3.4L engine dyno results | Page 2 | FerrariChat
Discussion in '308/328' started by Ferraripilot, Jul 31, 2012.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,827
    Atlanta
    John!
    [ame]www.youtube.com/watch?v=ECNMTdu72_k[/ame]
    [ame]www.youtube.com/watch?v=oEm6BGwTyuc[/ame]
    0-60 is probably somewhere in the low 5s or perhaps even upper 4s. I'm not going to beat on it to find out though. It's not geared as tall as an NSX in 1st and 2nd gear so it should pull through the gears a bit quicker but then again it can't be shifted as quickly either. No biggie
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    That sounds so smooth. Of course you made that video on a closed track.
  3. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    duhh. I actually live 10 minutes from Road Atlanta track and that was shot very near there. I'm so glad I'm out of that house we were stuck in for 6 months while our house was being built. I had zero room to do anything, now I have a shop. woo
  4. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    Last week I was chatting with one of the guys at FormulaGT in Munich regarding drivetrain losses with these engines. It may be a bit higher than we previously thought because their test subject was a race-built 308 engine which flywheel dyno'd at 309bhp, and then yielded 241bhp at the wheels. That's a massive 22% loss. I couldn't have thought in my wildest thoughts it could be that high.
    This very possibly means our power figures are not quite as far off as the factory originally claimed. Most solid stock 308 QVs will put down 190bhp at the wheels. If 22% is anywhere near correct, that would put stock output at 243bhp (ish) which is right about in line with their claims of the day. Wild
  5. jcurry
    23,928
    In the past
    Jim
    Wow, the tach hardly moved at all! (if I knew how to post a smiley I would!)
  6. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,310
    Netherlands
    Steven
    My 308 with turbo was dynood at 240,6 hp and acc to the " general" rule of a 17% drivetrain loss i was close to 300 bhp. My hopes however where to reach beyond the magic 300 bhp barrier. With this new figure for losses i did reach it after all:):):)
    Thanks for this new info!!
  7. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    My tach now works. It was converted to a square wave signal. Extremely accurate now too.
  8. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Considering that the 308 doesn't even have a proper ring and pinion, that loss number is not believable. I would suspect that two different types of dynos being used to measure HP are more the source of the delta discrepancy.
  9. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,273
    Dumpster Fire #31
    SMG
    I tend to agree, a 22% loss is massive, also it's not going to be fixed, possibly linear or slightly logarithmic but certainly not a fixed 22%. if I had the time I could sit and crunch the numbers based purely on the gears and est. the friction of oil viscosity, temp, clutch slip, diff and flywheel, etc... but it would be tedious a time consuming.
    Dynomometers are not all created equal and the sheer number of factors that go into a 'calculated' HP figure means that at best you could use it as a marker for changes on that one dyno, jump dynos and it's apples and oranges.
  10. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    That's entirely possible Dave. This being in EU as well they could have them set up very differently than some in the states do which is why at times we see such discrepancies in rear wheel bhp figures from the US vs EU. Weird right.
  11. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    Check out the German dynos Mercedes, Audi, and Porsche developed called 'Maha' for short. They are massively cool dynos that show powertrain losses at different rpms, and yes it indeed is a linear loss.
  12. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Well, since you opened the door, are we talking DIN-rated HP or SAE-net HP. As I recall, there's a 15% difference between these two ratings.
  13. airdelroy
    airdelroy Formula Junior
    May 10, 2007
    420
    Austin, TX
    Aaron Richardson
    So are there modifications that could be made to reduce this loss? Many are spending significant money to increase HP, but perhaps there are also changes to be made in reducing this drag on the HP the engine makes.
    Aaron
  14. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Yeah, I can't believe that. My bone stock (except aftermarket muffler) euro QV made 213 at the wheels on a dynojet. If you believe 22%, that would mean my engine makes 273 hp at the crank. No way is that possible for an engine that is rated at 240 hp from the factory.
  15. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    I don't think it's quite that high.
  16. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    that is the key... dyno your motor first on it and afterwards to see the gains
  17. hyenahf
    hyenahf F1 Rookie
    May 25, 2004
    2,603
    arent you contradicting what you posted a few weeks ago?
    http://www.ferrarichat.com/forum/showpost.php?p=141636196&postcount=189
    my hunch it isnt linear given how meshing gears work and the way oil heats up
  18. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    Not at all. Just new information from a very good engine builder. I'm not giving it much weight, but it's interesting. I'm still very lean north of 5k rpm, I'll get my 270 at the wheels.
  19. ColoradoTiger
    ColoradoTiger Formula Junior
    Jun 11, 2010
    607
    Colorado
    Mark
    I'm going to have the raw engine dyno results from Carobu soon. How much would it cost to put the car on some rollers when I get back to Denver to compare the flywheel #'s vs the rear wheel #'s. Would that be the first "side by side" example around here?
    Mark.
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,273
    Dumpster Fire #31
    SMG
    You can do that for a baseline, however considering your elevation in Co, it would be an apples and oranges comparison. Keep in mind elevation, temperature & humidity all effect the dyno results.
  21. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    Both dynos will be done at roughly the same elevation (5200 feet) so the measured friction loss should be acurate. Anyone else who does one or the other should be able to get a decent estimate from that.
  22. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Just finally saw this thread - Nicely done!!!! When I get back from here I need to makea trip up to Atlanta to come see you and your family!!! I also want to get photos of the cars together since I never got to do that in Oklahoma....
    PDG
  23. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    #48 Ferraripilot, Aug 19, 2012
    Would be fantastic if you could do that, yes.
    Elevation, humidity, temperature are all supposedly programmed into the dyno to be compensated for, at least that's what dynojet says. They claim dyno results will be within 1% regardless of conditions, but I'd be surprised if it was 1%, heck if it were 3% I'd be pleased. Then again, their software is very good so who knows.
    Other things that effect dyno runs at the rear wheels are wheel weights and I don't think they are looked at often enough. A 52lbs wheel/tire is going to dyno lower than a 45lbs wheel by a solid 8-10bhp, I know, I've seen it happen. Other things like oil type and temps play a bit smaller role but still at times measurable such as a 50w non-synthetic oil will dyno less than a 40w synthetic. I haven't run my engine on a synthetic yet as I ran it with this thick 20w-50 blend which is great stuff, but I think it's a bit thick.
  24. ColoradoTiger
    Jun 11, 2010
    607
    Colorado
    Mark
    I guess I should put my 390's on for the roller test then. I'm pretty sure the 17" compomotives weigh more, no?
    How much do dyno shops charge?
  25. Ferraripilot
    May 10, 2006
    17,827
    Atlanta
    John!
    Actually, just stick it on with the compomotives as you want to tune it with what you're running. A baseline dyno run on a dynojet is less than $100 and takes about an hour to set up, run it, and done.
