3.2 Carrera oil burning question | FerrariChat
Discussion in 'Porsche' started by johng, Apr 17, 2008.
  1. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    i am considering purchasing a 1987 911 cab with 190K miles on it. it drops a little oil (a few drops) and has smoke on start up, per the owner. compression is 170, 175, 165, 170, 175, 170..with leak down numbers "very good." the owner states he has to fill about a quart of oil every 800 miles. i would appreciate others' opinions if this is too much. i am under the vague impression that up to 600 mi/qt is ok.
    thanks
    john
  2. 356racing
    356racing Formula Junior
    Sep 24, 2004
    541
    Paradise Valley, AZ
    The smoke at startup is a sign the valve guides are worn, and that's a lot more oil than my 3.2 with 87K burns but not the end of the world for a weekend fun car. Leakdown within 10% is OK, are you getting a good enough deal to cover a top end rebuild in the future?
  3. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Boxer engines do burn more oil than V type ones. I know the OM of my BB512i indicates one liter per 600klms is normal...although my car does not burn nearly that amount...more like 1 liter per 2000klms...
  4. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    thanks for the responses...the deal is not good enough to cover a rebuild if it comes to that.
  5. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Surely (with 190K miles) it has had a top end done sometime in the past?
  6. davem
    davem F1 World Champ
    10,717
    Stepford, Connecticut
    dave m
    Yes but with those miles might still need another.
  7. thecarreaper
    thecarreaper F1 World Champ
    18,071
    Savannah
    i am on my second 3.2 911, and i love them both have around 140k on them, and have both have had the top end redone. my black 89 911( 25th anniversary edition) uses maybe 1 quart in 3 months, i dont put that many miles on it, and it did puff a bit of smoke when i got it, but it does not do it anymore. i added a can of BG MOA to the oil at the last oil change, and it seemed to help. given the lack of zinc in oils now, i change my oil every 300 miles, or in my case, every 6 months.
    i sold my green 84 911 to a buddy and i see the car and keep up with how its running on a regular basis. no oil issues with it either.
    the 3.'s are great cars, and the last of the good 911's to me.
    i will never own a newer Porsche than an 89 911.
  8. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    i don't think it has had any kind of rebuild even at 190K miles. these are very durable cars.
    carreaper, you can get motul oil, it has the zinc in it.
  9. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    John G , you may want to got Pelicanparts.com or rennlist.com if you have not already. They are the F-chats of the Porsche world.
  10. thecarreaper
    18,071
    Savannah
    thanks, will look for it.
  11. BoulderFCar
    BoulderFCar F1 World Champ
    13,187
    Asheville, NC/Ft Lauderdale
    Tom
    The oil per miles is OK but I don't like consistent smoke at start up. As mentioned above, it points to guides. I've had 15 911's and it's never just an easy top end job and they are still expensive to rebuild. I would take my time and find a car via the Porsche club or one from a Pcar fanatic. I don't know what you're talking about for a purchase price but you can probably find one that has a sound motor (maybe swapped) that will save you some time, money and aggravation for a small premium.
    Even though parts are available and they aren't as expensive as FCars I would stay away from a 911 that is going to need major work. A clutch, no big deal. Getting into the engine will get pricey in a hurry. Good luck with your search and with whatever you buy.
  12. luke9583
    luke9583 Formula 3
    Nov 8, 2003
    1,322
    Detroit Michigan
    Luke Wells
    It's more of an issue with the 3 liter engines (1978-1983) but check for head stud issues.
  13. Tony F.
    Tony F. Rookie
    Nov 24, 2004
    19
    my 87 with 66K miles is going through a quart every 600-700 miles. Occasional puff on start-up. I drive mine everyday, and it has been dead reliable. I would not hesitate to drive it cross country tomorrow. Great shops in NVA too- I like Jose at Autobahn. Once you get used to Ferrari prices, nothing on a 3.2 Carrera should scare you. When and if mine needs motor work done, I may just swap in a 3.6L motor instead.
    My only regret is not having a 911 sooner. Personally, I would look for a cab with less miles unless its otherwise exactly what you want. Fantastic car.
  14. Mojo
    Mojo Formula 3
    Sep 24, 2002
    1,293
    Washington St.
    Joseph
    The 2.7 liter's we known for bad head studs 1974 to 1977.
    But most are fixed by now.
  15. luke9583
    luke9583 Formula 3
    Nov 8, 2003
    1,322
    Detroit Michigan
    Luke Wells
    The 3 liters had some serious issues as well. They definitely outlive 2.7's but out of the 5 911sc's I drove, 2 had noticeable weak head studs.
    They will make a distinct 'flapping' noise under WOT.
