308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 16 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. Jack-the-lad
    Jack-the-lad Eight Time F1 World Champ
    Are fog lights (US spec) interchangeable between GT4 and any other iteration of 308/328?
    I couldn't turn anything up with a search.
    Thanks.
    Jack
  2. 2281GT
    2281GT Formula 3
    Oct 9, 2006
    1,134
    Germany
    Markus
    #377 2281GT, Mar 16, 2016
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    Dust boot and seal for front caliper is same as that which fits a 1985 5 series BMW. Rock Auto has them for $3.16 per caliper.
  4. rickyx
    rickyx Karting
    May 9, 2006
    117
    #379 rickyx, Jun 9, 2016
    Hello everybody,
    Can someone help me out sourcing a double wired capacitator, or at least now the part number (or market equivalent). Superformance in the UK only have the single wired ones at stock.
    Thanks,
    Ricky
  5. 308Kelly
    308Kelly Rookie
    May 18, 2004
    22
    Hartford Area
    Edward
  6. DickyF
    DickyF Rookie
    Oct 29, 2016
    1
    HI
    as the title says im looking for a pair of QV door wiring harnesses for the mirrors. needs to be a right hand drive as the passenger mirror is electric.
    thanks
  7. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    #382 Andy 308GTB, Nov 8, 2016
  8. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    #383 DANCER308, Nov 16, 2016
    If you strip out the gearbox fill plug hole , Dorman makes one with longer threads. Found at local auto parts. It uses a 3/8 ratchet to tighten instead of hex.
  9. craiggo
    craiggo Formula Junior
    418
    Redwood City
    Craig
    mixedgas likes this.
  10. Roberto D G
    Roberto D G Rookie
    Aug 13, 2014
    1
    Toronto
    Roberto Di Giulio
    Robert D G ,I just start to give a good face lift to my ferrari 1980 308 GTSi carpets seats etc.. i noticed my hard top sides rubber moldings( Removable roof) are worn out looking for new as anybody know where to get them.
    a reply appreciated Thanks.
    Arthbkins likes this.
  11. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    The PTFE coated (one side) thrust washer 22x38x1.5mm with pin hole.
    8 pcs used per car
    Location rear hub joint on wishbone
    These are standard off the shelf items:
    Industry pn: WC20DU available as low as $ 2.37 ea for 37 pcs
    Global Machine has them in stock $4.37 each.
    Algar has them at $17.10 each
    Mr Fiat $42.00 each
    miketuason likes this.
  12. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    106769 Differential on my 1982 308GTSi. The 4 friction disks and 4 spacer disks. I found them to be the same as from a 188 BMW differential. I found a seller who makes for his BMW race team. Belgrad Serbia.
    Much less then Porsche disks.
  13. absostone
    absostone F1 World Champ
    10,311
    wow good find thx
  14. BLACK HORSE
    BLACK HORSE Formula 3
    1,976
    California - Bay Area
    Rob
    I have a 1985 308 QV GTS US car... does anyone know where I can get the following air injection system parts? I need them and preferred new.
    1. differential pressure switch
    2. Cut-Off valve
    3. Solenoid Valve
    Not sure but someone tell me if GM made any of these parts? If so they're I'm sure much cheaper than some of the Ferrari part houses what they want for them! Also any other cross-over from other vehicles that used the same parts? VW, Porsche, etc...
    Thx
    Rob
  15. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    The wishbone bushing insert PTFE coated sleeve where the hub meets the wishbone is a standard off the shelf item.
    701064 or ZU MB2025ZU approx $1.40 Ea
    20x23x25mm
    Press out the old press in the new one.
    Ferrari Dealer $16.25
  16. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    CV Joint Spring Washer Porsche 901-332-312-00
    CV Joint Circa Clip Porsche 999-152-084-01
  17. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    108048 is a basic va45 seal. Off the shelf item $1.50
    Some suppliers for F parts $20
  18. Lawrence Coppari
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    RockAuto sells them. I rebuilt my fronts due to car pulling to one side during braking. No more pulling to one side. Fronts cross reference to a BMW. Rears do not. Hence they cost 7 times as much.
  19. Softtail11722
    Softtail11722 Rookie
    Jan 30, 2017
    25
    washington state
    ron
    anyone know a source for a replacement knob for the choke lever on a 1977 308 GTB
  20. todd6363
    todd6363 Formula Junior
    Jan 20, 2007
    270
    Ohio
    Todd
    QV pilot bearing - SKF 62202-2RS1
  21. GordonC
    GordonC F1 Rookie
    4,169
    Calgary, AB, Canada
    Gordon
    You kind of need to provide the exact year and model of BMW for a cross reference to be useful... ;) or the brand and part number of the repair kit you bought?
  22. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    #397 waymar, Feb 14, 2017
    Does anyone have the dimension for the replacement collet sleeve? The sleeve can be pressed out and a new $4.00 sleeve pressed in. It is the exact same type as the (hub / wishbone) joint on the rear suspension. Measure is id and length. It is the bottom item in photo
  23. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #398 derekw, Mar 7, 2017
  24. absostone
    10,311
  25. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    #400 waymar, Mar 11, 2017
    This bearing is standard PN N2206 (30x62x20) Any bearing house has them got mine for $38. I have seen these advertised for a range of $275-$498
    Removable outer race. As a last resort there is a NU2206 more readily available the NU2206 is same bearing only with a removable inner race. Both are available with standard steel cage or optional bronze/brass cage.
