3.2 Mondial Cab. battery 66 A/h vs. 75 A/h or higher... | FerrariChat
Discussion in 'Mondial' started by 3.2Cab, Jan 12, 2008.
  1. 3.2Cab
    3.2Cab Rookie
    Dec 27, 2007
    23
    Kristiansand, Norway
    Oystein S.
    Hi,
    After approx. 7 years, I am now going to replace the battery in my 3.2 Mondial Cab.
    From what I have read on the forum, it looks like almost every part-time driven Mondial, has “some kind of” battery problem. So I wonder if I shall go for 75 A/h or even higher, 85-90 A/h…. (66 A/h has been specified in the Owners manual)
    I have no problems with the battery/electrical system, but to avoid possible problems in the future a higher specified A/h might be a good solution ??, or only waste of money ?.......
    Best regards
    Oystein
  2. mksu19
    mksu19 Formula 3
    Jan 4, 2008
    1,864
    LAX / YVR / MNL
    Capt. K. Banzon
    #2 mksu19, Jan 15, 2008
    :D WTF!? "(66 A/h has been specified in the Owners manual)" :D
  3. 3.2Cab
    3.2Cab Rookie
    Dec 27, 2007
    23
    Oystein S.
    Ok Ken, if this is how you want to contribute on this web site, I assume you are better off by choosing another hobby. However, by reading your previous inputs to this site I am highly surprised if you have ever owned a Ferrari. Well, I have seen some spoiled idiots in a Ferrari before, so nobody knows……
  4. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,697
    wisconsin/chicago
    bo
    Any battery will do, realistically. Battery technology has made quite a bit of progress over the last couple of decades. The lowest CCA you are likley to find is 500. I put a 700cca+ battery in the testarossa, was about 110$. In the US batteries are listed by CCA (cold cranking amps available), not by total amp storage. Would guess a standard battery is about 40-50amps, based on how long it takes to charge from a dead state. On my fast battery charger at 12/ah it charges from flat to full in about 4-5 hours...
    Perhaps you folks measure differently in Norway?
  5. 3.2Cab
    3.2Cab Rookie
    Dec 27, 2007
    23
    Oystein S.
    Thank you for your reply.
    The possible problem might occur when using AC/NAV/Multimedia/daylights etc… I have been told that electrical problems can occur when “overloading the vulnerable el. system” So I my question was rather simple, ie. changing from 66A/h to approx. 80-85 A/h might have a positive effect ???
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    In my 3.2 there have been two things that have helped keep the battery happy:
    1. A trickle charger
    2. When storing for a while if no charger available, turn off the battery ground using the round knob at the battery compartment.
    Typically, in a stock car without any high amp requiring mods (stereos, etc) the amperage is not as much a problem as loss of voltage (thus inability to deliver amperage) over aging wires/connections in addition to 'slow leak' short circuits as the printed card circuits in the fusebox age and delaminate.
    This is why you may also notice many of us long term Mondial owners hot for the improved fusebox hopefully coming out soon.
    best
    rt
  7. 3.2Cab
    3.2Cab Rookie
    Dec 27, 2007
    23
    Oystein S.
    I will go for the newly developed fusebox when the “commissioning period “ is over…..
    However, changing to approx. 80A/h will give a me “a little improvement” . Ok, if not, I will drop it….
  8. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    I installed a Red Top Optima in my Mondial 8.
    Charles
  9. 3.2Cab
    3.2Cab Rookie
    Dec 27, 2007
    23
    Oystein S.
    I will go for the same solution, Red Top Optima, and when the newly developed fusebox is available, I will order one.
  10. mksu19
    mksu19 Formula 3
    Jan 4, 2008
    1,864
    LAX / YVR / MNL
    Capt. K. Banzon
    This spoiled idiot apologises!
  11. 3.2Cab
    3.2Cab Rookie
    Dec 27, 2007
    23
    Oystein S.
    Ok, and thanks Ken, the war is now over.........
  12. mksu19
    mksu19 Formula 3
    Jan 4, 2008
    1,864
    LAX / YVR / MNL
    Capt. K. Banzon
    Whew! :D
  13. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    That was handled with ultimate class :) Oh, off topic - - Use a battery maintainer all the time as it seems batteries are happy only if they are fully charged. The charging system overall, is lightly taxed if the battery is on top of its game :)
    Cheers, Hank
  14. MondiAl87
    MondiAl87 Karting
    Oct 10, 2005
    69
    Sacramento Area
    Al D.
    I've found that my little plug in at the cigarette lighter, voltmeter is worth it's weight in gold. At $20 US it's helped me avoid getting stuck away from home by driving around with a low battery charge. It's nice to look over at it while driving around and see that all is well with my charging system. I do wish they kept a voltmeter as part of the dash gauges.
