308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 13 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. MR2 Mike
    MR2 Mike Rookie
    Mar 11, 2012
    28
    St. Augustine, FL
    Mike Rioux
    Just wanted to let everyone know that I have been going through this thread and compiled an alphabetical list of the parts mentioned here and put them into a viewable or downloadable PDF on my site. I plan on doing this for some of the other models that threads have been contributed to here on Ferrari Chat. I'll try combing through them on a regular basis so I can keep these lists as up to date as possible. Hope this helps some of you guys!
    http://www.ferraridiy.com/parts_guides/308-328/
  2. MR2 Mike
    MR2 Mike Rookie
    Mar 11, 2012
    28
    St. Augustine, FL
    Mike Rioux
    Sorry everyone, just realized the PDF was not set to be "executable" from my hosting account. All has been changed and the PDF should open up and be downloadable now. Again, hope this is something helpful for you all.
  3. thecarreaper
    thecarreaper F1 World Champ
    18,165
    Savannah
    posted
  4. BLACK HORSE
    BLACK HORSE Formula 3
    1,976
    California - Bay Area
    Rob
    Help... Looking for a OEM O2 sensor for a 1985 308 QV US car. Anyone knows where I can get one without grabbing my ankles for it?
    Rob
  5. Dr Kananga
    Dr Kananga Formula 3
    Apr 20, 2011
    1,222
    Los Angeles, CA
    Buonapart I. Gallia
    #305 Dr Kananga, Jul 14, 2012
    1/2" ID - PN 28439
    5/8" ID - PN 28447
    Plan on picking up some extra 5/8" hose to extend the hose from the radiator pipes to the hose tee to address the below Service Bulletin.
  6. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    Dr.
    Have you or anyone had any luck tracking down 1-3/8" i.d. fuel hose to replace those two 4" long rubber hoses connecting the crossover tube to the saddle tanks? I don't want to pay $40 each for OEM's if I can help it. Most hose I've found is only rated for "filler neck" not 24-7 submersion in gasoline (so say the mfg.'s).
    Bob
  7. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,747
    South East
    Jimmie
  8. Dr Tommy Cosgrove
    36,723
    Birmingham, AL
    Tommy
    If memory serves it is the same as a 1989 Saab 16V Turbo. Try that Bosch part number and see what you come up with.
  9. PT 328
    PT 328 F1 Rookie
    4,019
    Fuel Pump Check Valve for late 308QV and the 328
    One cross reference part number is E3030-27424 and is available at http://www.importeccatalog.com/
    Other cross reference numbers courtesy of Steve Magnusson:
    Ferrari PN =120098
    Bosch PN = 1587010532
    Other = W0133-1627491
    Available at AutoHausAz or www.rockauto.com
  10. ClydeM
    ClydeM F1 World Champ
    12,321
    Wayne, NJ
    Clyde E. McMurdy
    I thought I posted on this before, but can't find it.
    My coil wire caps(aka nipples aka terminal nipples) were falling apart.
    Found at Car Quest EC TN7 .25 each.
    aka CarQuest=Blue Streak = Standard Wires
    They are black.
  11. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    #311 don_xvi, Nov 20, 2012
  12. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    (Couldn't edit to add)
    Ferrari Part number 110664
  13. newto308
    newto308 Karting
    Mar 20, 2007
    92
    McLean, Virginia
    Chris
    I was really irritatied to see that Ricambia wanted $11.25 for a single 4.00mm Valve shim. I have since found out that the mid 1970's Fiats used the same valve shim as the 308 2 Valve cars. Fiat owned Ferrari at that point and the 33mm diameter valve shims used in the 308 cars are the same as the 1975 Fiat 128. I ordered all of my Valve shims from either International Auto Parts in Charlottesville, Virginia or Midwest-Bayless Italian Auto in Columbus, Ohio. Both have web sites that are very easy to use. I paid $2.15 per shim at IAP vice $11 at Ricambia.
  14. Dizengoff
    Dizengoff Formula Junior
    Nov 24, 2011
    625
    Chicago
  15. Dizengoff
    Nov 24, 2011
    625
    Chicago
    #315 Dizengoff, Dec 13, 2012
  16. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    353
    Mid West
    Paul John
    #316 ProvaMo, Jan 5, 2013
    I searched FC and couldn't find this, so I hope this is new and helpful information:
    For the 308 GTS (carb for sure, not sure for injected and QV) the interior map light, or dome light, is the same Hella unit as similar period Mercedes Benz. Paul
    Look for Mercedes Benz part number: 0008206301
  17. oceanview328
    oceanview328 Karting
    Dec 7, 2012
    214
    Charleston, SC
    Ed
    MR2 Mike,
    Regarding the K&N Air filter 33-2518: I tried this filter on my '87 and I could force it in but, it was not an exact fit (a little to long and narrow). I tried the K&N 33-2662 and found that it is a perfect fit.
  18. ClydeM
    12,321
    Wayne, NJ
    Clyde E. McMurdy
    one of my tenax pull-snaps was broken from the trunk on the latch covers
    Found them at http://www.eagleday.com/tefage.html.
    They are the exact replacements. GHE Made in Germany
    Dont forget to buy the little tool to make life easier.
    They simply unscrew & are a quick fix.
  19. John M
    John M Formula Junior
    Nov 18, 2004
    888
    Kentucky
    Thanks Clyde! I ordered 4 for my trunk as two of mine had lost the threaded retaining nut. At $5 each, those are cheap enough to go all new and have them all shiny!
  20. Icandrive
    Icandrive Rookie
    Apr 29, 2012
    22
    Ma
    Harry
    Is there a specific wording for the rear shocks on trunk lid? I thought it would be here but i can't seem to find it.
  21. John M
    Nov 18, 2004
    888
    Kentucky
    gas lift supports for rear engine cover
    stabilus sg237001
    strongarm 6271
  22. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    Gas struts can almost always be repaired; 99% of the time they just need re-gassing. Don't throw those OEM Ferrari logo stamped ones away if you can get a repair done. A shop wanting to sell new stuff to you may tell you otherwise but don't believe them.
  23. Icandrive
    Icandrive Rookie
    Apr 29, 2012
    22
    Ma
    Harry
    Hey, thanks!
  24. F1Austin
    F1Austin Karting
    Apr 29, 2012
    103
    Near Austin, Texas
    Pat Welch
    47407 has a wood front bumper!!! carreapper is this not rare,,,?? what a 308xpert U R,,,so fab I have the only 308erQV with a wood front bumper!! Does CR sell gold bars?
