2V IDF/IDA/EFI manifolds | FerrariChat
Discussion in '308/328' started by derekw, Jan 29, 2022.
  1. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I finally have a reasonable offer for the IDF/IDA manifolds. They will be $600 a pair for 25 sets. I haven't figured out the throttle linkage but plan to use the threaded bosses on the two tubes to mount something. I'll get 30mm nipples that screw into the central water passage.
    Casting in a single piece was not going to be viable for a short run so I got pricing on cast tubes machined and welded into machined flanges and then heat treated. They'll be in A356T6 aluminium.
    The MOQ is 25 pairs and I am prepared to sit on max 10 to flog on ebay so need 13 people to make this fly as I'll keep two for myself. If we get fewer people the price jumps up to about $700 to get cnc machined tubes instead of cast.
    Weber IDFs and IDAs will fit under the engine cover with short trumpets (15mm) and shorter ITBs like the Jenvey and SherryBerg IDF replacements would allow a longer trumpet. For air filters I plan to find or make baseplates that drop the filters down around the carb to allow taller filters and still sit under the deck.
    Let me know if you are interested. As with my other group buys I'll take a small deposit before I pay for the tooling. If you would rather get one soon for $700 I can get the non-cast version for you.
  2. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    277
    Australia
    Hi Derek, are you talking USD or GBP?
  3. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    USD. Not sure of shipping costs yet but will try to get them sent directly to you (or a few to one person for forwarding in-country.)
