3.2 Engine Running Rough After Hitting Pothole | FerrariChat
Discussion in 'Mondial' started by 328tobe, Apr 9, 2014.
  1. 328tobe
    328tobe Karting
    Apr 7, 2012
    64
    Northern VA
    Luuda
    I have an 1986 3.2 US Spec Mondial. I was able to change the accelerator cable this past Sunday and car was just running great. Drove around for hours just enjoying the car and how smooth and easy the gas pedal was. About 2 traffic light from home, I hit a pothole and right after, the car would not idle. Next day, I started the car and it would idle roughly. Pressing the gas pedal does not do anything but cause the car to stall. Same if I rev the engine at the throttle body. I checked all the vacuum hoses that I removed to get to the accelerator cable and they are all in. Is there anything else I need to check? Thanks everyone!
  2. Brian420
    Brian420 Formula Junior
    Oct 27, 2009
    469
    Suburb of Detroit
    Brian
    And here I thought Michigan was the only place with pot holes. Same thing happened to me a couple of years ago. It shook loose the ignition control unit that's in the trunk, passenger side I think. I took it in, and after I described what happened, that's the first thing they checked. Had it diagnosed and fixed in an afternoon. I couldn't tell you how to fix/adjust it. I think they just bolted it down better. I hope this helps.
    Regards,
    Brian
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    First check for your symptom (and chain of events) on your model (K-Jet with Lambda) is to confirm/deny if the frequency valve is "buzzing", or not, when the engine is running (it should always buzz whenever the engine is running, cold or warm).
    Alternatively, you can unplug the safety switch, and just turn "on" the key (engine not running) -- the fuel pump should run and the frequency valve should buzz.
  4. 328tobe
    328tobe Karting
    Apr 7, 2012
    64
    Northern VA
    Luuda
    I needed a place to start looking... i hate just not knowing where to begin the troubleshooting. With Brian's advice, i was able to look at the trunk on the passenger side under the antennae. There was a control unit that was not tighten down and when i lifted that up, I saw that one of the relay was knocked off. Also, one of the wire was fraying as well so i just redid the wiring and the car started like it did before. And I did notice the buzzing as well Steve. Thanks a lot guys for the advice!!!
    Luu
  5. Faber
    Faber Formula Junior
    May 5, 2011
    954
    TX Hill Country
    Tom G.
    Interesting - thanks - where/what is the "frequency valve" and where does one unplug the safety switch? Thanks,
  6. Steve Magnusson
    26,822
    Click Search - Advanced Search - enter "frequency valve" for the keywords and my user name in the user name box - read those ~100 threads...
    Repeat using "safety switch"...
  7. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #7 soucorp, Apr 10, 2014
  8. 328tobe
    328tobe Karting
    Apr 7, 2012
    64
    Northern VA
    Luuda
    Thanks Mike. It was so frustrating not knowing where to start and this forum definitely helped!
    Luu
  9. Brian420
    Oct 27, 2009
    469
    Suburb of Detroit
    Brian
    I almost mentioned that the person to ask would be Mike Sou. Good to hear from you Mike. I hope all is well.
    Regards,
    Brian
  10. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    Just a thought: If the air flow sensing plate (or any related lever) had touched/moved/bent out of normal position during the pot hole vertical high-g event, it could cause all sorts of weird behaviour, couldn't it? Easy enough to check.
  11. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    Crazy busy these days Brian! Until we meet again... Hope to stop by CnC this Sunday, its going to hit 80 and SUNNY !!!
    CHEERS,
  12. Faber
    May 5, 2011
    954
    TX Hill Country
    Tom G.
    Thanks Steve!
