3.4L drysump build | FerrariChat
3.4L drysump build
Discussion in '308/328' started by Newman, Apr 16, 2018.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    This is the other 3.4 Im doing along with the CIS version. It was brought to me in pieces, not even a bearing in the block but the heads were still assembled and the 360 crank was provided.
    I had pistons and cams made, upgraded the rod bolts with ARP parts, springs suited to these cams, new valves, guides and bearings etc. The crank remains standard but has been polished. Liners machined using my torque plate. One main was a little tight so we made a quick pass to even everything out, a light pass on the decks then set liner protrusion which was inconsistent and had to be corrected. Ring end gaps checked and adjusted. Pistons go in next. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Albert-LP and AN-M like this.
  2. JCR
    JCR F1 World Champ
    11,041
    H-Town, Tejas
    Nice to see modern piston design. Contact reduction grooves and accumulator groove.
  3. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    #3 Newman, Apr 16, 2018
    And light! Interesting to see the change in direction where they want a larger second ring gap than the top which is the opposite to what was gospel not too long ago and is directly tied to the reason behind the accumulator groove.
    INTMD8 likes this.
  4. 4right
    4right F1 Rookie
    Good to see a 308 project again! Looking forward to watching this one progress!!
    Was this originally a dry sump or is it be converted to a dry sump?
  5. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Original dry sump application.
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,920
    Atlanta
    John!
    Those look like the exact same pistons I used with mine. Ignition timing was max at about 36-37 degrees if I remember right. Made great power!
  7. Albert-LP
    Albert-LP F1 Veteran
    8,187
    around Modena, Italy
    Alberto Mantovani
    fantastic job: it will need a brake upgrade... :D
    ciao
    Formula Uno likes this.
  8. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,153
    SanFrancisco BayArea
    1983 US 308 GTS QV
    This will be a fast car. Brakes only slow you down.
  9. Albert-LP
    8,187
    Alberto Mantovani
    which compression ratio is expected?
    ciao
  10. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Measured actual compression ratio is 10.2:1 which was chosen to work with our ethanol free 91 octane fuel.
    Stock 9.2:1 512 boxers are really 8.75:1 when actually measured and the 8.8:1 308's actually measure out at 8.5:1
    Albert-LP likes this.
  11. JCR
    JCR F1 World Champ
    11,041
    H-Town, Tejas
  12. fatbillybob
    Aug 10, 2002
    29,272
    socal
    I'm not up on the latest. Can you explain that a bit more? Accumulator groove is to help control combustion gas coming off top ring and reduce ring flutter. What is the thinking behind 2nd ring gap being bigger?
  13. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    283
    Winter Park, FL
    JK Stevens
    Keep the pictures coming! Beautiful......love to see the progress.
  14. AN-M
    AN-M Formula Junior
    Jun 30, 2012
    367
    Norway
    André
    Even though I have to limit myself to basic maintenance, it's truly inspiring to look at your work. Ever considered moving to Norway, Newman? :D Its a really peaceful country.
  15. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Also to relieve pressure buildup between the rings. It made sense to me that the upper ring would run hotter requiring a larger gap to make up for that and were gapped accordingly. We’re not talking a huge difference now but the second gap depending on bore can be the same or a thou larger than the top gap.
    You have to wonder if you would ever notice the difference. I’ll say no but maybe on John forces car you would.
  16. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    I’ll think about it lol
  17. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Here's how much the timing mark moves when the bolts are installed but left loose allowing it to rotate left and right taking up the clearance between the bolts and flywheel bolt holes. So when I tighten it how do I know where to put it to have true TDC?
    A boxer /Testarossa for example has a locating dowel between two boltholes to prevent this.
  18. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    With true TDC established using a piston stop and a degree wheel Ill know where to put the flywheel to have an accurate pm 1-4 mark, problem is it might shift because it wants to be rotated counter clock-wise to line up and crank rotation / load will encourage it to shift back. At least cam timing will be correct and I can set base timing assuming the mark is right and play with ignition timing on the road tests.
    Albert-LP and hyenahf like this.
  19. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    so you added a dowel to the fly wheel to prevent the shifting movement?
  20. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    No I didn’t because ignition timing is all it’s effecting which I’ll just play with. It just proves more than anything that setting cam timing with the flywheel is a mistake. Using the factory marks on the flywheel and cams could mean you’re cam timing is 6 degrees off (or more) because the cam marks are a starting point not dead on and the flywheel mark is a moving target. Takes time to do things correctly rather than good enough and you can’t know unless you check.
    hyenahf likes this.
  21. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Cams degreed in which lead to my next step.....Checked valve to piston clearance the harder way but the better way as well. In the last pic you can see how much the play dough is pinched at the far right indicating how close the valve edge is to hitting the piston. The depth of the relief is great, side clearance not so great. I wouldn't have known that clearance if I just pushed down on the bucket throughout the valve event as a quick check rather than re and re the head to do this test. Not every one is this way and I expect the CIS version to not be an issue here due to the less aggressive cams but every time I find something like this it reinforces the fact you can't skip steps. Exhaust valve clearance is great, didn't even touch the play dough. So Ill push the pistons out and open up the relief just a bit and back together it goes.
    Just to clarify the last pic, I took a cross-section of the play dough with a razor blade to get a clear look at how close the valve is getting to the piston.
    tbakowsky and thorn like this.
  22. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    #23 hyenahf, May 11, 2018
    6 degree is a lot ! thanks for sharing with us your findings
    seems odd on a hemi head that exhaust sides have more clearance? seems inversed... typically the exhaust side is closer to the pistons than the intake valves.
  23. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Agreed but there are a lot of factors, valve timing being one of them.
  24. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    F106b block.
    Formula One,,, 06b just like mine.
    10.2 to one???? seems a little high....
    Mine is 9.8 to one..... Pump premium ( 15% ethanol) works great,,,,., with the stock 1981 (Euro) Bosch CIS, mechanical injection.
    Where did you find the Ferrari (factory) dry sump parts?????
    Keep going,
    Edwardo
