308 2v sodium valves | Page 3 | FerrariChat
Discussion in '308/328' started by AREA, Jan 21, 2015.
  1. Nabga
    Nabga Rookie
    Oct 31, 2017
    17
    CT
    Barry Enis
    can i save this piston
    3mm deep groove ..... no cracks
  2. MrDino308GT4
    MrDino308GT4 Formula Junior
    Sep 2, 2009
    775
    Geldermalsen NL
    Arian
    Tulammo762 and Albert-LP like this.
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    I would say very lucky escape in terms of damage looks like a new valve seat and piston only.
    Tulammo762 likes this.
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,411
    Toronto / SoCal
    Rob C.
    The piston is garbage. Original pistons are cast and with a mark like that it is prone to failure. You got off lucky once don’t expect a second.
    Tulammo762 and thorn like this.
  5. BigTex
    79,218
    Houston, Texas
    Bubba
    Well you have won the lottery in way......
    Bad news is that pistons are not available, unless maybe a good salvage one??
    Trouble is you still have seven good ones!
    But, you are very lucky that happened and did not trash the engine badly.
  6. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,257
    Montana
    Kim
  7. BigTex
    79,218
    Houston, Texas
    Bubba
    Nice work......
    308 milano likes this.
  8. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,084
    If it helps, I may have a serviceable piston from when my engine was rebuilt 20-something years ago. I'm in the UK.
    miketuason and JuLiTrO like this.
  9. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    Looks great!!
  10. Albert-LP
    Albert-LP F1 Veteran
    7,784
    around Modena, Italy
    Alberto Mantovani
    2v USA cars with cat and high mileage: God bless you if you still have OEM Sodium exhaust valves.
    Change them, unless you own a low mileage car (and you don't want to drive it much agian)
    ciao
  11. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    #64 derekw, Jun 16, 2020
    Buy a used piston. I have some if you don’t find them in the US. I have updated 21-4N stainless valves for £10ea and you’ll need the guides lined (good engine shops will have the 8mm guide sleeves and tool.) I have viton stem seals £1ea. Change the rings and bearings while it’s out along with all seals (diff, shifter, cam drive bearing etc)
  12. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    383
    Julio Saiz
    Ciao Albert,
    Bold question, does it apply for non-cat cars too?
  13. Albert-LP
    7,784
    Alberto Mantovani
    Yes, of course: but for the cat cars the problem comes out earlier, as the cat raises exhaust temperatures and so the exhaust valves thermal stress.
    But It's not an age problem, like it happens for rubber parts: it's a mileage only problem.
    ciao
    JuLiTrO likes this.
  14. JuLiTrO
    Nov 2, 2017
    383
    Julio Saiz
    Good, thank you. That was my guess
    I do have that "Damocles Sword" on my neck, there is only one carbon copy invoice from the 80's mentioning 'valves' but not the work done in a almost ilegible hand written.
    So I dont know whether those d**m valves are still in the car
    My guess is that they are not as I reached 63K documented miles and nothing happens yet so.... they were replaced... hopefully....
    We love these cars, dont we?
    Regards
    Julio
  15. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    Is there anyway to look at the valves with a bore scope and determine if they are sodium or SS?
    JuLiTrO likes this.
  16. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    577
    Yorkshire UK / Switzerland/ Liguria ( Italy )
    Portofino
    Apparently the stainless steel aftermarket ones are not magnetic.
    The OEM sodium/ steel are magnetic.
    Perhaps the best access is from the top .....under the cam covers .....try a small magnet from that end .
    You might be in there anyhow....fixing oil leaks , doing the clearance etc .
    Or if the exhaust manifolds or Carbs are off ...,,you could turn the engine and try the magnetic test .
    Obviously taking necessary precautions not to drop anything in .
    JuLiTrO and ferrariowner like this.
  17. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,411
    Toronto / SoCal
    Rob C.
    To access the valve tip with a magnet you do need to remove the cam cover, camshaft, and cam bucket. Quite a lot of dis-assembly to run a test that can be deceptive at best.
    I changed my OEM valves to Stainless a few years ago and, out of curiosity, tried a magnetic test between the two installed valves and there was not a definitive difference in pull between the stainless and non stainless valves. I believe that the steel keepers and spring retainer make it difficult to determine if the valve is stainless with a magnet.
  18. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Look at my engine rebuild— google Derek’s 308 and I describe how to test the valves via the plug hole. There are a lot of 2V engines with high miles so it seems random or perhaps related to oil quality, driving style, fuel quality etc. As many know, the guides are soft, wear, and the eccentric closing of the valves with over-specified springs causes fatigue at the weld joining the head to the stem.
  19. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    I thought high-mile 3x8 cars were more proven, and reliable? ;)
  20. Nabga
    Nabga Rookie
    Oct 31, 2017
    17
    CT
    Barry Enis
    are the valves still available??
  21. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    Yes, lots left both inlet and exhaust. I have a range of lengths (.020” range) so depending on your seat wear I can usually find some to give a usable shim thickness. Get your guides lined if they are loose (don’t buy new guides unless they are undersized and you can index cut them concentric with the seats. If you fit new guides and cut the seats you will sink the valves into the heads and the shims to give correct clearance will be too thin. £10 per valve, £2 per viton stem seal (butyl seals in most gasket sets are not suitable for exhaust valves.)
  22. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    Just to let you know not all stainless steel are none magnetic. I have some SS valve from or for my Fiat/Lancia and I can still feel some kind of magnetic in them.
