308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 12 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. 350HPMondial
    350HPMondial F1 Veteran
    5,343
    Edwardo
    #276 350HPMondial, Dec 18, 2011
    Need SKF Bearing Number please.
    Ferrari PN 103042
    1982 308, 208, Mondial-8, Clutch Shaft, Flanged Double Row Ball Bearing.
    Thank you,
    Edwardo
    see mine is pitted = noisy
  2. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    That should be SKF BA2B 633912 C3,, but I believe that p/n has been replaced by BA2B 636151A C3. Please check this info. If it is in fact correct, please let us know! (and the price..)
  3. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    anyone found an alternative source for these pricey items if bought from the f store? thanks, jon s
  4. PT 328
    PT 328 F1 Rookie
    4,019
    328 Auxiliary Air Valve OEM Bosch #0280140229 cross referenced to part #AC4233 available at Autozone for $699.
  5. thecarreaper
    thecarreaper F1 World Champ
    18,165
    Savannah
  6. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
  7. 89 FERRI
    89 FERRI Guest
    Jul 31, 2010
    86
    Cold Spring Harbor ,
    Elliot Siegel
    my heater valve is leaking when the heater / defroster is switched on . Can this valve be replaced / repaired how difficult is it to remove , repair and how can I source a new or used one , Thanks Elliot [email protected] or 516 528 5010
  8. Steve Magnusson
    27,026
    Unfortunately, the QV valves have a 7mm stem diameter, not 8mm (yet have the same 10.8mm OD guide, and I don't see that combination on that page).
  9. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    #284 Falcon, Jan 10, 2012
    Got a new starter for my 328 at NAPA. It's a Bosch unit, part number SR488X, $385.02. Absolutely identical to the original, right down to the stampings. It also fits the Testarossa.
  10. PT 328
    PT 328 F1 Rookie
    4,019
    I recently replaced the auxiliary air valve (AAV) on my 328 due to horrific cold start idling. At the same time I found and ordered a new frequency valve protection relay from Pelican Parts ($91.00) as part of preventative maintenance.
    Relay OEM part number 92861512400
    Relay Cross reference part # 92861512402
  11. Jdubbya
    Jdubbya The $10 Trillion Man
    44,170
    Hell's waiting room
    Do you or anyone know if this is the same starter for a 78 carb car? Looking at the usual supects it appears a NOS one would be bewteen $1,700 to $1,800!!
    I think I'm having issues with mine. My first try is going to be taking it to a local electrical repair shop, starters, alternators is all they do. I'm hoping they can rebuild it for me.
    If not did you get a part number for this one from NAPA?
  12. Jdubbya
    44,170
    Hell's waiting room
    Sorry Dean, I see the part number now...duh!!
  13. Jonny Law
    Jonny Law F1 Rookie
    3,211
    Over yonder.
    IT Guy
    FYI to all
    Ordered a set of the Strong Arm 4760 from Rock Auto for around $30
    They fit the brackets, but did not have enough strength to hold up the deck lid. Any ideas?
  14. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    These struts are for a 1886 to 1998 Saab 9000 hood. If you have them look under the Saab they will find them, part number C4760. But do they work?
  15. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    What are you trying to fit them to, 308GT4, 308, 328? I was thinking of getting a pair for my 328. I know as the numbers get higher the struts get longer. Maybe a 4761? The parts store should be able to assist you.
  16. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    If you're looking for struts for a 308 GTS QV, etc., get the Stabilus/Sachs struts from RockAuto.com (part SACHS #SG237001). Just put a new pair on and they're great. I did install both. They don't slam the lid up, and they hold it perfectly.
    mixedgas likes this.
  17. sporty883
    sporty883 Rookie
    Aug 23, 2010
    16
    I'm no cheapskate, nothing but genuine Ferrari parts go on my imaginary 308! Hehehehehe
    Seriously, before I paid $350 for an oil sending unit I'd retap the hole if possible.
  18. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Great quality foam for closing in the radiator bay can be had from Grainger. Their item number is 5GCU7. They also carry the 3M spray adhesive.
    As a side note....should you need engine bolts, Fastenal has pretty much anything metric.
    **If you pick up the foam at the Charlotte NC shop, stop across the street at KT's cart in the Little Hardware parking lot :D best grilled Brats and Italian Sausages in town.
    mixedgas and Mark C Harvey like this.
  19. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Internet source for QV water pump and alternator belts (Gates 7M630 and 7M750):
    http://www.royalsupply.com/
    **Minimum order of three each
  20. ivo73
    ivo73 F1 Rookie
    Mar 3, 2005
    3,495
    Switzerland
    Ivo Pucci
    Does someone have or know where i can find a Bosch parts list with reference to the parts from the Ferrari cars ?
    thanks in advance
    Ivo
  21. guygowrie
    guygowrie Formula 3
    Sep 19, 2011
    1,400
    ct
    guy s
    For 308gt4, searched through the boxes at my local autozone and the following looks like a perfect match for the Donut gasket between headers and muffler.
    Duralast by fel-pro - #60985 - $2
  22. conan
    conan Formula Junior
    Nov 13, 2011
    389
    #297 conan, Apr 28, 2012
    The AC blower motor might not work as expected. If turning the knob only slightly increases the blower speed and at the end, the blower motor suddenly runs at maximum speed, the AC blower motor transistor could be faulty.
    A replacement transistor for the BDY29 is the 2N5886. Datasheets are readily available on the internet, but the picture below should have all references needed to successfully replace one transistor against the other without mixing up the leads. The pinout is exactly the same ...
  23. porphy
    porphy Formula 3
    1,210
    LouisvilleKY/Switzld
    Randall Gatz
    Are you talking Mondial here or??
  24. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    Looks like the oil Temp Sending unit is going bad,there is a steady drip once the car has come up to Normal opperating temp,this Morning i went under the car checked all oil pan nuts,all snug,slight weeping,next project Oil Pan gasket.The leak on the Temp Sender looks to be where the wire connects to the sender.Part#107576,Anyone have a cross reference to that Number?
  25. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
