3.2 Mondial brake light switch wiring question | FerrariChat
Discussion in 'Mondial' started by PBonneau, Aug 8, 2016.
  1. PBonneau
    PBonneau Karting
    Sep 14, 2013
    65
    Albuquerque, NM
    #1 PBonneau, Aug 8, 2016
    I have an '86 3.2 Mondial. Someone in the past inserted a 2 prong brake light switch where a 4 prong switch is required. They then connected together the remaining two wires so that my rear brake lights would work. (See photo) As a result the brake light warning system is activated every time I apply the brakes.
    I have acquired the correct 4 prong switch (see photo) and wish to make the replacement. However, I do not know how to wire it correctly. The two small prongs are labeled "1" and "2", while the larger prongs are labeled "3" and "4". The wires I have are: one large red wire, two large green wires connected together, a small red/black wire, and a small green wire.
    Can anyone please advise me which wire attaches to each prong? Thanks in advance!
    Philippe
  2. Alden
    Alden F1 Rookie
    3,601
    Central Florida
    #2 Alden, Aug 8, 2016
  3. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    #3 spicedriver, Aug 8, 2016
    I believe that I have the same switch (the new one) on my car. When I first got the car, the brake lights didn't work, but the switch looked new. I found that the adjustment was way off, and the switch would not touch the actuator. After I had adjusted the switch position, the system worked backwards. Meaning the brake lights were always on until the brake pedal was pressed. So I reversed the wires by putting the large wires on the small connectors, and the small wires onto the large connectors. The large connectors on the switch needed to be trimmed a bit. Then everything works. The console "STOP LIGHTS", and yellow warning light come on whenever you press the brake pedal, but I think this is normal. I'm guessing the new switches are different than what was originally on the car.
    The connections I have are 1. large red 2. two large green 3. small green 4. small red and black.
    Actually you can switch the 1 position with the 2 wire, and the 3 position with the 4 wire, and it will still work the same.
    So what you can try is to put the large wires onto the large connectors on the switch, and the small wires onto the small connectors on the switch, and if everything works okay, you're good. If it works backwards like mine does, then just put the large wires onto the small connectors, and the small wires onto the large connectors.
    I'm curious to see how yours works, so let us know, thanks.
  4. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Alden,
    I am impressed by the schematic, do you happen to have the entire one for the Mondial?
    cheers
    braq
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,957
    Isle of man- uk
    #5 mike32, Aug 9, 2016
  6. Alden
    Alden F1 Rookie
    3,601
    Central Florida
    Yes, I have the factory wiring manual, shoot me a PM and I will see if I can help get some info to you.
    Alden
  7. spicedriver
    Feb 1, 2011
    3,859
  8. blownfuse
    blownfuse Karting
    Jul 16, 2012
    104
    Campbell, California
    FWIW, I've used this book to troubleshoot my '88 3.2, and found many differences. Seems the factory changed the wiring scheme from year to year.
    Still a good book nonetheless...
  9. Alden
    Alden F1 Rookie
    3,601
    Central Florida
    My manual is full of handwritten corrections, as I found stuff wrong, I noted it.
    Alden
  10. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Sweet, thanks for the link, downloaded the pdf. Now would any of you also have one for the QV?
    I don't know yet how much of the 3.2's I could assume to have been carried over from the QV (or 8)?
    Cheers
    braq
  11. spicedriver
    Feb 1, 2011
    3,859
    The QV workshop manual has some electrical info:
    http://ferrari.cdyn.com/ferrari_docs/mondial8qv_workshop_281-83.pdf
  12. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    The basics are the same, but the 3.2 has a more complex HVAC, ignition and injection wiring than the QV, so those sections would not fully apply.
  13. afterburner
    3,470
    Switzerland
    Urs STEMMLER
    #13 afterburner, Aug 10, 2016
  14. PBonneau
    PBonneau Karting
    Sep 14, 2013
    65
    Albuquerque, NM
    Thanks for all the replies!
    Does anyone who has changed their switch have any tips to share before I undertake this job? Thanks in advance!
    Philippe
  15. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Yes, great stuff, thanks from my side as well.
    You will appreciate having a 2nd person to tell you when the brake lights come on while you are adjusting the switch position OR mirror OR park close to some surface so you can guess the reflection,
    cheers
    braq
  16. Alden
    Alden F1 Rookie
    3,601
    Central Florida
    Take the driver's seat out, 4 bolts and about 5 minutes to do and it will make access under the dash much easier.
    Alden
  17. spicedriver
    Feb 1, 2011
    3,859
    Not under the dash, it's under the hood. No need to take the seat out.
    Very simple, remove the wires, loosen the locknut, unscrew the old switch. Install is reverse of removal. Go easy on the plastic nut. See post #3 for wire positions. Don't adjust too much pedal pressure onto the new switch.
  18. afterburner
    3,470
    Switzerland
    Urs STEMMLER
    QV under the dash.
    3.2 on the pedal box accessible from the front trunk.
    I think.
  19. PBonneau
    PBonneau Karting
    Sep 14, 2013
    65
    Albuquerque, NM
    I have installed the new brake light switch that I purchased from Super Performance. Here's how I wired it:
    pole #1: small green wire
    pole #2: red/black wire
    pole #3: double green wire
    pole #4: large red wire
    I screwed it it about 3.5cm and snugged the nut. Now the "brake light" warning light in the center console no longer burns every time I press on the brake pedal.
    Thanks to everyone who helped me!
    Philippe
  20. afterburner
    3,470
    Switzerland
    Urs STEMMLER
