2nd gear is stiff | FerrariChat
2nd gear is stiff
Discussion in '348/355' started by ferrari930, Jun 18, 2013.
  1. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    Second gear is stiff to push into, is that normal for the 348's? Its the same whether im going from 1st to 2nd or 3rd to 2nd, ok maybe 3rd to 2nd is a little bit easier but not much, theres no graunching or any noises at all, its just really stiff to put into 2nd, anyone else have this problem? I know the dog leg boxes arent great but on a 348 what other choice is there. I will change the oil and see if that helps but if anyone else has this problem please let me know
  2. Dazzling
    Dazzling Formula 3
    Nov 18, 2010
    1,133
    Adelaide
    Darren
    Have you tried a search? There are quite a lot of threads on Fchat on this subject :)
  3. Chupacabra
    Chupacabra F1 Rookie
    3,584
    Behind a drum kit
    Mr. Chupacabra
    Perfectly normal, unless it persists after the car has warmed up. With a few caveats...
    At any temp, my car (and from what I hear many others) doesn't like being shoved into second in about the top of the bottom 1/4 of the rev range. She either wants to be wound up and shifted quickly or not spinning fast at all and gently guided in.
    At any rate, just make sure you do not do anything the car doesn't want to do (you will know) and you should be fine.
  4. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    most of the 348's do it to some degree.
    Lots of posts including some of my own gear oil experiment.
    shuffle from 1st to 3rd until she warms up..
    as previously mentioned, don't force the car to something she doesn't want to...
    try changing your gear oil (or having it changed) to some of the recommended ones. Should help it out.
  5. Lfpontes
    Lfpontes Karting
    Nov 1, 2010
    141
    São Paulo
    Luiz.
    I think it is normal. I've had the same "problem" in my F355 since I bought it. Once all the fluids are warmed-up, it ****s much smoother.
  6. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Quite Normal but some will say theirs don't do it. I just go 1st to 3rd until up to temp, simples.
  7. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    thanks guys, i feel much better now, phew!
  8. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    so looking at other threads it seems the Redline Superlight Shockproof Gear Oil is the stuff to use? What is the best oil to use to fix this problem, I dont care about the cost.
    So you drain ALL the oil from the transmission and refill it with ONLY this oil above? (or similar oil)
  9. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Yes and yes - see the link in post #3. I changed to the superlight about a week ago and this is after doing a change using the "proper" NS about 2 months ago which made no difference. Gearchange is so much nicer now even from cold.
    In the UK it cost £85 for 5 litres (you need 5 as each bottle is slightly less than 1lt and the box takes 4 lts)
  10. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    perfect advice, thats exactly what I wanted to know, thanks jeff
  11. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    Jeff, do you have a better pic of the label on the bottle that you used, i see theres a few grades and i want to get the right one, cheers
  12. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #13 348Jeff, Jun 19, 2013
  13. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    perfect! :)
    so while we are on the subject of oil, whats the best stuff you guys use for the engine? May aswell do the engine oil at the same time i guess
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Shell Helix Ultra 5w40 - you need 11ltrs
  15. ferrari930
    ferrari930 Karting
    Oct 28, 2011
    96
    lol, Jeff you really are the Encyclopedia of Ferrari, thanks mate
  16. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I use Red Line 10W40
  17. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Liqui-moly 5w-40 full syn.
    Mobilized reply by David
  18. YVR_Schumi
    YVR_Schumi Karting
    May 20, 2012
    103
    British Columbia
    +1 on Liqui Moly 5w40.
  19. gaw111
    gaw111 Formula Junior
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    WOW, what a difference!!! I put the Redline in and had instant gratification. The car shifted from 1st to 2nd and back no issues. Shifting through all gears was better, most def the best option to what Ferrari recommends.
  20. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    I'm not affiliated with the seller. My research shows this is a good price for Red Line products so want to pass it on to fellow f-chatters. I recieved my order in approx. 5 days. There seems to be few bids so I waited till the end of the auction and purchased one case for $70.00 + shipping.
    Sorry for the poor copy of the ebay listing. Not sure what the problem is. Search for Red Line Superlight Shockproof gear oil and look for seller autochic1
    Red Line Synthetic Superlight Shockproof Gear Oil, Case of 12 Quarts
    Seller : autochic1 (170 ) 100% Positive feedback
    Save this seller | See other items
    Item condition:New
    Time left: 6d 12h (Sep 04, 2013 04:48:47 PDT)
    Starting bid:US $70.00
    [ 0 bid ]
    Place bid
    Enter US $70.00 or more
    Price:US $100.00 Buy It Now
    Add to Watch list
    Shipping: $27.19 Standard Shipping | See details
    Item location:
    Dover, New Jersey, United States
    Ships to:
    United States
    Delivery:
    Estimated between Fri. Sep. 6 and Thu. Sep. 12
    Includes 5 business days handling time after receipt of cleared payment.
    Payments:
    Visa/MasterCard, Discover, Pay on pickup | See details
    Returns:
    14 days money back, buyer pays return shipping | Read details
    Learn more
  21. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Death, taxes, and stiff 2nd gear in Ferrari.....
  22. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    I seen that on ebay, I didn't see it again after it ended. That is a great deal on it! I ended up paying 15.00 per qt free shipping on ebay. Still not bad compared to other sites I've seen.
  23. gaw111
    Sep 24, 2012
    662
    Rainelle WV
    George Wheeler
    It really fixed my problem! No grind, no clunk! It felt great, 1st time I've felt it feel so good. That was straight from install, no warm up!!!
  24. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    I was only just thinking yesterday about giving an update on this and was just to say that it just gets better and better with the more miles I do :)
    No brainer to do IMO
