3 angle or 5 angle | FerrariChat
3 angle or 5 angle
Discussion in '308/328' started by Ferraripilot, Mar 25, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,859
    Atlanta
    John!
    Need some Ferrari expert advice on this one. The local machine shop is suggesting I go 5 angle if it benefits the flow for these heads. They had advised 3 angle are better for some. Anyone have a rough answer? Common sense tells me 5 angles = better flow
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,748
    The twilight zone
    Normally that is the case.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,875
    Mike 996
    True but in this case, whether it's worth the money is the issue. IMO, it is not. The more angles a valve job (properly done, of course) the better the flow theoretically. BUT the more angles, the faster the wear because the sealing area is much narrower. Competition engines normally have a 5 angle or even a radiased surface but they are rebuilt frequently. For street use an 3 angle is plenty sufficient. The difference in flow is not worth worrying about for street driving. Mopar hemi Barracudas in SS trim (currently turning 8.29 in the 1/4 mile) pick up about 15 HP with a 5 angle over 3 angle valve job. That's 15 HP at almost the 900+ HP level at 8k RPM. So if one of our Ferrari motors even managed to pick up 3 HP, I'd be impressed.
  4. Ferraripilot
    May 10, 2006
    17,859
    Atlanta
    John!
    thanks guys. good advice. Thing is, my shop charges the same amount for 5 as the do for 3, strange I know. Henson engines in Yukon, OK is the place. I will be impressed if it makes 1 bhp more than a 3 angle. Don't think it matters a ton for this application.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,748
    The twilight zone
    #5 mk e, Mar 25, 2010
    I use a formed seat cutter so it makes no difference at all 3 angle , 5 angle or my personal favorite 4 angle 3 radius.
  6. Ferraripilot
    May 10, 2006
    17,859
    Atlanta
    John!
    too cool. thanks mark
