3.2 motor mount hardware? | FerrariChat
Discussion in 'Technical Q&A' started by Dizengoff, Mar 30, 2013.
  1. Dizengoff
    Dizengoff Formula Junior
    Nov 24, 2011
    625
    Chicago
    I have a motor mount whose center bolt threads are damaged. I'm in the process of replacing but can't seem to locate a supplier who has the actual center bolt in stock. It's Ferrari p/n 106527. Can I just replace the bolt with an off the shelf of similar strength?
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Yes, you can. The only thing special about the OE bolt is the "self-centering" tip. Just be careful that you don't cross-thread the bolt...As I recall, it is a 12x1.5mm pitch.
  3. Dizengoff
    Nov 24, 2011
    625
    Chicago
    Thank you!
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    You're welcome...and I stand corrected. The bolts are 12x1.75mm thread pitch. (I'm doing motor mount in a QV now and just happened to have the center bolts removed.)
