3.2 ported/big valves/carb first Dyno: WAY rich | Page 2 | FerrariChat
Discussion in '308/328' started by snj5, Jul 1, 2008.
  1. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
  2. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Thanks Hy. I didn't know there were to types. Makes sense that one needs a load type dyno.
    I might just load the GT4 in a plane and bring it over to Russ' dyno in Texas :D
    I've never driven a US spec GT4, so I can't tell how they differ. All I know is that mine is pretty uncivilized - loud, smelly, snorting, spitting, FUN..... :D:D:D
  3. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Hi Russ,
    Looks like you are having fun now :) I recently purchased an rpm sensor, so am looking forward to your experiences and thoughts.
    good luck,
    chris
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hans,
    I borrowed a friend's LM1 and stuck the sensor up the tailpipe on a little bracket I made out of coat hanger. (No cats). I did the A/F in the driveway. It might be a little more accurate when you are actually driving, but you don't need a bung if you have no cats, as I'm sure you know.
    Birdman
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #30 snj5, Jul 15, 2008
    Am looking to pick the car up probably Friday or so in Dallas. Will put in the LM-1 for the trip back to San Antone.
    More impressions from James at Norwoods:
    Will need at least a 50 - 52 idle
    135 main is about right
    the car seems to be tolerating the leaner accel jet
    I'll take some jets with me to rejet on the trip if need be. The LM-1 records both A/F and RPM, so in theory I can do a 4th gear pull on the road and go back and chart the rpm+A/F, then compare to the dyno.
    Once I can get it to hold about ~13 at WOT and ~14 at part throttle cruise, and limit the accel pump tip-in to 12 or so, we'll find a Dyno-jet to re-baseline the car. I think with the improved low-mid range, much improved throttle response and a conservative top of 320 - 330 at 7200 - 7300 will be a nice solid and reliable overall package. And, easy to DIY maintain. The personality and sound should be pretty impressive.
    For those who have not seen what A/Fs look during ordinary driving, here is an LM-1 trace of the Mondial with the previous 40 DCNFs taking a Freeway on-ramp:
  6. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #31 snj5, Jul 23, 2008
    Hurricane has delayed picking car up and riving home, but talked to Mike K. at Norwoods who drove it today. Mike has a A LOT of time with Weber carb'd cars of his own, especially 911s, and knows what to feel for. With the new jetting and a quick re-synch, he says the car drives quite well and is dang close to right on with no spots. This is especially heartening as it suggests that the leaner accel pumps will cover throttle opening yet keep the A/F from plummeting as with the fatter ramps. This would serve to improve the already good throttle response (something amazing when compared to original K-jet).
    Equally important, he says it starts right up with two accel jabs, idlea at 1000 rpm and runs the exceptionally well performing A/C ("best i've seen in a Mondial or 308") well with no need to adjust the idle set or hold throttle.
    He took it through slow, moderate and fast driving regimes without apparant problems. Since the big dyno hp/torque dip is above 3500 rpm, I'm hopeful that we are well on our way to correction with the 135 main, down from 145 main as shown in the dyno. In my experience with the 40 DCNFs, changing a jet one size (i.e. 145 to 140) would change the A/F approximately 1 A/F point across the curve. So if before, as we were running in the A/F 10 - 11s, we should be closing in on the 12 - 13s, which is where we want to be. If Mike is right, and I feel pretty certain he is, I think the only tweaking will be the A/C jet, althoiugh I am sore tempted to squeeze the idles a bit.
    We'll get the LM-1 one on next week and balance the numbers with seat of the pants and see where to go.
    As always, kudos to James, Mike and Any at Norwood's.
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #32 snj5, Jul 27, 2008
    Got this picture today from FChatter Joshvette, who detailed the car.
    All I can say is WOW! Great job!
    Looking forward to tomorrow!!!!!
  8. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Sweeeeeeet!
    Enjoy your new ride!!!!
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #34 snj5, Jul 29, 2008
  10. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Okay, how did you take a pic of yourself leaving the shop? I didnt see a flux capacitor installed anywhere in your car.
  11. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    photo courtesy Jimpo1
  12. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    How come you didn't wave with your cowboy hat??
    YEEEEEHAAAAAA!!:D
  13. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Might scare the horses.
  14. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #39 Pizzaman Chris, Jul 29, 2008
  15. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Hopefully not riding a bomb...and since we have never met you do not realize the humor in portraying me by someone named 'Stringbean'.
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #41 snj5, Jul 30, 2008
    For all of the tweaks to the car, it still looks much as it did, and fairly stock appearing. The only two big visual changes are the lengthened airbox snout and the wider exhaust with a Euro-type valence replacing the US rear grille.
    Did not want to push it so much on the way home until I have an A/F meter on the new jetting, but the jetting feels pretty close. The big success looks to be the suitability of the smaller accell pump ramps over the previous large ones.
    It sounds very good outside of the car. Inside it's ok, but maybe a little too much induction sound. I've got an idea how to fix that this weekend for a nice mix.
  17. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,262
    Indiana/North Carolina
    JIM
    So are we going to take bets on how long Russ is going to have that smile on his face?
    The car looks AMAZING!!!!!!!!!!
    JIM
  18. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Still waiting for the new Innovate LM-2 to do A/F, but here are the 'clinical' impressions on the initial jetting of 135/F24/190 with 52 idles on (relatively) whompin' 38mm chokes. It's close - you can feel ultra-subtle little spots - maybe - but it pulls like never before cleanly all the way to 8K. There is no noticable lag in throttle response despite the bigger venturis and small accel pump cams. This hopefully verifies that all that large air velocity that Vic measured on the flow bench is working for us. Interestingly, turning the A/C on only lowers the idle about 100 rpm and the engine acts like it doesn't care. On the ride up, you cannot really feel a 'coming on the cam'. She just keeps getting faster, faster. It is also wild to me that I got about 20 mpg on the 65 - 75 mph trip from Dallas to San Antone on 4 x 44 dcnfs.
    I cannot begin to describe the sound over 4000 rpm - so smooth, beautiful and definitely a clean baritone. It is unmistakably Italian and Ferrari. If Andrea Bocelli were a car he would sound like this. James at Norwoods even commented it is what a Ferrari V-8 SHOULD sound like. There is some more induction sound in the cabin than previously - go figure. You can talk at cruise, but while the actual exhaust sound volume is low, the induction is pretty apparant. And Woo-Hoo you can't hear that annoying woodpecker Facet pump clicking away now that it is replaced by the Pierburg.
    And, I am very glad I went with Norwood's Kevlar clutch package as it feels great. Not too much effort, but solid.
    The biggest thing I know I am going to have to figure out is why the new linkage feels like it has so much more friction, especially at the beginning of travel it seems to bind just a little. I also have figured out I cannot drive the Ferrari well in Birkenstock clogs.
    Another side note - I had kinda regretted buying the new Michelin PS-2 before I had driven with them, but they are really great. Excellent response and a terrific ride - better than the Pilot A/S I had before. I had also chosen slightly narrower sections (205 and 235) on the 17" Speedlines, but the car feels remarkably poised. I think these are an excellent match for the Mondial. I have not tried to push them yet, but they feel good so far - it just re-inforces that there is a big difference with newer technology tires on the Mondial.
  19. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Sooo, what's next??
    A man's gotta have a project on his hands, right? ;)
  20. bill308
    bill308 Formula 3
    1,225
    Windsor, CT
    Bill Sebestyen
    Russ,
    What's the advantage to the LM-2 vs the LM-1?
    Bill
  21. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #46 snj5, Aug 2, 2008
    Bill, as I understand it, the advantage is primarily TWO A/F inputs versus one, plus beefed up connectors.
    The advantage for me is the movers lost my LM-1 last year when I changed houses. #$% !
    Hans - As far as projects, between the Mondial and the T-28 there will be enough to keep occupied for a while---
    ---of course, there's always a 50 foot Bristol Bay Pilot Cutter that I've been eyeing... (j/k)
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I think I'm going to have to steal your design for my car....I guess I need 4 mufflers though so I can group them in 3s. Now I just need to hold off on designing the air box until you work out something your happy with there too :p
  23. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    The airbox is close - we got more hp on than with it off! It seemed that velocity is important here as well, so I opened it up and ensured that the area that the airfow was seeing was smooth, about the same or very slightly narrower progressively - and also eliminated all flexible couplings. Intuitively, the flow in the airbox has inertia and flow qualities like everywhere else, so why not use porting principles (that YOU taught me) and apply them to the airbox? :)
    It's just loud.
  24. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    This is like saying that Pavarotti was loud!
    It's singing!!!! ;)
  25. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #50 snj5, Aug 4, 2008
    When I have a headache, a hangover, both, or as a friend so eloquently says "putting the Mac on some skank"**, I want Pavarotti and the car to tone it down. :)
    ** how do you say that in Dutch? :)
