3.4L project | Page 6 | FerrariChat
3.4L project
Discussion in '308/328' started by Ferraripilot, Jun 21, 2011.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,920
    Atlanta
    John!
    there is some debate whether to use Threebond 1211 which is essentially the same thing but takes a couple days to 'set up'. To each his own IMO.
  2. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #127 Ferraripilot, Jan 20, 2012
  3. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    So very true...However:
    One big plus that 518 has over most other products is that can't break off into little "worms" and plug the oil galleries. The engine/pan surface should be perfect, in that it is not a place where most DIYs live. As I recall the factory moved away from RTV and ThreeBond type products due to the risks (warranty claims) of sealants remains ending up in place where it shouldn't be.
    On the other side of the coin, when the yahoos or "pros" in my area (you know who you are) pry the transfer case off with a screwdriver, a more "aggressive" sealing product is needed. In this case, less is always more...
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Strong work!
  5. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    I can't remember who it was that mentioned the factory uses threebond 1194 for some things like this...... it was someone though. I don't know if there is any truth behind it but yes it is a huge PIA to dissassemble later but this stuff doesn't leak and I personally believes it allows for more margin of error which helps with the naturally occuring not-exactly-perfect geometry of the Ferrari mating surfaces. I know Porsche guys stopped using it to join their case halves together for that reason. I know it's still used by several motorcycle companies at their respective factories. Both are still great it's just one man's voodoo right.
    Regarding 'worms'. RTV products will yield worms but Threebond absolutely does not as it is not an RTV nor a silicon based material, but rather it's an elastic type material once dried and applies as a viscous sticky liquid that is very difficult to remove from your skin once it's there (wear gloves!). But the stuff absolutely does not budge from the surface no matter the chemical once dried to its elastic state as opposed to RTV stuff which can easily be picked off with a finger.
  6. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Last night I put the #1 piston at TDC to check if the stock 308 flywheel marks would still apply with the 360 crank. Lo and behold they match meaning I can still check the initial and total timing using the stock 308 flywheel marks. I was fully expecting the 360 crank index hole to be mounted differently thus making the 308 flywheel marks null and void. This build gets better and better. I will snap a pic of this once other parts are in place.
    Also, any recommendation regarding cam cover finish? I had wrinkle paint black last time. I guess I like that..... the only other choice is red isn't it... hmm.
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    John,
    Is the 88 Modial crank the same as the 328 crank?
  8. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Indeed it is. I think it was '90 that the mondial went to the 'T' designation with the 3.4L?
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Thank you. I just got one off ebay now that I have your endorsment. Still collecting parts for my rebuild. Yours looks fantastic. I have been following and learning.......
  10. dave80gtsi
    dave80gtsi Formula 3
    1,948
    Ohio
    Dave Meredith
    #135 dave80gtsi, Jan 20, 2012
    Powder coated in a slightly wrinkled silver. Trying to mimic the bare cast look.
    Optional red highlights.
  11. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Oh fantastic! Grats to you. Document it here and build it here!
  12. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Now there's an idea. Thanks Dave. Definitely going into the consideration pile.
  13. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #138 Ferraripilot, Jan 21, 2012
    Flywheel and sandwich plate (aka Africa plate) bolted up this afternoon. I also found and made note of exact TDC which even on the 360 crank is exactly the same marking on the flywheel as it is with the stock 308 crank. The flywheel mark showing PM1-4 is off of exact TDC by 1 degree ATDC on both crankshafts. I am sort of amazed by this as it shows Ferrari's machining equipment for drilling crankshaft holes probably never changed. Anyway, there it is, 360 crank mated to a stock 308 flywheel. Don't let anyone tell you it cannot be done because here it is. No modifications required.
  14. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    That's pretty cool. Way to go.
  15. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #140 Ferraripilot, Feb 23, 2012
    cams are all dialed in. I set the intakes at 104LC and exhaust at 108LC. This closes the intake valve a little earlier which these engines really like for some reason. More pics coming soon, but she's almost done from this end. Just need to button down the cam covers, intake manifolds, and install the bell housing.
  16. 4right
    4right F1 Rookie
    Those are good looking cams. Paul will be installing your old cams in the Spring.
  17. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #142 Ferraripilot, Mar 5, 2012
    Here we go. Floor to installed and bolted to the chassis in under an hour, solo. It's definitely one of those things where when you have done it a couple times it's incredibly (but cautiously) easy. I have since bolted up the manifolds and a few other things. SHould be fired up soon.
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    An hour? Does that include a lunch break? We've got it down to six minutes. Slacker :D
  19. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    you must be doing it wrong @6 min.
    10 minutes to walk around the engine staring at it.
    15 minutes for the first beer
    5 minutes grabbing tools
    10 minutes for the second beer (they go quicker the more you drink.
    10 minutes to lower and tighten the mounts (you've had a couple of beers so take your time)
    10 minutes for another beer and thinking job well done
  20. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    ^ that
    you left out scratching yourself when wondering why the 1-4 bank exhaust manifold won't quite go in regardless of what direction you position it.
  21. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Dang me!!! You always miss something no matter how many times you've done the job but hey, give me a break, at that point I've shotgunned 3 beers
  22. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Checked a few things off the list last night. Sort of sad that this is almost over as I've really enjoyed every bit of this project.
    to recap what has been modified/changed:
    79mm stroke 360 crankshaft
    83mm bore
    10.5:1 JE pistons with low drag rings and gapless top rings. 60 grams lighter each piston
    Cat Cams fast road camshafts with 10.75mm intake lift and 248 dur @ .050
    stiffer valve springs from Performance Valve springs Australia
    44mm nailhead style backcut intake valves (2mm larger than stock)
    new larger ID and OD valve seats
    new exhaust valves
    ported intakes and bowl work porting - flow bench tested
    new clutch
    new high torque starter
    new water pump
    36-1 trigger wheel on damper for electronic controlled map-able ignition
    port matched intake manifold
    new custom designed crossflow aluminum radiator
    all new coolant hoses
    I'm sure I'm missing some things.... why didn't I just pull the entire car apart while I was at it. Ah well, she will be ready for spring fun.
  23. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    #148 Ferraripilot, Mar 8, 2012
    This was measured off of cylinder #1 with spark plugs in the 5-8 bank but not in 2,3,4. Also, the battery is not quite 100%. 185psi with these monster cams with great leak ain't too shabby. This will run nice.
  24. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I agree with your initial jetting as per PM, but wanted to add it will be easier to tinker with initially with one step hotter plugs. Once things are dialed in you can go back one step cooler if that suits your driving.
    Not sure if you have addressed this before, but at higher flows a consideration will be bellmouth clearance. There used to be a low rise bellmouth available out there for DCNFs which allowed more room to suck air.
    Strong work - should be fun!
  25. Ferraripilot
    May 10, 2006
    17,920
    Atlanta
    John!
    Thanks Russ. BP6ES it is then for now.
