3.5/3.7/4.0 Water pump seals? | FerrariChat
Discussion in 'Maserati' started by 67alloy, Feb 5, 2009.
  1. 67alloy
    67alloy Karting
    Jun 11, 2007
    111
    Anybody have a source for new water pump rebuild kit (impeller seals)? I know they are obsolete, but maybe someone has a fix for Sebring, 3500, Mistral???
  2. eogorman
    eogorman Formula Junior
    May 10, 2005
    337
    Buhl, ID
    Eugene O'Gorman
    There is an easy modification which uses an industrial pump seal. The seal I use is a US Seal # PS360. Cost is about $30. It requires the impeller to be machined .130 inch. But most impellers need to be machined to repair the damage. I have used this seal for over twenty years in six different Maseratis and have not had one fail. If you must have the original seal contact me off line. I do have two.
  3. 67alloy
    67alloy Karting
    Jun 11, 2007
    111
    Thanks Gene,
    I should have contacted you first. We wanted to avoid any machining (and also had a fan clutch problem to deal with) so we sprung for the MIE conversion. $650 w/exchange for the whole pump with clutch. There is also a seal available in Italy that is recommended but again requires machining.
