if the proper setup is 15/20mm or something else?
  5. Kmaaq
    Kmaaq Formula Junior
    Jul 26, 2019
    602
    Qatar
    Khalid Mohammed ALQattan
    Asked my dealer, said it’s not possible. Apparently alignment and height adjustment don’t even require manual labor anymore.
  6. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,442
    Weston, Florida
    Robert M
    mdrums likes this.
  7. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,442
    Weston, Florida
    Robert M
    what are the wheel sizes and offsets being installed on the 296 ??? example 21x9 ET30 and 22x12 ET30.... than is what was on my F8
  8. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,442
    Weston, Florida
    Robert M
  9. 488gtbmasergt
    488gtbmasergt Karting
    Oct 18, 2016
    169
    this is what I wrote one another thread...
    21 inch wheels front and rear
    21X9.5 ET38 with 245/30/21
    21X12 ET35 with 315/30/21
    I would advise against both so called "recommended" specs (or springs) from Novitec or any advice or useful help/knowledge from Tag...
    I will post more info in the next few days about lowering or spring rates (at least OEM ones).
    I intend to drive my 296 as it was intended by Ferrari on and off the track (but not with those wheels of course)
  10. soulsea
    soulsea Formula 3
    1,355
    29464
    Are those Novitec wheels?
    The offsets are off.
  11. 488gtbmasergt
    Oct 18, 2016
    169
    there are no "Novitec" wheels... they are Vossen's.
    I will look tomorrow for the offset numbers. The one I mentioned above were given to me by TAG by email but I did not visually checked them before the install.
  12. 488gtbmasergt
    Oct 18, 2016
    169
    Here is the final result.
    The Novitec springs will need to be removed as soon as I get the custom made ones. if anyone in Switzerland is interested I will sell them really cheap. Same for 2 new Michelin 255/30/21 PS4
  13. 488gtbmasergt
    Oct 18, 2016
    169
    I also have measurements for the springs:
    OEM:
    front at 70kg/cm2 (not sure about the units)
    rear at 80kg/cm2
    Novitec:
    front at 70kg/cm2
    rear at 110kg/cm2
    Sorry if the units do not make sense. I am no good in physics. But the numbers are correct (the ones measured by the mechanic himself).
    Lowering:
    I measured from the "flat" ground to the middle of the wheel well..
    front: 6780mm
    rear: 7250mm
    happy to provide more details if I can...
  14. soulsea
    soulsea Formula 3
    1,355
    29464
    Out curiosity, is there a reason you're not lowering it as much as possible on the stock springs?
    Or is that been confirmed as not being an option on the 296?
  15. 488gtbmasergt
    Oct 18, 2016
    169
    with the original gap (especially at the rear) it did not seem it was going to fulfill my goal to just lower it on the original springs. Let alone that I am not clear if that would negatively alter the dynamics of the car to go that route...
    at the end of the day, I will order stiffer springs all around...
    I am tracking my car once in a while. and when i do so I really push it hard.
    OEM springs are a little too soft for me anyway...
