2EEA error - Replace coolant temperature sensor? | FerrariChat
Discussion in 'Technical Q&A' started by pexogoce, Feb 19, 2023.
  1. pexogoce
    pexogoce Karting
    78
    pexogoce
    E46, 316i, N46, Touring 2007 year
    Car is working fine, but I have constantly recurring error:
    2EEA CDKTKA - Temperaturfuehler Kuehleraustritt
    P2184 Motorkühlmitteltemperaturfühler 2 - Input niedrig
    Error counter: 36
    Logistic counter: 40
    1. Umweltsatz
    Mileage 220610 km
    Motordrehzahl (nmot) 2640.00 /min
    Motortemperatur (tmot) 24.75 Grad C
    Umgebungstemperatur (tumg) 6.75 Grd C
    ADC TKA (adtka) 5.00 V
    2. Umweltsatz
    Mileage 220620 km
    Motordrehzahl (nmot) 1520.00 /min
    Motortemperatur (tmot) 57.75 Grad C
    3. Umweltsatz
    Mileage 221000 km
    Motordrehzahl (nmot) 0.00 /min
    Motortemperatur (tmot) 12.75 Grad C
    Umgebungstemperatur (tumg) 9.75 Grd C
    Kurzschluss nach Plus oder Leitungsunterbrechung
    Testbedingungen erfuellt
    Fehler momentan nicht vorhanden, aber bereits gespeichert
    Fehler wuerde kein Aufleuchten einer Warnlampe verursachen
    Diagnose aktiv
    Zyklus-Flag gesetzt
    Error code: 2E EA 22 05 21 84 24 28 56 2D 42 61 49 FF 56 2E
    26 8D 49 FF 56 54 00 51 4D FF
    Have someone met this problem? What was the solution?
  2. pexogoce
    pexogoce Karting
    78
    pexogoce
    thanks, for any help
  3. wmuno
    wmuno Formula Junior
    513
    Wilmette, Illinois
    Bill Muno
    FYI, E46 is a 3 Series BMW. I have a 2004 325ci, but never had this error code. The back of the service manual has a list of error codes; they all start with a "P" followed by a 4-digit number.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,392
    San Carlos, CA
    Mitchell Le
    First, you know this is a Ferrari forum, correct? Ferrari knowledge runs deep, BMW not so much although many of us own and drive BMWs (me included).
    You have over 200,000 kms on the car, and while I don't know where the coolant temp sensor is on the Bimmer, it cannot be expensive to change it out. My practice on my own E61 BMW (5 series) is to change out the entire cooling system every 100,000 miles. That includes: radiator, coolant tank, coolant hoses, water pump, and thermostat. I probably should add the coolant temp sensor to that list at 200,000 miles coming up here.
  5. pexogoce
    pexogoce Karting
    78
    pexogoce
    thank you so much for your suggestion
  6. f355spider
    f355spider F1 World Champ
    18,028
    I do the same on my E39 540 M-Sport...been through three "cooling system overhauls" over the years. I also add the fan clutch, valley pan and a few other things...one and done for another 100k. I passed 347,000 miles this weekend... Image Unavailable, Please Login
  7. yelcab
    Nov 29, 2001
    13,392
    San Carlos, CA
    Mitchell Le
    I started doing that since all BMWs I have owned broke down right at 100,000 miles like clockwork. The neck of the radiator breaks, or the water pump goes, or the coolant hoses, so they all get changed out at the same time on every BMW I own. For radiators, I only buy from the dealer. The after market ones don't seem to fit, have all accessories, or work at all.
    f355spider likes this.
  8. f355spider
    18,028
    I've done the same...though I try to buy from the original equipment supplier where possible. It bit me a couple years ago when I bought the Behr expansion tank OES online and the thing kept throwing "low coolant" warnings. I tried to diagnose the issue and even swapped out the sensor, but still happened. I think the float was messed up inside the tank, but seemed to be freely moving. Tons of negative reviews on FCP Euro....so I ordered a factory BMW one...also made by Behr. Works perfectly. The BMW/Behr one is made in Germany, the OES one by Behr is made in China...go figure.
    Never had an issue with the OES water pump. Both BMW and OES are Saleri and both made in Italy. $200+ price difference
  9. yelcab
    Nov 29, 2001
    13,392
    San Carlos, CA
    Mitchell Le
    I have learned to buy factory OEMs on certain things. Radiators, coolant tanks, thermostats, water pumps are those that I only buy from dealers. Especially on cars driven by the women in my life (wife and daugters). Those girls will drive the cars with the engine light flashing until the cars go no more. It's best to just avoid those things that break.
  10. yelcab
    Nov 29, 2001
    13,392
    San Carlos, CA
    Mitchell Le
    I have Behr radiators made for BMW leak right out of the box. I have Behr radiators made for Audi missing mounting brackets for the fans and the fan controller. The aggravation is so much that $500 for a dealer radiator seems so small.
  11. f355spider
    18,028
    My experience with Behr radiators whether from dealer or OES is mixed. I have had both fail early (less than 50k miles).
