2nd Gear Synchro | FerrariChat
2nd Gear Synchro
Discussion in '206/246' started by Crawler, Nov 20, 2006.
  1. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    There surely is a thread somewhere dealing with the issue of 2nd gear synchromesh... What's the best way to deal with it until things warm up? I've tried skipping 2nd altogether (not very satisfactory). I've also tried pausing for about two seconds in neutral and / or double-clutching on the upshift.
    Of course, everything's fine once it warms up.
  2. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Dan - skipping 2nd is the most efficient solution. However, the newer gear oils, specifically one used by the Ferrari service shops, has a reverse heat-viscosity characterisitc such that it is less viscous when cold and more viscous when warm. I apologize but I do not know the brand names of the various products, but I am sure the brain trust on this Chat will rise to the occasion.
    I have used the product now in my Dino and it does significantly help.
    Jim S.
  3. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Flip it out of first and then feel it into second. Practice until you can match the revs, then she should be OK.
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Redline 75W90NS
  5. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    I wrote about my fixes in the May 8, 2005 Saga.
    http://ferrarichat.com/forum/showthread.php?t=70700&highlight=050814
    Still OK after Engine and transmission all apart and back together. Regular Valvoline gear oil is fine after trying special oil for a week and not liking feel. My car is now at 190,000 miles.
    A lot of the problem is probably wear in the universal joint and pin coupling in the shift linkage. Hard to get in there and lube things but worth pulling the access plates occasionally to look at throttle, shift and brake linkage. Opening the casting and gate compensates. Let us know what you find and what you do.
  6. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Agree completely with the above- it has always worked in my car.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    One of the most alluring features of the Dino is that the driver must "learn" the feel of the car. The driver is an integral component in operating the Dino, this is an excellent example.
  8. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    Maybe, but it's only for like, the first two miles...
  9. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    In general you should warm up the car for a few minutes or drive it with feeling for the first couple of miles. Same as some other Italian cars (Alfa)of the period. Must have gone to the same font for water:)
  10. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    Is there another oil brand I can try if I can't find Redline75W90NS?
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I'm running Swepco 201 in my Euro Dino on advice of a vintage racer and it performs very well.
  12. dm_n_stuff
    Dec 10, 2003
    43,715
    26.806311,-81.755805
    Dave M.
    Swepco is recommended by lots of Porsche guys. Hadn't thought about it in some time.
    Just ordered some, ($37 a gallon) gonna pop it in the gearbox this service cycle, see if it keeps my newly rebuilt box running well.
    FYI, even with new synchros and sleeves, my 2nd gear can be a little touchy when the car is cold. It works, but you need to show some care when slipping it into gear.
    I may try John C's suggestion as well.
    DM
  13. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    You've pointed out one of the downfalls of synthetic, the limited slip modifiers in them can interfere with the synchros engaging. Hence the Redline choice of 75W90NS where the NS means it does not have the limited slip modifiers.
    Ribolla_67 likes this.
  14. dm_n_stuff
    Dec 10, 2003
    43,715
    Dave M.
    We use redline in some of our large presses at work as gear oil precisely because it doesn't have a ton of additives.
    DM
  15. dm_n_stuff
    Dec 10, 2003
    43,715
    Dave M.
    SWEPCO!!!
    In the car.
    Mechanic noticed the improvement.
    Drove it home.
    Much improved. Highly recommended. Nothing else is going in my Dino, ever. And, the mechanic is ordering it, too.
    DM
  16. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    I tried several slick synthetic gear oils and had trouble grinding going into second with my Dino. I changed to Redline NS and now it shifts perfectly.
  17. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    That's not an uncommon complaint. Synchros depend on a certain amount of friction to do their job. Take it away with too "slick" a lubricant and they stop working.
